Author Topic: [IC] Milkyway Lilith R3 doubleshot product debut  (Read 8170 times)
Offline MILKYWAY KEYS
  • PBT keycap manufacturer
    • MilkywayKeys
« on: Mon, 20 May 2024, 03:25:32 »
Milkyway Lilith R3
Hello, this is MWKEYS, today we bring you Milkyway's first dual-color keycap - MW Lilith R3.
   In the past two years we energetic order surge, deep cooperation Vendors bankruptcy, order decay a series of tribulations, but this did not break us, in the past year, we developed dual-color products, and optimized our heat sublimation products. This allows us to have a better guarantee of the quality of our products.
IC
BASE+NOV
Translucent Alpha
Norde Kit
Num Kit
40S Kit
Space Kit
Lamp Keycaps+lid keycaps
REBDER
Vendors
TBA
GB Dates
June 10-20, 2024
Contact
Instagram: @milkywaykeys
Discord Server: Milkyway Keys
« Last Edit: Sun, 26 May 2024, 22:09:36 by MILKYWAY KEYS »
Offline mr_foggy
  • neue = nope
Re: [IC] Milkyway Lilith R3 two-color product debut
« Reply #1 on: Mon, 20 May 2024, 03:31:14 »
alice bars child kit please. alpha colored (blue).
please.
Offline vhaarr
« Reply #2 on: Mon, 20 May 2024, 09:06:20 »
What do you mean by "Milkyway's first dual-color keycap"?
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
« Reply #3 on: Mon, 20 May 2024, 10:38:05 »
Add mod-color arrows, enter, esc please
Edit: What is “EVABACING” on the 1.5u novelties
« Last Edit: Mon, 20 May 2024, 16:03:39 by GrumioThaSpoonGod »
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #4 on: Mon, 20 May 2024, 15:21:39 »
I'm assuming they mean their first double shot set, but who knows when you're reading an IC that spells render rebder....... :p
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #5 on: Mon, 20 May 2024, 17:42:26 »
There's a duplicate GB thread - https://geekhack.org/index.php?topic=123005
Offline aicyborg
« Reply #6 on: Mon, 20 May 2024, 17:55:18 »
Your base kit has R3 @' and ~# in base but none of the rest of the keys for UK-ISO. They can both be removed because they are duplicated in the Nordeuk kit, and the base kit also includes R3 1u pipe which is all you need for physical ISO coverage.
    • MilkywayKeys
« Reply #7 on: Mon, 20 May 2024, 20:29:08 »
please.
I'll add it. Thanks for the heads up.
    • MilkywayKeys
« Reply #8 on: Mon, 20 May 2024, 20:30:21 »
Duplicates have been locked,thanks!
    • MilkywayKeys
« Reply #9 on: Mon, 20 May 2024, 20:33:06 »
Means our first two-color keycaps, since we used to only do PBT heat-sublimation keycaps!
Offline Sashemi
« Reply #10 on: Tue, 21 May 2024, 01:04:32 »
Do you mean doubleshot?
Offline KeebRehab
« Reply #11 on: Tue, 21 May 2024, 02:29:06 »
MW, I highly recommend you hire a human English translator or English-speaking PR representative. It will help you a lot in terms of marketing and sales.
    • MilkywayKeys
« Reply #12 on: Tue, 21 May 2024, 03:23:20 »
Thanks for the suggestion, we'll get in touch with the relevant people quickly! :-X
    • MilkywayKeys
« Reply #13 on: Tue, 21 May 2024, 03:25:32 »
YES
Offline vhaarr
Re: [IC] Milkyway Lilith R3 doubleshot product debut
« Reply #14 on: Tue, 21 May 2024, 14:45:13 »
YES
You really, really need to hire someone who can speak and write english, and who knows keyboards, to edit the original IC post.
This is very confusing.
Offline dvorcol
« Reply #15 on: Tue, 21 May 2024, 15:03:43 »
YES
Already recommended and in the works:
    • MilkywayKeys
« Reply #16 on: Sun, 26 May 2024, 22:13:17 »
Corrected errors in the base where "F", "J", and "B" did not have Japanese root characters. Added R1~ reverse colors and included a 6U space.
Offline konstantin
  • Formerly constexpr
« Reply #17 on: Wed, 29 May 2024, 08:25:21 »
BASE+NOV
Num Kit
Norde Kit
I'm noticing some discrepancies in the kitting. Here are a few suggestions to correct them:
There's a duplicate alpha-colored (blue) R2 1.5u \|む key in the base kit. One of them should be mod-colored (white).
The 1u Backspace key should be mod-colored (white).
The 1u Shift key should be mod-colored (white).
The F13 key should be mod-colored (white).
A second R4 1u Alt key should be added for full compatibility with HHKB/Mac bottom rows (1u Alt – 1.5u Super – 7u space – 1.5u Super – 1u Alt). However, R4 1u Ctrl should stay at one copy, as it currently is.
The R1 PgDn, End keys should be moved to the numpad kit, seeing as they are only used in layouts that require a numpad (1800/CP/96-key).
Additionally, a R1 1u = key should be added to the numpad kit.
The R3 '@, #~ keys should be removed from the base kit because: 1) they're missing JP sublegends; 2) ISO-UK keys are generally not used in sets with JP sublegends.
Similarly, the whole NorDeUK kit should probably be scrapped entirely due to its general incompatibility with JP sublegends.
On the 0)わを key, the legend is too small; it should be the same size as the legend below it (unlike ぁ, ぃ, ぅ, ぇ, ぉ etc., there is no small を kana).
I'm unsure what the purpose of having only 7×1u relegendable keys + 1×2u relegendable Backspace is. Could you explain?
« Last Edit: Wed, 29 May 2024, 08:43:12 by konstantin »
