Author Topic: QTRONIX SCORPIUS 305 (Controller IC)  (Read 5256 times)
Offline LocalF9
« on: Sun, 09 June 2024, 15:50:59 »
Hello,
Two years ago, the controller IC on my QTRONIX board failed. I plan to replace it with a Teensy++ 2.0. After mapping out the PCB on an Excel spreadsheet in my spare time, I’ve finally completed the task. Before proceeding further, I wanted to check if anyone here has undertaken a similar project and might have some advice or suggestions. I’ve used QMK a few times and believe it’s the best option for this project.
Additionally, if anyone knows where I could find a keycap set that includes a BA Enter key, I’d greatly appreciate the help. Finding one has been quite a challenge.
Thank you!
308338-0
308340-1
