Author Topic: [IC] Penguin 1.0, 8k TKL (big spooky update)  (Read 12757 times)
Offline PPKPenguinParty
« on: Tue, 23 April 2024, 18:23:13 »
Penguin 1.0
Keyboard bestie back at it again with updates :3
I designed the Penguin 1.0 with one thing in mind, to create a nice looking top mount 8k keyboard with an internal weight and a unique colorway.
SPECIFICATIONS
Alu Top, Alu Bottom, Brass Weight
Second proto was 2.3 kg built, third proto is going to have a redesigned internal weight.
8k F12 TKL
Top Mount
5.5 degree angle
16 mm front height
22.9 mm EKH
Compatible with FUYU PCB and Penguin PCB
PENGUIN PCB
For the Penguin keyboard, I commissioned a custom pcb. This pcb is a fork of the FUYU without the rgb but with indicator led support and 10u space bar support. It also has the penguin on it.
SALE DETAILS
This board in group buy will be offered in WKL, and possible 7u HHKB depending on how it looks. You will be free to pick colors for top and bottom case, offering DDS-A, Silver, and a third color to be decided on before the group buy.
Initially I was shooting for 50 moq, however due to the switch to dds as manu I may need to shoot for something higher to make my target price of $350. Due to this fact, I will need to find vendors since I don't think I can properly run a larger scale group buy by myself. This may lead to a slightly higher purchase price, however it will give buyers a bit more security.
I will be running a private GB for a WK Penguin with a 10 unit cap for feedback, join the server for more information.
2nd PROTO PICS
Join my discord for more info and updates! https://discord.gg/rZ7CTGyuJG
Pretty soon I'm going to reach out to streamers to do some build, so expect some more content on the board in the relatively near future.
Thanks for reading, hopefully you find this project interesting!  :thumb:
« Last Edit: Sat, 05 October 2024, 11:15:00 by PPKPenguinParty »
Offline Rafa_n
Re: [IC] Penguin 1.0, 8k TKL
« Reply #1 on: Tue, 23 April 2024, 18:32:44 »
Best weight engraving I have ever seen
Offline LMarci
« Reply #2 on: Tue, 23 April 2024, 18:40:14 »
Cool project, might be worth including some plate pics/renders but otherwise this is solid :thumb:
Offline CoolPenguin1
« Reply #3 on: Tue, 23 April 2024, 21:04:07 »
I approve.
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #4 on: Wed, 24 April 2024, 00:08:12 »
Big fan of this "back to basics" approach!
Offline HubertThemad
  • * St. Jude Supporter
« Reply #5 on: Wed, 24 April 2024, 10:08:14 »
I approve.
Eyyy, was hoping you'd see this and comment!
OP, GLWIC, solid-looking project in my opinion.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #6 on: Wed, 24 April 2024, 11:27:56 »
interesting
Offline Bennettb
« Reply #7 on: Sat, 27 April 2024, 00:01:18 »
I like the reverse two-tone! I feel like you don't see that very much.
Offline norb
« Reply #8 on: Sat, 27 April 2024, 10:52:06 »
it should not be hidden on the inside.
Offline HowdyDoot
« Reply #9 on: Tue, 21 May 2024, 16:09:47 »
The discord link is expired, anyway to get an updated one?
Offline Soulcook
« Reply #10 on: Thu, 23 May 2024, 21:56:42 »
Looks amazing, love the 2 tone and the interesting navigation cluster. That recessed front lip also goes incredibly hard
Offline Soulcook
« Reply #11 on: Thu, 23 May 2024, 21:58:40 »
Also, idk if its me but the discord link doesnt work
« Reply #12 on: Fri, 24 May 2024, 20:54:06 »
I fixed the server invite link: https://discord.gg/mrQe6e6K
Offline mr_foggy
  • neue = nope
« Reply #13 on: Sat, 01 June 2024, 08:23:24 »
invalid :( I like the project a lot, I'd like to get on board
« Reply #14 on: Mon, 03 June 2024, 11:07:22 »
I fixed it again, sorry I'm stupid and dumb
Re: [IC] Penguin 1.0, 8k TKL (big spooky update)
« Reply #15 on: Thu, 24 October 2024, 18:27:55 »
Quick tiny update, I recorded a sound test!
