Author Topic: [IC] Pangea Full Size  (Read 41121 times)
Offline bowlkeyboards
« on: Sat, 13 April 2024, 10:29:59 »
Pangea Full Size
IC FORM | Discord | Instagram |  Website
Index
1. Introduction
2. Specifications
3. Renders and Images
4. Inspiration
5. Availability
6. Status and Notes
Introduction
Pangea Full Size is my take on a full size keyboard design, with some extra features. The name comes from the supercontinent Pangea. Like the supercontinent, this keyboard can morph and change shape to better suit your needs. Pangea Fullsize features a unique construction allowing the user to change from “normal” numpad location to southpaw without the need for any additional parts. This is achieved through a 9 piece case construction with a specially designed PCB by Gondolindrim.
Specifications
Case:
Materials: 6063 Aluminum/Polycarbonate, Brass, Stainless Steel/Copper
Layout: WK/WKL/HHKB TKL Frames
Typing Angle: 8.5 Degrees
Front Height: 17.15mm - 22.2mm EKH
Weight: 2.7Kg unbuilt
Mounting:
Custom Silicone Gasket Molds
30A/60A/90A will be included in the kit
PCB:
Split PCB Designed by Gondolindrim
Black FR4
1.6mm thick
Red Solder Mask
Gold pads
No meme-cuts
FPC connector to connect the two segments
JST connector to Unified C5 Daughterboard
VIA Compatible
Solderable Layouts Supported:
LED support at capslock, scroll lock, and numslock
Hotswap Layouts Supported:
Mirrored numpad will be supported with a second included numpad PCB
Renders and Images
Renders by MiKeyDigit
Photos of prototype 1: raw aluminum and stainless steel (note, prototype 1 does not have external engraving, next round will)
PROTOTYPE 2: The spray coating shown here are not part of the GB, they are color samples for future projects. Anodized/PC Samples will be shown when they are complete. But these are the finalized weights/top frames that will be offered in the GB.
PCB Prototypes: These are not black FR4 and do not reflect final layout support
Inspiration
Case:
The main goal of the project was to design a keyboard that could offer southpaw and normal numpad without any extra components. This became challenging because a fullsize keyboard can’t be split into sections that can be mirrored (namely because of the nav cluster). To get around this it was necessary to chop up the top case of the keyboard until the pieces could be rotated and shifted around to accommodate both numpad locations. At the same time, I wanted to keep an optional minimalist aesthetic from the top of the keyboard for those who want a fullsize to use in the office while also allowing a lot of customizability for those who want something a bit more loud. To accompany the name, the exterior weight is engraved with lines meant to replicate the mapped out outline of modern day continents on the supercontinent Pangea.
Mounting:
When designing the case one of the trickiest parts was making it so the numpad cluster and the TKL cluster could be swapped without conflict. I also wanted to replicate a classic top mount sound and feel, however top mount screws would interfere with the TKL/Numpad and top frame pieces. To avoid this, I used gaskets which are short enough to not interfere with the swappable construction while still using a typical top mount plate design. The result is a sound and feel that is similar to top mount while also being customizable with different durometer gaskets.
PCB:
When I originally came up with the idea to make a swappable full size I brought the idea to Gondo to see what could be done. After many ideas from Gondo we settled on splitting the TKL and numpad pcbs and using an FPC connector to connect the two parts. This allows the user to quickly and easily switch locations of the numpad by utilizing the ports on the opposite ends of the PCB even after a build is soldered/assembled. FPC is also a good solution as it is cheap, readily available and very easy to use. We are using a clamshell lock FPC so the connection is very sturdy and secure. It also is a flexible connection so the TKL and numpad clusters are essentially free to move separately from one another.
Availability
Estimated price: $530 USD
MOQ: 50 ~ unlimited
Estimated GB time: August 2024
Estimated GB Fulfillment: 3-5 months after GB closes
Vendors (working on adding more):
US: Bowl Keyboards
EU: Delta Key Co
UK: Prototypist
KR: Swagkeys
TH: Aiglatson
CA: Minokeys
AUS: KeebznCables
CN: VTX
SG: Ilumkb
Kit Contents:
1x Top case
1x Bottom case
1x Top Frame
1x TKL Frame
1x Numpad Frame
1x Internal Weight
1x External Weight
1x Aluminum TKL Plate
1x Aluminum Numpad Plate
1x Solderable or Hotswap PCB
1x C5 Unified Daughterboard + JST to JST cable
1x Carrying case
15x 30a/60a/90a Gaskets
4x Custom molded feet
All Screws/parts/etc for assembly
Addons:
Solder PCB
Hotswap PCB
Alu/CF/PP/PC plates
WK/WKL/HHKB Top frames
Colors:
COLORS IN GB
Decided based on IC results
Bedrock
Top Case: Smokey Polycarbonate
Bottom Case: Dark Gray Anodized Aluminum
Top Frame: Patina'd Copper
TKL Frame: Dark Gray Anodized Aluminum
Numpad Frame: Dark Gray Anodized Aluminum
Inner Weight: Brass
Outerweight: Patina'd Copper
Glacier
Top Case: Frosted Polycarbonate
Bottom Case: Silver Anodized Aluminum
Top Frame: Polished Stainless Steel
TKL Frame: Silver Anodized Aluminum
Numpad Frame: Silver Anodized Aluminum
Inner Weight: Brass
Outerweight: Machine Path Stainless Steel
Earth
Top Case: Brown Anodized Aluminum
Bottom Case: Dark Brown Anodized Aluminum
Top Frame: Dark Brown Anodized Aluminum
TKL Frame: Brown Anodized Aluminum
Numpad Frame: Brown Anodized Aluminum
Inner Weight: Brass
Outerweight: Machine Path Copper
Sediment
Top Case: Gray Anodized Aluminum
Top Frame: Silver Anodized Aluminum
TKL Frame: Gray Anodized Aluminum
Numpad Frame: Gray Anodized Aluminum
Inner Weight: Brass
Colors removed:
Nerve
Prussian Blue
Status and Notes
Status
Testing prototype 1
Changes from Prototype 1:
Added external engraving emulating the modern day continent outlines in Pangea
Removed alignment pins for TKL/Numpad frames
Small adjustments to plate acoustic cuts
Tuned chamfer/fillet size throughout
Next steps:
Order 2nd prototypes/promotional units in decided GB colorways
Confirm vendors
Current Status:
Promotional units are being produced, ETA June
Notes:
Big thank you to the friends that helped this project take shape
Thank you to Gondolindrim, Manu, and Mikeydigit for helping get everything together for this board
and thank you  :thumb: for reading my IC
« Last Edit: Sun, 01 December 2024, 20:53:52 by bowlkeyboards »
Re: [IC] Pangea Full Size
« Reply #1 on: Sat, 13 April 2024, 10:31:45 »
RESERVED ;D
Offline streamline
    • saevus
« Reply #2 on: Sat, 13 April 2024, 10:32:55 »
bowl and goat are both 4 letters. Coincidence? I think now.
Offline keepoto
  • HHKB top for TKL pls
« Reply #3 on: Sat, 13 April 2024, 10:41:34 »
sick af bro
Offline ppatches24
« Reply #4 on: Sat, 13 April 2024, 10:51:59 »
Buy Buy Buy!
This will add nicely to the collection.
Offline ZavaZ86
« Reply #5 on: Sat, 13 April 2024, 10:58:57 »
Only providing US-ISO...
« Reply #6 on: Sat, 13 April 2024, 11:01:49 »
Oops completely just used the wrong PNG, updating right now
Offline Gondolindrim
    • My GitHub
« Reply #7 on: Sat, 13 April 2024, 11:01:55 »
The first PCBs were not supposed to have ISO. Next iteration already has it and we are prototyping soon.
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #8 on: Sat, 13 April 2024, 11:02:19 »
Big boi! GLWIC, I enjoy big boards
« Reply #9 on: Sat, 13 April 2024, 11:32:52 »
updated to add weight to specifications and split left shift to solderable layouts supported image
Offline nFaiz
« Reply #10 on: Sat, 13 April 2024, 12:11:00 »
Another full-size offering lfg
Offline Dumblescore
« Reply #11 on: Sat, 13 April 2024, 13:40:08 »
I LOVE this!  Especially the purple one!  Definitely interested, I’ll start saving
Offline Gtour
  • Just a random guy passionate about keyboards.
« Reply #12 on: Sat, 13 April 2024, 14:34:59 »
I like the design and the Southpaw Numpad. The Prussian Blue color I see in the render to my eyes doesn't match the actual color, please consider changing it so I can finally get a Prussian Blue board ;D
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #13 on: Sat, 13 April 2024, 16:26:35 »
Love it, full sized & southpaw/normal layout swappable! You guys are some mad lads, thanks for bringing this to the community!
Offline iamtragic
« Reply #14 on: Sat, 13 April 2024, 16:30:15 »
What a lovely board.
Any chance for 6.25u normie bottom row?
« Reply #15 on: Sat, 13 April 2024, 16:57:07 »
Unfortunately, due to the internal structure and the moving components it wasn't possible to support 6.25u bottom row
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #16 on: Sat, 13 April 2024, 17:25:30 »
GLWIC
Offline IOVERCALLHISTIOCYTES
« Reply #17 on: Sat, 13 April 2024, 18:55:21 »
Hoping for prototypist
Offline Egypt
  • proof of my existence
« Reply #18 on: Sat, 13 April 2024, 19:06:39 »
yummy project :cool:
Offline clay
  • No foams
« Reply #19 on: Sun, 14 April 2024, 02:18:50 »
Numpad needs more love!
Offline scorcher36
« Reply #20 on: Sun, 14 April 2024, 12:33:06 »
Love me a full size. Like the office gray and espresso. Please add led support or include them for hotswap/solder for usually culprits like caps lock, num lock and etc.
« Reply #21 on: Sun, 14 April 2024, 14:18:17 »
Forgot to say in the specs, but solderable PCB has LED Support at capslock, num lock and scroll lock.  :cool:
« Reply #22 on: Mon, 15 April 2024, 15:42:53 »
Thank you all for the support already, updated post to include more pictures of the prototype as well as mentioned LED supported in PCB section.  :))
Offline LMNPI
  • QAZ is love.
« Reply #23 on: Tue, 16 April 2024, 10:02:34 »
I haven't used a full sized keeb in years - but this is looking great so far.
Big thanks for a southpaw option!
Offline bigmaxnonions
« Reply #24 on: Tue, 16 April 2024, 12:25:24 »
For the exploded layout of the green board, on the left side there are two pieces, the lime green and the silver bezel pieces. I've also noticed all the color renders have two colors for those as well, even the silver/black ones, most notable on the purple and brown ones too. Will it be possible to order those the same color? (IE both green, or both silver, etc.) I like the design and layout, but the mixed colors don't quite do it for me.
« Reply #25 on: Tue, 16 April 2024, 22:20:18 »
Hello, thank you for your interest! I don't think that we will be able to offer different colors of the frames due to SKU limitations. I understand where you are coming from, my reason for doing the multiple colors is there is already a seam there so IMO it looks better to kind of own the seam and have it have multiple colors  :D
Offline longcao1010
« Reply #26 on: Tue, 16 April 2024, 23:43:15 »
The Prussian Blue looks a little bit different from what I searched on Google. Is the rendered picture your final decision or is it going to look different later on?
« Reply #27 on: Wed, 17 April 2024, 20:40:24 »
Edited to show final colors based on IC results as well as list the material/finish for each part for each colorway. Thank you all for the support so far! Next we will be confirming vendors  :cool:
Offline CircuitHero
« Reply #28 on: Thu, 18 April 2024, 21:39:04 »
This is sick. 100% in
Offline Yves W
« Reply #29 on: Thu, 18 April 2024, 21:41:43 »
Oooh, this looks sexy! Although unlikely, any chance of getting a dark alu top case? Never been a fan of polycarb because there's a higher chance of scratches and yellowing due to UV exposure.
Offline JeffreyTaylor
« Reply #30 on: Sat, 20 April 2024, 07:31:44 »
Das Tastaturdesign sieht wirklich hochwertig aus. Einige interessieren sich daneben auch für glorion online spielen. Jeder hat eben unterschiedliche Interessen.
« Last Edit: Sat, 25 July 2026, 07:43:33 by JeffreyTaylor »
« Reply #31 on: Wed, 01 May 2024, 11:21:40 »
Post updated with vendors, GB time/fulfillment schedule estimate and current status.  :))
Offline VXQN
« Reply #32 on: Thu, 02 May 2024, 04:26:33 »
Really cool board and concept, I just wish that there weren't all the seams in the top-case, though of course I understand that they are necessary for the concept to work!
Offline TheGreenLion172
« Reply #33 on: Thu, 09 May 2024, 00:33:27 »
you managed to make what is otherwise a clunky layout into something really elegant looking. great job! :thumb:
Offline Aregs Keyboard
« Reply #34 on: Thu, 09 May 2024, 08:42:58 »
Looks so nice
Offline Cringelord
  • Crack Connoisseur
« Reply #35 on: Mon, 13 May 2024, 01:55:05 »
This is quite nice and will definitely pick one up... chocolatier on Earth will be hot. I see the update for LED support for solder pcbs, would you consider LEDs already on hotswap pcbs? I'm sure folks buying hotswap at extra cost wouldn't mind the added cost for num/scroll/capslock indicators even in cool white.
Nvm I took a closer peep at proto pcb heh.
« Last Edit: Mon, 13 May 2024, 02:38:04 by Cringelord »
« Reply #36 on: Mon, 13 May 2024, 10:34:32 »
the hotswap PCBs will have SMD LED's pre-installed for indicator keys.
Offline Cringelord
  • Crack Connoisseur
« Reply #37 on: Tue, 14 May 2024, 01:27:03 »
Bless Gondo's heart
Offline Aethelberht
« Reply #38 on: Fri, 24 May 2024, 22:21:41 »
This will be my first bowl's keeb for sure
I'm better than all of you combined.
« Reply #39 on: Wed, 17 July 2024, 20:28:03 »
 :p Hello Everyone, I have added new images that show the weights that will be offered in the GB. GB period is planned for September!
Offline TyPo.mk
« Reply #40 on: Fri, 30 August 2024, 18:47:51 »
My wife said I have enough good boy points to buy this keyboard, thank you Mr bowl
Offline pseudonym
« Reply #41 on: Tue, 24 September 2024, 15:40:28 »
I don't understand how the different layouts work. Are these just blockers that can be moved to get HHKB or WKL layout?
Offline vhaarr
« Reply #42 on: Wed, 25 September 2024, 00:25:33 »
You change the green frames in the lower left in this render, one for the numpad and one for the rest:
So yeah, it's a large blocker frame.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
