Author Topic: [GB] Magnum65 by Cary Works  (Read 4973 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Thu, 28 March 2024, 09:20:47 »
GB NOW LIVE!
Magnum 65
by CaryWorks
Post edited by ClickClackIO
Please see the IC post for more details: https://geekhack.org/index.php?topic=122595.msg3182700#msg3182700.
Index
- Intro
- Streams
- Design
- PCB and Layouts
- GB Details
- Colorways
- Pricing and Vendors
Intro
The Magnum 65 is a unique keyboard brought to you by CaryWorks, which is inspired by the "Magnum" revolver. The Magnum65 is a 65% dual-mode Bluetooth keyboard comprised of 40+ components and featuring a gasket-mounted structure.
We are happy to announce that the Magnum65 keyboard GB will come at the end of March!
With the amount of support and traction the Magnum65 keyboard has received, we are excited to take this keyboard to the next step.
Design
The Magnum 65, as the name suggests, is inspired by the theme of the classic revolver. The revolver cylinder is not purely for looks. It is a piece of engineering art! The cylinder is redesigned into the weight, consisting of 11 components and 8 connectors, retaining the cylinder's ability to rotate, coupled with the detachable bullets, capturing the essence of its rotating motion.
https://imgur.com/ltNxNwN
Streams
AndyVNGuyen
Magnum65 Kit Components
What the Magnum 65 kit includes:
Main:
●   Upper case;
●   Plate;
●   Base;
●   Side-mounted magazine (with 6 bullets);
●   Battery, battery cover plate,
●   Badge;
●   Distributed silicone grains for indicator lights (4 pieces);
●   Foot pads (4 sets of 2).
Weight:
●   Base;
●   Cylinder;
●   Bearings;
●                Spring plates;
●   Bullets (6);
●   Bullet securing rubber rings;
Locking mechanism.
PCB:
●   Bluetooth dual-mode PCB;
●   Power board;
●   Lighting board;
●   Aluminum alloy spring structure plate;
●   Poron switch spacer;
●   IXPE switch shims;
●   Case Foam
PCB & Plates
▼ We will offer 2 kinds of PCBs:
└ 1.2mm Flex-cut Hotswap PCB
└ 1.6mm Non-cut Hotswap PCB
▼ Plate:
└ Flex-cut Aluminum Plate
└ Non-cut Aluminum Plate
└ Non-cut FR4 Plate
GB Details
GB start time: 29 March 2024, 20:00 EST
GB end time: 28 April 2024, 23:59 EST
Colorways
This release includes three colors: Desert Yellow, Moonlight Silver, and Shadow Black.
Desert Yellow applies a spray coating process, while Moonlight Silver and Shadow Black apply an anodizing process.
Desert Yellow - Spray Coated
Moonlight Silver - Anodized
Nightshade Black - Anodized
Pricing and Vendors
Pricing: $379.00
**FREE SHIPPING INCLUDED IN THE PRICE**
Vendors: Worldwide: ClickClackIO
Socials
Join ClickClack’s Discord for the latest updates, discussions, and questions:
Follow ClickClack's IG for other new projects:
« Last Edit: Tue, 09 April 2024, 14:58:20 by ClickClack.io »
Re: [GB] Magnum65 by Cary Works
« Reply #1 on: Tue, 09 April 2024, 15:18:24 »
Approval bump :thumb:
