Author Topic: [IC] BSUN Strawberry Cheesecake Switch R2  (Read 22639 times)
Offline kentdo10
« on: Mon, 15 April 2024, 06:41:51 »
Background Introduction
Hello everyone, the Strawberry Cheesecake Tactile switch is back for another round. This time, several improvements were implemented to provide a better typing experience for everyone.
Switch Information
Not just keyboard, but I also share a great passion for food. My favourite dessert was Strawberry Cheesecake. Also, as a tactile fan, I love the Holy Panda. However, my fingers are weak and I can't type on them for long.
Hence, the strawberry Cheesecake tactile switch is the sweet child born from the love for both Cheesecake and Holy Panda. It is nothing fancy or extraordinary. It is just me trying to improve the old recipe to make it better suited to myself.
Switch specification:
Top Housing: POK. Patone 11-0510 TPG
Bottom Housing: POK. Pantone 4026C
Stem: LY. Pantone 19-1763 TPG
Spring:Single-stage 22mm KOS 60g.
Factory lube: Yes. A thin layer of factory lubrication will be applied to the stem rails, housing sliders, and stem legs. Dry powder lubrication for the springs.
Travel distance: 3.8mm
Manufacturer: BSUN
Pricing: Available in-stock at worldwide vendors. 0.42usd/switch (in-stock pricing)
Force Graph
To be updated
Difference compared to R1
We used a different mould compared to R1. This leads to quite a few improvements for the switches in overall.
- First, the fitment issues were rectified so the switches won't be too tight on some plates and boards.
- Secondly, less leaf ping, which results in cleaner sounds
- Thirdly, a different type of spring is used to reduce spring noise
- Lastly, the amount of lubrication was adjusted as I noticed an uneven (and inconsistent) amount of lubrication on the housing and rails.
Switch photos:
I recycled the R1 photos since R2 will be using the same colours and pretty much will look the same as R2
Vendors
OCE and ROW: Toro Studio
US: MechanicalKeyboards
CA: Unikeys
UK: Prototypist
SG: ktechs
MY: Mecha
JP: Yushakobo
INDIA: Neo Macro
VN: The Keeb of Lesser
Sound test
Snake60 R2 - Aluminum Plate - O-ring mount
Parabolica - Aluminum Plate - Tadpole mount
Full Playlist available HERE
More sound tests will be updated soon
To-do list:
- Looking for more vendors (if anyone interested, please send me a DM)
- Sending out prototypes to vendors and content creators to collect feedback
- Entering production
- Finalising prices and launch details
I am very thankful that you have spent the time to read till the end of the IC.
« Last Edit: Wed, 02 July 2025, 23:42:58 by kentdo10 »
Offline kentdo10
Re: [IC] BSUN Strawberry Cheesecake Switch
« Reply #1 on: Mon, 15 April 2024, 06:58:06 »
reserved
Offline sauvieng
« Reply #2 on: Mon, 15 April 2024, 07:05:49 »
mmm i love chescake very gud
Offline keepoto
  • HHKB top for TKL pls
« Reply #3 on: Mon, 15 April 2024, 08:01:21 »
nice hands
Offline vhaarr
« Reply #4 on: Mon, 15 April 2024, 08:49:38 »
Please excuse me being an idiot and unable to read the force graph; what's the pre-travel before tactility bump and/or activation?
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline irithyll
« Reply #5 on: Mon, 15 April 2024, 17:56:26 »
I need these.
Offline kentdo10
« Reply #6 on: Tue, 16 April 2024, 02:43:53 »
There is pretty much no pre-travel for my switch. So you will go straight to the prominent, round bump. Then it will be a little bit of post-travel and bottom out (due to longer pole)
Offline kentdo10
« Reply #7 on: Tue, 16 April 2024, 02:44:18 »
Offline vhaarr
« Reply #8 on: Wed, 17 April 2024, 01:03:16 »
Right, that's what I thought and it really confused me LOL
I'm used to topre, which behaves the same way, so I am really looking forward to trying these
Thank you!
Offline EUGeniusX1
« Reply #9 on: Wed, 17 April 2024, 13:42:53 »
Offline kentdo10
« Reply #10 on: Sat, 20 April 2024, 22:36:17 »
Quick update on the project:
- New sound test added.
- All prototypes shipped to vendors.
- Got some content creators on board. Prototypes are also being shipped to them.
« Last Edit: Sat, 20 April 2024, 22:39:52 by kentdo10 »
Offline vhaarr
« Reply #11 on: Mon, 22 April 2024, 05:08:14 »
These won't be available at unikeyboards right?
Offline kentdo10
« Reply #12 on: Mon, 22 April 2024, 06:03:56 »
Hey mate, It won't be available at UniKeyboards. The vendor list is above and it is finalised. I feel that it should cover most regions.
Offline vhaarr
« Reply #13 on: Mon, 22 April 2024, 07:34:43 »
Yes, that's not what I asked, I'm just going to put in an order there and wanted to know if I should wait a bit.
My region is definitely covered.
Offline clik_clak
« Reply #14 on: Mon, 22 April 2024, 11:16:02 »
These are in IC on Unikey's Discord right now. Unless something changed very recently, they should be available from Uni sometime in the future. When that is though, who knows.
Offline kentdo10
« Reply #15 on: Tue, 23 April 2024, 02:50:43 »
Hello, can you link me to the IC on the UniKey's Discord? only see the IC of Strawberry Shortcake switch which is made by HMX. This one is Strawberry Cheesecake made by BSUN.
Offline h3lli0n
    • oliversphotoblog.com
« Reply #16 on: Wed, 24 April 2024, 11:31:31 »
Offline kentdo10
« Reply #17 on: Wed, 01 May 2024, 19:38:19 »
Minor update:
- Prototypes arrived at all vendors. They are currently testing it (Positive reviews from vendors who have tested it).
- We will likely go with a very short pre-order (probably 2 weeks) and finalize the quantity with BSUN.
- Prototypes are on the way to some content creators so expect content to go live in a couple of weeks.
Offline kentdo10
« Reply #18 on: Fri, 03 May 2024, 21:47:56 »
The new sound test with Cycle7 is live
Offline Bokehhbob
« Reply #19 on: Wed, 08 May 2024, 11:59:22 »
Another sound test.
Offline kentdo10
« Reply #20 on: Sat, 11 May 2024, 06:51:56 »
Project update:
- Change from In-stock to Pre-Order based on IC responds.
- Pre-order going live on May 20th. Last for 2 weeks.
- Pre-order price is down to 0.4usd from 0.5usd (exclusive of regional tax)
- In-stock extra will still be 0.5usd (exclusive of regional tax).
- Another sound test made with Kohaku
Offline kentdo10
« Reply #21 on: Mon, 13 May 2024, 07:52:27 »
Review from BokehhBob is live!!!
Offline kentdo10
Re: [IC] BSUN Strawberry Cheesecake Switch - Pre-Order is LIVE!!!
« Reply #23 on: Fri, 24 May 2024, 21:08:18 »
Review from Keeb Taro
Offline reidweb
« Reply #24 on: Tue, 22 April 2025, 13:25:09 »
In love with these switches; would you ever consider an R2? I need to buy like another 400 lol
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #25 on: Tue, 22 April 2025, 13:26:55 »
Agreed! R2 please! I am running out of these switches!
Offline kentdo10
« Reply #26 on: Wed, 23 April 2025, 02:28:59 »
R2 prototypes just arrived. I will test them soon haha but from a random pick, these are much better than the R1. Join my discord to be updated on the R2 progress.
Offline AerosolFNTM
« Reply #27 on: Wed, 30 April 2025, 08:23:04 »
I have R1 and loved them, looking forward to picking up some of the R2
Offline kentdo10
« Reply #28 on: Wed, 30 April 2025, 20:26:52 »
I have received the R2 prototypes and will be testing them soon
Offline Metakeebs
    • metakeebs
« Reply #29 on: Fri, 02 May 2025, 06:26:57 »
I purchased some r1 cheesecake switches and feel so good. Looking forward to picking up more of the R2
Offline kentdo10
« Reply #30 on: Sun, 04 May 2025, 04:56:09 »
Thanks for your support. I have just tried the R2 and I am hyped for it. They are much better than the R1 and more clacky to my liking.
Offline aumz.work
« Reply #31 on: Fri, 09 May 2025, 02:52:11 »
thats make me hungry
Offline AerosolFNTM
« Reply #32 on: Fri, 09 May 2025, 21:55:48 »
Nice! A more clacky version of this switch would be great. Hopefully the bottom housing tolerances have been addressed, because my only gripe with R1 was that the larger bottom housings made the unusable is some of my plates. If this has been addressed on this run then I will definitely be picking of a few hundred.
Offline Metakeebs
    • metakeebs
« Reply #33 on: Thu, 15 May 2025, 09:48:04 »
Is there still a possibility that we might have a Chinese vendor?
Offline kentdo10
« Reply #34 on: Fri, 16 May 2025, 02:27:14 »
I am trying to find one but cant find any so far
Offline kentdo10
Re: [IC] BSUN Strawberry Cheesecake Switch R2
« Reply #35 on: Mon, 19 May 2025, 04:51:33 »
R2 IC is live. YES, I recycled the R1 IC since I am lazy to make a new one.
TLDR:
- Spec is confirmed
- A new sound test is made (more to come)
- Some improvements compared to R1 (please check out the IC for full details).
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #36 on: Mon, 19 May 2025, 07:46:39 »
How's BSUN in terms of switch leg thickness? Will these be good candidates for plateless builds (i.e. don't fall out when you turn the pcb over)?
Offline kentdo10
« Reply #37 on: Mon, 19 May 2025, 08:27:31 »
They are decent for me in one of my plateless builds. At least they work fine for me, but my PCB was relatively new, and the sockets aren't loosening up yet. I do not recommend using these with hotswap plateless and half plate tbh
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #38 on: Mon, 19 May 2025, 08:45:20 »
I need these yesterday 🤣
Offline kentdo10
« Reply #39 on: Thu, 22 May 2025, 20:44:50 »
TLDR:
- Switch back to the R1 loved material
- New mould that fixed R1 issues
- In stock
- Better pricing
- A new prototype to reflect the change is being ordered
- Supposed to be R2 will be run as an entirely new switch
Offline WarlordGorguts
« Reply #40 on: Fri, 06 June 2025, 08:12:55 »
Any updates?
Offline kentdo10
« Reply #41 on: Sat, 07 June 2025, 20:26:41 »
Any updates?
waiting on the new prototypes but should be finished and shipped to me next week.
Offline kentdo10
« Reply #42 on: Wed, 02 July 2025, 23:35:17 »
- Sound Tests updated. More to come
- Pricing is updated.
- Vendor list updated. Will be available in-stock at multiple vendors worldwide
