Author Topic: [GB] Petrichor by AKB - GB live June 14th - July 15th!  (Read 10158 times)
Offline Alchemist Keyboards
    • Alchemist Keyboards
« on: Mon, 03 June 2024, 13:32:07 »
Petrichor   by AKB
FRL 1800
GB to run from Friday, 14th June to Monday, 15th July.
Starting from just $230! (+$10 for e-coat, +$5 for hotswap)
The idea with Petrichor was always to keep it simple. Simple mounting, implemented well. Simple design, but enough
to retain its own identity. No external weight, but the board still has weight to it. Every feature serves a purpose.
There isn’t too much of a story to tell for this board, but this to me is everything I need and want in a keyboard, and
I’ve been using a Petrichor as my daily driver since 2020. Hopefully that is enough to convince you that it’s worth
your consideration.
Links:
AKB Website
AKB Discord
Interest check thread
Lightning's build stream VOD
Alexotos' build stream VOD
Specs:
  • 8° typing angle
  • 6063 aluminium top/bottom case
  • 20mm effective front height (with bumpons)
  • ~1.7kg (3.75lbs) built weight
Key Features:
  • Standard & HHKB-ish layouts
  • Anodised & E-coated options
  • Gasket mounted
  • QMK and VIA-compatible PCBs (solder & hotswap)
  • RGB LED indicator daughterboard
  • USB 2.0 passthrough hub
  • OG-style product sticker on bottom a la OGR
  • Internal brass weight to cover the hub parts
  • Bold, pronounced seam
  • Manufactured by Hongtu
Renders:
Onyx
Verdant
Woad
Fool's Gold
E-Beige
Rubedo
Luna
Dolch
Dolch side view
Case Layout Support:
Two tops will be available - one regular and one “HHKB” which covers the corner 1.25u keys.
Regular case compatibility:
  • 6u (center & off-center), 6.25u & 7u bottom row compatibility
  • Full/split backspace
  • ANSI/ISO
  • Full/stepped caps
  • Full/split numpad mods
  • Split/full numpad enter
HHKB case compatibility:
  • Fixed 6u bottom row
  • ANSI/ISO
  • Full/stepped caps
PCB Layout Support:
Solder PCB compatibility: (same as regular case)
  • ANSI/ISO
  • Full/stepped caps
Hotswap PCB compatibility
  • 6u (centered only) & 6.25u bottom rows, compatible with both case tops
  • Fixed ANSI
  • Full/stepped caps
Kit contents:
  • 6063 Aluminium case
  • 5052 aluminium plate
  • Solder or hotswap PCB
  • USB-C daughterboard
  • USB 2.0 hub board
  • LED indicator daughterboard
  • JST/Molex cables
  • Gaskets (12 large, 4 small)
  • AKB feet (4)
  • Stickers
  • 6u stab wire
  • Hard carry case
  • Microfiber cloth
  • Screws and hardware for assembly
Group buy information:
  • Unlimited GB
  • GB to run from Friday, 14th June to Monday, 15th July.
  • Price: starting from $230 (+$10 for e-coat, +$5 for hotswap)
  • Shipping Q1 2025
Plate addons available:
  • FR4 - $25
  • Carbon Fibre (half) - $45
  • 5052 Aluminium - $40
  • Polycarbonate - $40
PCB addons available:
  • Solderable PCB - $45
  • Hotswap PCB - $50
  • Daughterboard Kit (USB hub, USBC DB, LED DB + all cables) - $32
Other addons available:
  • Foam kit - $26
  • Extra gaskets - $6
  • Extra AKB feet (16) - $4
  • Extra tops in both WK and HHKB - $75 ano/$80 e-beige
Vendors:
  • US: CannonKeys
  • UK: Proto[Typist]
  • EU: Oblotzky
  • KR: Swagkeys
  • OCE: KeebzNCables
  • SG: iLumkb
  • IN: Neo Macro
  • ME: SandKeys
  • LATAM: Latamkeys
« Last Edit: Tue, 08 April 2025, 12:57:27 by Alchemist Keyboards »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [GB] Petrichor by AKB - GB live June 14th - July 15th!
« Reply #1 on: Tue, 04 June 2024, 16:35:46 »
reserved
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Wed, 05 June 2024, 10:14:03 »
Can't wait for this! Still trying to decide what color but I'm definitely grabbing a Petrichor for my collection! Great work as always from AKB!
Offline jpro
« Reply #3 on: Thu, 06 June 2024, 12:08:58 »
One can never have too much AKB. I'm here for this, let's gooooooo
Offline Chippy
  • sus chef
« Reply #4 on: Thu, 06 June 2024, 12:33:02 »
pogging so hard
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Adqam64
« Reply #5 on: Thu, 06 June 2024, 18:42:30 »
Very excited for this GB!
« Reply #6 on: Fri, 07 June 2024, 14:37:52 »
Updated with kit contents and add-on pricing :thumb:
One week til launch!
Offline halfling_barista
« Reply #7 on: Fri, 07 June 2024, 22:00:39 »
The more I see of this keyboard, the more impressed I am at $230, and I started impressed.
Offline :)Owen
« Reply #8 on: Fri, 07 June 2024, 22:16:07 »
This price is definitely a great value
