Author Topic: [IC] DSS 99¢ | 90s Vibes for 40s Boards | GB Begins Aug. 24!  (Read 12027 times)
Offline sidrow
  • listen to Blowback
« on: Sat, 06 April 2024, 12:12:15 »
DSS 99¢
the best profile meets a timeless 90s vibe
kitting
colormatching
renders
machida by fruitykeeb // mesektet by sidrow
(note: the new SP stock colors haven't been accurately digitized yet, so the pink in the renders is somewhat softer/less saturated than the physical sample—for the most accurate view of the colors, please refer to the photo of the color chips and the Arizona bottle above)
interest check form
Details
DSS 99¢ is a 40s-oriented keyset, with one robust kit to support a huge variety of 40s and 30s layouts. The kitting should cover any row-stagger and ortho layout (and most columnar-stagger as well) from 13u on down, including 40s with a Gamer Row—feel free to ask on here or Discord (same username) if you want to confirm compatibility with a particular layout. Colormatching is complete (see photo above).
To accompany the base kit, we've partnered with Pseudoku/Asymplex to offer convex DXX minibars (designed to emulate a convex version of DSS R3) in sizes from 1u to 3u, as well as DSS ISO Enter. These keys will be available in two styles: opaque and artisan. The opaque bars will be matched to the alphas, and the opaque ISO Enter will be matched to the accent pink. The artisan versions will be a mix of the alpha cyan, mod green, and accent pink in Pseudoku's dynamic signature style!
  • GB from August 24 - September 23
  • Cost: 115 USD (or local equivalent)
  • Vendors: Sneakbox (U.S.), KeebSupply (E.U.), and ergokeyboard.sg (Asia)
  • Manufactured by Signature Plastics
  • All SP stock colors:
    • Alphas: VDR on VBV
    • Mods: RFJ on VCO
    • Accents: WA on RFJ
  • Doubleshot ABS in DSS profile (1-2-3-4-3 sculpt)
  • Trashcon Icons by TrashMan
  • Matching convex minibars and ISO Enter by Asymplex
  • Renders by Liv (OJ)
« Last Edit: Sat, 17 August 2024, 14:33:38 by sidrow »
Offline sidrow
Re: [IC] DSS 99¢ | 90s Vibes for 40s Boards
« Reply #1 on: Sat, 06 April 2024, 12:12:46 »
Update History
April 2024:
  • Kitting updated
    • Cut R1 1u grave/tilde
    • Cut 1x R3 1u Sys
      • 1u bottom-row mods are now 2x Ctrl, 2x Alt, 1x Sys, 1x Menu/Fn
  • Renders added
« Last Edit: Sun, 28 April 2024, 19:13:01 by sidrow »
Offline KuroTheCrazy
« Reply #2 on: Sat, 06 April 2024, 12:24:07 »
Aside from the obvious similarities to aesthetic's colors and inspiration, this has some odd choices. Why is the darker green, which is pretty small on the bottle, being used for the alphas color? And why include the 1-6 num keys when only one or two 40s will support it? Should either get rid of them to ease up costs, or add the rest of the numbers to add some coverage for anything with a numpad, which is probably more common in 40s than a half numrow.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #3 on: Sat, 06 April 2024, 12:40:54 »
I am going to give you 99 cents for a set of this  ;D
GLWIC
« Last Edit: Sat, 06 April 2024, 14:27:03 by twitchytheinsideman »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Sat, 06 April 2024, 14:09:43 »
Finally the general public can witness the glory of 40s gbs
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #5 on: Sat, 06 April 2024, 14:39:42 »
[...]And why include the 1-6 num keys when only one or two 40s will support it? Should either get rid of them to ease up costs, or add the rest of the numbers to add some coverage for anything with a numpad, which is probably more common in 40s than a half numrow.
That hypothetical numpad would be all R1, and there's a healthy amount of v4n-layout boards floating around that do 1-6 only - arguably a more popular layout than 40s with numpads.
Offline sugarfreemedia
« Reply #6 on: Sat, 06 April 2024, 14:47:51 »
I agree, not including all the numbers is a questionable choice.
Offline LMarci
« Reply #7 on: Sat, 06 April 2024, 16:43:19 »
comment: TBD
Offline Chippy
  • sus chef
« Reply #8 on: Sun, 07 April 2024, 00:39:21 »
Reserved
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline baconspoon
« Reply #9 on: Mon, 08 April 2024, 16:21:54 »
Still love this idea. A couple questions: Why grave/tilde with half number row kitting? I'll wager that exactly no one uses that cap if the set gets made. Also, any chance for a pair of 1.25u "bars"? Have you gotten any quotes yet?
Offline tactilesbad
« Reply #10 on: Tue, 09 April 2024, 04:32:26 »
unusable
glwic
Offline HappyB0T
  • I'm a Piggie
« Reply #11 on: Tue, 09 April 2024, 17:27:11 »
If this had the pink and the mod green I'd be in.
Swap ~ for Esc.
Haha no FN key. I'm out.
« Last Edit: Tue, 09 April 2024, 17:32:20 by HappyB0T »
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #12 on: Tue, 09 April 2024, 19:06:07 »
Are one or both rows above DSA really R4 and just miss-labeled R3?  Mostly 1.25u and 1.5u are R4 mods.  Arrows are usually R4 as well.
Offline baconspoon
« Reply #13 on: Tue, 09 April 2024, 23:24:28 »
This set is 2-3-4-3 intentionally for a flatter bottom row. There is an R4 up arrow as well as R3 so you can put all arrows on the bottom row, or put up arrow on the Z-row.
Offline sidrow
« Reply #14 on: Sun, 28 April 2024, 19:30:46 »
Thanks to everyone who's responded and filled out the IC form so far! I've added renders (thanks Liv!) and made a minor update to the kitting.
For the person in the IC form asking if this supports QAZ layout: Yes! The kitting intentionally includes the mod keys you need to cover QAZ-like boards:
  • R2: 1u Esc for Q; 1.25u Bksp for P
  • R3: 1.25u Tab for A; 1u Enter for semicolon
  • R4: 1.75u Shift for Z; 1.5u Shift for period
Offline sidrow
Re: [IC] DSS 99¢ | 90s Vibes for 40s Boards | GB Begins Aug. 24!
« Reply #15 on: Sat, 17 August 2024, 14:06:42 »
Hi everyone, thanks so much for your interest in DSS 99¢! Your feedback has been super helpful in refining the kitting, and for everyone who asked for non-DSA minibars, we've lined up a fantastic partnership with Asymplex, so you're in luck! :thumb:
I have a couple exciting updates on the status of this project:
First, I'm happy to announce that we'll have three regional vendors for the set: Sneakbox in the U.S., KeebSupply in the E.U., and ergokeyboard.sg in Asia. We're planning on running the group buy from August 24 - September 23. The base kit will be priced at 115 USD (or local equivalent).
Second, we will be partnering with Asymplex to offer convex DXX minibars and DSS ISO Enter! Convex DXX minibars will be available in sizes from 1u through 3u. We'll be offering two styles: opaque and artisan. Opaque bars will be matched to the alphas (and the opaque ISO Enter will be matched to the accent pink). The artisan caps will combine the alpha cyan, mod green, and accent pink in Pseudoku's dynamic signature style. Check out some sample photos of the artisan prototypes:
« Last Edit: Sat, 17 August 2024, 14:23:37 by sidrow »
Offline culain
« Reply #16 on: Sat, 17 August 2024, 16:59:24 »
These look incredible
Offline sidrow
« Reply #17 on: Sun, 15 September 2024, 17:43:37 »
For everyone following along, we had a delay getting the GB thread approved, but we're live with about one week left! Here's the GB thread. Hope everyone is able to jump in and grab some Pseudoku bars as well! :thumb:
