Author Topic: [OTD] New OTD wiki  (Read 8680 times)
Offline zlobin356
  • Hi! My name is zlobin, im a big korean keebs fan!
[OTD] New OTD wiki
« on: Mon, 10 June 2024, 06:05:11 »
Hi! In this thread i will try to cover all OTD keyboards. All info and stuff will be covered, with OTD lore itself. Two posts in one day.
List of boards to cover:
1)OTD 356MF
2)OTD 356AMF
3)OTD 356ES
4)OTD 356L
5)OTD 356LS
6)OTD 356N MK.1
7)OTD 356C
8)OTD 356CL
9)OTD 356F
10)OTD 356CL DGE
11)OTD 356N MK.2
12)OTD 356A
13)OTD 356W
14)OTD 356mini V1
15)OTD 356mini V2
16)OTD 356pad
17)OTD The Cheat
18)OTD Koala & Brass Koala
19)OTD 356CLS
20)OTD 356.2
21)OTD 456GT
22)OTD 360c
23)OTD MXmini
24)OTD SSS
25)OTD LIMKB
26)OTD Cyclopia
27)OTD 2017
28)Cat Pad
Right now i will start with how OTD started. The OTD was created in 2008 named ohbang.net, after a year of testing the website was renamed to OTD.kr. First board for groupbuy (356L) was selled through KBDmania, but during it Eungsam had disagreements with KBDmania administraiton due to absurd reasons of taked down gb posts, while friends of KBDmania staff freely posted everything, so he decided to make new community. OTD covered not only keyboards, also bicycles, mechanical pens, photography, gaming and other lifestyle things. The main members of OTD creating team were: Eungsam, Sir, Jeany, Aqua,DSPman, Sad Nova and Korellas.
With time community growned, in 2014 after 360C gb eungsam got noticed by TAX office, someone whistleblowed on eungsam, so TAX office made research, they called eungsam and started investigation. Eungsam needed to prepare documents about all of his purchases/sells so he had to cancel all GB's on OTD. also korean goverment haves act of radio wave that covers keyboards too. OTD keyboards were not registred and licensed so they couldnt be selled.
OTD members:
Eungsam:
« Last Edit: Fri, 13 September 2024, 02:22:15 by zlobin356 »
Neo80/BSUN X ZX Solutions SuchANiceSwtich/DCS Dark Sky
Offline zlobin356
Re: [OTD] New OTD wiki
« Reply #1 on: Mon, 10 June 2024, 06:06:44 »
OTD 356MF (A.K.A 356L S/N 001, Eungsam Tenkeyless) - First prototype of 356L, MF means Metal Frame, The board is fully in raw aluminium and haves brushed finish. The board is predecessor of 356AMF. Haves strange mounting system and FR4(?) green PCB. I See white silkscreen of switch footprints, strange mounting points on pcb, strange stabilizer cutouts, also screwholes (?) on sides of plate. Made in 2007.03.04. Standart F12 Layout. Came before DK Saver,Built with Cherry G80-3491 Blacks and G80-3491 keycaps. The point to make it, was that Eungsam wanted to make Cherry version of Realforce TKL keyboard. Was meant to be first TKL MX keyboard with variable weight springs. The 356 in OTD naming is length of plate on their first keyboard
Material: German aluminium
Plate Material: Stainless Steel (?) Aluminium (?)
PCB: FR4 (?) with Cherry G80-3491 Controller
Connectivity: USB, PS/2
Colors: RAW
Plates: SS (?)
Mount: ?
Quantity: ? (probably 1)
Source: http://www.kbdmania.net/xe/photo/565232 , http://www.kbdmania.net/xe/photo/565863 , http://www.kbdmania.net/xe/photo/566246
Pics by Eungsam [OTD] :thumb:
« Last Edit: Fri, 13 September 2024, 02:00:29 by zlobin356 »
Offline zlobin356
« Reply #2 on: Mon, 10 June 2024, 06:06:51 »
OTD 356AMF (A.K.A 356L AMF V.6.0) - Anodized version of 356MF, Haves smooth finish and black anodization. Probably uses sandwich mount.  Built with vintage blacks and Cherry G80-3491 keycaps.
Material: German Aluminium
Plate: SS (?)
Colors: Black
Mount: ?
Quantity: ? (probably one)
Source: http://www.kbdmania.net/xe/photo/566246
Photos by: Eungsam (OTD)
« Last Edit: Tue, 20 August 2024, 10:53:35 by zlobin356 »
Offline zlobin356
« Reply #3 on: Mon, 10 June 2024, 17:01:45 »
OTD 356ES - Engineering samples of 356L, In silver or black ano, haves stainless steel (?) plate and polycarbonate one. not sure if PC plate was included in 356L. haves sketchup of southpaw version, but it was probably never finished. haves also black plate with 356-ES engraving. only 5 made. Top Mount. probably was built to check how it works with finished pcb and plate
Mount: Top
PCB: FR4 (?) white with Cherry G80-3491 controller
Quantity: 5
Colors: Silver, Black
Plates: PC, SS
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=2520 , http://www.kbdmania.net/xe/index.php?mid=photo&search_target=nick_name&search_keyword=%EC%97%A0%EC%82%BC%EC%95%84%EB%B9%A0&document_srl=571081 , http://www.kbdmania.net/xe/photo/568208
« Last Edit: Tue, 20 August 2024, 10:55:23 by zlobin356 »
Offline zlobin356
« Reply #4 on: Mon, 10 June 2024, 17:18:35 »
OTD 356L - First GB board. Was run in 2008 after DK saver, Uses top mount, made out of german aluminium, L means optimized for linear switches, only black color, one lost during shipping, 60 units, run through KBDmania, Uses FR4 (?) white pcb adapted to work with Cherry G80-3491 controller, made by KlKlKl from DK. Case haves special cutout for controller, PCB Supports LED.  In GB you will receive: Case, PCB, Wrist Rest, Switch Stickers. Also there was brushed version, made after 23'rd unit didnt pass QC (due to rust).
Mount: Top
PCB: FR4 white with Cherry G80-3491 controller by KlKlKl
Quantity: 61 (1 LOST)
Colors: Black, Silver
Plates: SS, PC
Source: https://geekhack.org/index.php?topic=99876.0, http://www.kbdmania.net/xe/photo/565232 , http://www.kbdmania.net/xe/photo/572194
Photos by: Eungsam (OTD), Notflipperdan420
« Last Edit: Fri, 13 September 2024, 01:59:21 by zlobin356 »
Offline wigol2506
    • Instagram
« Reply #5 on: Mon, 10 June 2024, 17:52:03 »
I would suggest providing sources / citation of your information. I don't think purely describing pictures you have found online is enough to displace the existing "otd wiki". Also to leave out any information if you're uncertain, the alarming number of (?) does not invoke much confidence in being an informative source and inadvertently create more confusion / doubt.
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline zlobin356
« Reply #6 on: Wed, 12 June 2024, 09:58:20 »
Added sources! :thumb:
Offline zlobin356
« Reply #7 on: Wed, 12 June 2024, 10:18:36 »
OTD 356LS - Steel version of 356L. Eungsam wanted to test, how Stainless Steel case will change keyfeel. The board features 2 different finishes (Polished and Raydent), Top mount, haves custom CEM-3 PCB by KlKlKl (One of DK Saver makers), Raydent is special surface treatment, to make an alloyed textrue on metallic materials with use of electroplating. Weights 6kg
Materials: Stainless Steel
Mount: Top
PCB: CEM-3 green
Quantity: 2
Colors: Black, Polished
Connectivity: PS/2
Plates: SS
Source: http://www.kbdmania.net/xe/photo/572194, https://www.kbdarchive.org/otd_archive/album_post.php?post_id=60401
« Last Edit: Tue, 20 August 2024, 10:56:36 by zlobin356 »
Offline zlobin356
« Reply #8 on: Wed, 12 June 2024, 10:49:42 »
OTD 356n mk.1 - Second GB board, optimized for tactile switches. (n= non click), uses custom CEM-3 pcb by klklkl (DK) with Holtec 628A controller, still WK ansi layout, made of Aluminium. Haves deepning in bottom, to provide more unique sound with tactile switches. Case still uses cone feet structure with more rounded design and top mount, keyboard haves rubber o-ring between pcb and plate to provide bouncier typing feel and better sound. Case features unibody seamless design like on modern boards.
Materials: Aluminium
Mount: Top with Oring between plate and PCB
PCB: KlKlKl CEM-3 Red w/ Holtec 628A
Quantity: +-30 (2 chrome, rest is silver)
Colors: Silver, Chrome
Connectivity: PS/2
Plates: Half Polycarbonate, Aluminium
Sources: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=9873 , https://deskthority.net/viewtopic.php?t=13315 , https://blog.naver.com/elsuoo/80055909673 , https://geekhack.org/index.php?topic=99876.0
Photos by:  이동진 (OTD) , Eungsam (OTD), Firebolt1914, elsuoo.
« Last Edit: Tue, 20 August 2024, 10:57:08 by zlobin356 »
Offline zlobin356
« Reply #9 on: Wed, 12 June 2024, 17:14:51 »
OTD 356c - The pre-production version of 356CL, like 356es. There is +-10 units (Raw without weight, Brushed without weight, Raw with place for weight, bright with copper polished, bright with brass polished, dark gunmetal with copper sandblasted weight, raw with copper weight, gunmetal with engraving, slightly brighter than gunmetal with engraving, one with painted engraving) The first ever custom keyboard with angeled design. Project that taked long time and big money to finish it.
Materials: Aluminium, Brass, Copper
PCB: Aqua CEM-3 Green w/ Holtec 628A
Quantity: +-10
Colors: Raw, Bright Silver, Gunmetal, Dark Gunmetal
Connectivity: PS/2
Plates: Aluminium
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=3932
« Last Edit: Tue, 20 August 2024, 10:57:37 by zlobin356 »
Offline zlobin356
« Reply #10 on: Thu, 13 June 2024, 16:02:26 »
OTD 356CL (A.K.A (샘플) Samcle) - Finished version of 356C. Haves internal brass weight, angeled design, this board one of the most valuable pieces of keyboard history, that made the footprints of modern keyboard. Haves 2 protos, Dark Gray one and Dark Gunmetal. The main problem during production was anodizing, some boards had problems like streaking or tiger stripes. GB version offer Gunmetal Silver and Black colors. The keyboard units with ano issues were re-anodized to dark gray color, they dont have brass weight and use cone feets. Keyboard uses top mount with o-ring between pcb and plate. PCB uses Holtec 628A controller, PS/2 connectivity, PCB uses FR4 material (eungsam couldnt use CEM-3 in this board, CEM-3 ~1.0T pcb was in DGE) comes with full red aluminium plate or half pc.
PCB: Aqua FR4 Red w/ Holtec 628A
Quantity: 92-122 (60/90 Gunmetal, 30 Black, 2 Prototypes)
Colors: Gunmetal Silver, Black (also Dark Gray Proto, Dark Gunmetal Proto)
Connectivity: PS/2 (can be USB too, if you use AIKON controller)
Plates: Aluminium, Polycarbonate
Quote of Eungsam that he dont used CEM-3 in CL.
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=16095 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=8474 , https://geekhack.org/index.php?topic=99876.0 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=9182 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=15223 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=27506 , https://www.instagram.com/p/C0p-cw3vPZx/?img_index=1 , https://blog.naver.com/elsuoo/80083276461
Photos credits: greatzizus (OTD), RV , Heymark, Elsuoo, Eungsam (OTD), Photekq (for screenshot)
« Last Edit: Tue, 20 August 2024, 10:58:54 by zlobin356 »
Offline caap
« Reply #11 on: Fri, 14 June 2024, 00:38:41 »
cool stuff here man, thanks for making this :thumb:
Offline zlobin356
« Reply #12 on: Fri, 14 June 2024, 01:27:50 »
thank you!
Offline zlobin356
« Reply #13 on: Fri, 14 June 2024, 15:11:37 »
OTD 356F - One of the most mysterious boards of 356 series. There is 0 info about internals, only pictures. Probably all info was on forum, which is dead and cant be open. Probably one of prototypes, built with Cherry MX Gray switches, OG cherry keycaps, OTD aluminium CNC keycap prototype,  and OTD Alps-Like short spring prototypes. Red ano, no engraving above arrow cluster, red aluminium plate. F means Female, but also can have "screwed up" (in joke way) meaning.
Materials: Aluminium, Brass/Copper (?)
Mount: Top with oring between plate and PCB (?)
PCB: Aqua FR4 Red w/ Holtec 628A (?)
Quantity: 1
Colors: Red
Connectivity: PS/2
Plates: Aluminium
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=27506https://www.kbdarchive.org/otd_archive/album_post.php?post_id=11085
Photos credit: Eungsam (OTD)
« Last Edit: Tue, 20 August 2024, 10:59:37 by zlobin356 »
Offline zlobin356
« Reply #14 on: Fri, 14 June 2024, 15:42:29 »
OTD 356CL DGE (Dark Gray Edition) (A.K.A (닥클) Duckle) - The budget version of 356CL. Probably one of the most popular otd boards, the board haves worse ano quality than 356CL, dont haves brass weight and uses cone feet design, the board is designed around idea of cheap keyboard with good performance in games. the pcb here is CEM-3 1.0mm yellow pcb with atmega16 controller, which gives bigger polling rate with special firmware by CDC. DIP switch on pcb gave possibility to change layout, like on HHKB which was considered as best gaming keyboard in korean community. the board haves only aluminium plate, black one (standard) and rare champagne anodized plate, plate is compatible with 356CL so you could also build it with 356CL pcb or 356CL half pc plate to achieve amazing typing experience.
PCB: Aqua CEM-3 Yellow 1.0T w/ Atmega16
Quantity: ?
Colors: Dark Gray (duh-uh)
Connectivity: PS/2
Plates: Aluminium
Source: https://blog.naver.com/elsuoo/80113663021 , https://www.instagram.com/p/CzGUQAXvEkS/?img_index=1/ , TGR discord , https://blog.naver.com/elsuoo/80104096382
Photo credits: Snayee, Whirlwind, Elsuoo
« Last Edit: Tue, 20 August 2024, 10:59:59 by zlobin356 »
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #15 on: Fri, 14 June 2024, 16:18:20 »
Thanks for doing this! I'm pretty well versed in the hobby being around for about 8 years now, but beyond knowing of the OTD boards & knowing they are very desirable/rare. I had zero ideal how many boards they made, what PCBs & controllers they used, how many of each board they made, etc. This is definitely very interesting to me, will be following this thread for sure! :thumb:
Offline zlobin356
« Reply #16 on: Sat, 15 June 2024, 04:34:23 »
thank you!! will try to make my best
Offline zlobin356
« Reply #17 on: Sat, 15 June 2024, 05:14:23 »
OTD 356n MK.2 - New version of 356N, for those who couldnt buy previous version, case haves lower quality and haves horizontal brushed pattern. The PCB is black fr4 double-layered aqua pcb with AtMega16 controller for better performance in games. Can be connected through PS/2 or modded to USB with special modification. still haves design for tactile switches, the case design is same. Also seen build with green PCB, which is cem-3 version
PCB: Black double-layered FR4 pcb or green 1.2T CEM-3 pcb by aqua w/ atmega16 controller
Quantity: 100 (10 red, rest is black and silver)
Colors: Red, Black, Silver
Connectivity: PS/2, USB
Plates: Aluminium, Half Polycarbonate
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=62753https://www.kbdarchive.org/otd_archive/album_post.php?post_id=45671 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=40014 , https://blog.naver.com/rhythemn/100209770301 , https://www.instagram.com/p/C4egzsJvs2y/?img_index=1 , https://blog.naver.com/elsuoo/80125591442 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=44161
Photos credits: 무늬님 (OTD),  올드보이 (OTD) , MagicPro (OTD), EdWard (OTD), eun, heymark , elsuoo , devolition (OTD)
« Last Edit: Sat, 31 August 2024, 08:25:26 by zlobin356 »
Offline zlobin356
« Reply #18 on: Sat, 15 June 2024, 05:34:26 »
OTD 356A - Aftermarket case for 356CL, stacked acrylic keyboard, should be even cheaper than DGE. Stacked mount, aqua fr4 red pcb. board had several prototypes with testing different manufacturers, to have durable case material that will not crack after assembly. First proto didnt had any 356A engravings, was just painted silver. Next one was silver, next is black, latest proto was pink. Board developed by miinam and eungsam
Materials: Acrylic
Mount: Stacked
PCB: 356CL FR4 Red/DGE CEM-3 Yellow
Quantity: ?
Colors: Black, Silver, White, Acid Pink
Connectivity: PS/2
Plates: Acrylic
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=10644 , https://blog.naver.com/elsuoo/80099416671
Photo credits: miinam (OTD) , elsuoo
« Last Edit: Tue, 20 August 2024, 11:01:11 by zlobin356 »
Offline zlobin356
« Reply #19 on: Sun, 16 June 2024, 14:14:24 »
OTD 356W - Wooden case for 356CL/356n. Small project without lots of info, haves 3 versions. The project never meant to be mass project, board created by miinam to test CNC wooden machining. The case haves cone feet structure. First samples didnt have engraving above arrow cluster. 2 wkl and 1 wk version for 356n plate
Materials: Wood
Mount: Top Mount
PCB: 356CL FR4 Red/DGE CEM-3 Yellow/356n
Quantity: 3
Colors: Wood
Connectivity: PS/2
Plates: Aluminium, Acrylic
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=13116 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=12993
« Last Edit: Tue, 20 August 2024, 11:01:34 by zlobin356 »
Offline zlobin356
« Reply #20 on: Sun, 16 June 2024, 15:29:55 »
OTD 356mini v1 (A.K.A 삼미니 (sammini) - One of the most famous custom 60 percent boards, this board features sandwich o-ring mount, in this mount you have special mounting points like in isolation mount, they fit between top and bottom case, you can make board more softer by slightly unscrewing case or making it more stiffer with fully screwed case, this is the first board to use o-ring rubber band as mounting. The PCB here is CEM-3 red pcb by aqua, this is the first 60 with flex cuts (first keyboard with flexcuts overall was DK Saver), pcb haves 18.9 keyspacing instead of 19.05mm prototype pcb featured green mask. board also had GON case, that had just sandwich mount and thicker bezels, strange plate design. i will update info about it when i will have more photos and info! the board is made to be mini version of 356CL. OTD gamers really liked HHKB size, so this is MX replacement for HHKB by OTD. first version PCB dont haves white silkscreen, haves standard spacing. Mini haves USB-Mini port, but its USB compatible, the cable it used haves PS/2 end to connect it to PC. First version haves only ANSI bottom row. First proto didnt featured brass weight, had green pcb and half raw plate
Mount: O-Ring sandwich mount
PCB: Aqua CEM-3 Red
Quantity: ? (10-15 military greens, 1 lime)
Colors: Red, Black, Military Green
Connectivity: PS/2
Plates: Aluminium
-----Prototype:
Source: https://blog.naver.com/rhythemn/223324060373 , https://blog.naver.com/dyraos/220184284142 , https://www.reddit.com/r/CustomKeyboards/comments/par28b/otd_356mini_v1_in_black/ , https://imgur.com/a/08giQzN , https://www.reddit.com/r/MechanicalKeyboards/comments/v3cs56/otd_mini_new_kit_otd_mini_prototype_brass_in_seal/ , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=194944 , https://deskthority.net/viewtopic.php?t=5185 , https://blog.naver.com/elsuoo/80119205110
Photo credits:  에릭 (OTD) , ? , yab8433408, ? , A7X, LightningXi, MonkaOmega, Eun, CDC (OTD), elsuoo
« Last Edit: Fri, 13 September 2024, 02:06:20 by zlobin356 »
Offline zlobin356
« Reply #21 on: Tue, 18 June 2024, 02:21:18 »
OTD 356mini v2 - The updated version of 356mini, features different versions of layouts, features use of AtMega32 controller.
PCB: Aqua CEM-3 Red with AtMega32
Quantity: ? (2 sky blue, 1 silver)
Colors: Red, Silver, Sky Blue
Connectivity: PS/2
Plates: Aluminium
Source: Ben10 pm, https://www.kbdarchive.org/otd_archive/album_post.php?post_id=183373 , https://www.mechblog.org/post/102213017784/otd-356-mini-v2-switches-mx-vintage-black-from
photo credits: MKB, jingil (OTD), ? (OTD) , eun, Eungsam (OTD), ?
« Last Edit: Fri, 13 September 2024, 02:02:45 by zlobin356 »
Offline zlobin356
« Reply #22 on: Tue, 18 June 2024, 02:50:36 »
356PAD - the numpad of 356 serie, offers lots of color options, uses AtMega32 controller, aluminium plate, case haves unique structure, with "unibody" seamless structure and feet. top mount, cem-3 pcb by aqua with soldered cable. you could have any color you wish, so there is a lot of strange color versions, haha ;D Prototype featured Raw finish, and green pcb.
Matreials: Aluminium
Mount: Top Mount
PCB: Aqua CEM-3 with AtMega32
Quantity: ?
Colors: Black, Sky Blue, Pink, Ironman Rosegold (Like on 456GT), Blue, Raw (Prototype), Red, Military Green, Gold, Gunmetal Silver, Dark Gray, Mint, Magenta
Source: https://blog.naver.com/elsuoo/80117674247 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=20000
photo credits: OTD.kr, eungsam (otd)
« Last Edit: Tue, 20 August 2024, 11:24:56 by zlobin356 »
Offline zlobin356
« Reply #23 on: Tue, 18 June 2024, 14:22:42 »
OTD The Cheat - Custom keyboard by Aqua (OTD). First aluminium board with 3 piece case, top mounted, haves AIKON controller and Red CEM-3 pcb (prototype featured blue cem-3 pcb). Uses cone feet structure, features only tsangan bottom row, plate is only aluminium, case haves big front height. The most affordable OTD for today's market (around 800$). As far as i know the CAD files of this keyboard were public.
Mount: Top Mount
PCB: Aqua CEM-3 with AIKON
Quantity: ?
Colors: Black/Silver, Black/Red, Cream/Red (Sample), Red/Silver, Silver/Red(By DangWang420), Red/Red
Photo credits: Snayee, XC, Eungsam (OTD), alaricjis , DangWang420, cjakma
« Last Edit: Tue, 20 August 2024, 11:25:31 by zlobin356 »
Offline zlobin356
« Reply #24 on: Sat, 22 June 2024, 06:10:45 »
sorry for delays. updates will be in week or so :thumb:
Offline zlobin356
« Reply #25 on: Sat, 29 June 2024, 15:49:20 »
OTD Koala & Brass Koala - Koala is keyboard released by Korellas, famous keyboard builder and PCB Designer. First run of koala had 10 units, the difference between standard koala and first one - is brass weight, first run had only 10 units, was available in dark gray and red color. Board features PCB with A.87 Footprint, and used plate design that have been used for long time (compatible with TGR Jane, Lyn Whale) The boards after first run aint feature brass weight, probably to make keyboard more affordable for end user. Also in Koala, we seen this famous sideprofile that you can see in your Kaze. Also found mentioning of koala wrist rest. One individual named nasby obtained OG Koala files and made his own runs, so there are some fake red and silver koalas
Materials: Aluminium (+Brass for Brass Version)
Mount: Top Mount
PCB: Korellas A.87 PCB
Quantity: ? (10-11 brass versions)
Colors: Silver, Black, Dark Gray (brass version), Red (brass version), Pink, Red
Plates: Aluminium
Photo credits: Sonny Shi, mm8x, Photekq, YourBleed_red, ?
« Last Edit: Tue, 20 August 2024, 11:25:58 by zlobin356 »
Offline zlobin356
« Reply #26 on: Mon, 01 July 2024, 11:47:14 »
OTD 356CLS - Stainless steel TKL from OTD, Designed by Eungsam with help of Sir. The keyboard haves high angle (about 9 degrees), brass weight, and powdercoat finish. Weights 6.2kg, uses unified OTD PCB (like in 360c, 356.2, 456gt), probably haves same plate design. Made as gift, around 5-6 units.
Mount: Top Mount
PCB: Aqua OTD Unified PCB (CEM-3)
Quantity: 20
Colors: Beige
Connectivity: PS/2
Plates: Steel
Photo credits: gundam, Heymark, Comi5v
Sources: https://www.zfrontier.com/app/flow/2qyW3YAa5Rz2 , https://geekhack.org/index.php?topic=78597.50 , https://www.instagram.com/p/C7kqc2Xv0j_/?img_index=1
« Last Edit: Tue, 20 August 2024, 11:26:23 by zlobin356 »
Offline zlobin356
« Reply #27 on: Mon, 01 July 2024, 12:28:25 »
OTD 356.2 - Refined version of 356cl, uses unified plate and pcb, haves outer brass weight. The board was limited only to special group of people with big amount of forum credit and big LVL, like on KBDmania. To earn points you should be active and participate in GB's. Board had several prototypes, V2.1 prototype haves some cnc and finishing mistakes, like error on cable hole, strange markings on F-row keys, strange black dots over alu. Also features prototype of unified pcb. Second known prototype haves Dark Gray anodization, belongs to stolenweapon. also heard that comi5v haves one prototype. Also had ALPS pcb as extra option, with stainless steel plate
Mount: Top Mount
PCB: Aqua OTD Unified PCB (CEM-3) + Prototype version for proto + Alps pcb (EXTRA)
Quantity: ~40-45 (20 in china, 2 in malasiya, 3 prototype, 15-20 in korea
Colors: Bluish Silver, Gray Blue, Gunmetal Silver, Prototype Gray Blue, Dark Gray prototype
Connectivity: PS/2
Plates: Aluminium, Half PC + Steel (ALPS EXTRA)
Photo credits: MKB,  글라슈테™ (OTD) , Venom (OTD), Heymark, Stolenweapon, Snayee, ???, Alarmsheep
Sources: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=180377 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=164827 , https://imgur.com/gallery/otd-356-2-build-log-by-snayee-date-3-jan-2024-7W4FazG , https://imgur.com/a/356-2-PIQ0K , https://www.reddit.com/r/CustomKeyboards/comments/12ykse9/otd_3562_grey/ , https://www.reddit.com/r/CustomKeyboards/comments/skobxr/otd_3562/, https://www.instagram.com/p/C7-jwYuPaFp/?img_index=1
« Last Edit: Tue, 20 August 2024, 11:27:36 by zlobin356 »
Offline bruin
« Reply #28 on: Mon, 01 July 2024, 22:11:26 »
thanks for sharing  :thumb:
would be nice to know where the qty numbers/colors came from as it seems a bit off. I don't think mini v2 had any black units?
the qty breakdown for the 356.2, by region, is also a bit strange? these boards get traded/sold privately so I'm not sure how one can sum this up by region.
either way really enjoyed going through the old photos.
« Last Edit: Mon, 01 July 2024, 22:16:27 by bruin »
Offline zlobin356
« Reply #29 on: Tue, 02 July 2024, 10:25:34 »
v2 should have black units, seen some photos of 356mini built with tsangan bottom row.
just seen mentioning of this in gh. info might be outdated, but thats the only thing i have rn.
Offline danielsun23
« Reply #30 on: Tue, 09 July 2024, 17:29:25 »
https://blog.naver.com/hariappa/223498003524
According to this there were ~20 356CLS made, although I don't know who except Eungsam has the definitive answer.
I'm just hoping I'll get the chance to see one of them in person eventually :thumb:
Offline zlobin356
« Reply #31 on: Mon, 22 July 2024, 14:12:27 »
OTD 456GT - High angle keyboard from OTD. Haves 11 degree angle, named after Ferrari 456GT. Uses unified OTD PCB and plate, Nice feature here is two separated brass weights, it saves manufacturing costs. Included wrist rest. GON Also made A356 controller for GT.
Mount: Top Mount
Quantity: ?
Colors: Rosegold Iron Man, Black, Silver
Connectivity: PS/2
Plates: Aluminium
Photos by: Photekq, Snayee,  웨이브샷 (OTD) ,  전우빈 (OTD)
Source: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=141674 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=145408 , https://www.kbdarchive.org/otd_archive/album_post.php?post_id=196462 , https://www.instagram.com/p/CpPN6WNP_-J/?img_index=1
« Last Edit: Tue, 20 August 2024, 11:27:59 by zlobin356 »
Offline Jampot_298
« Reply #32 on: Mon, 22 July 2024, 18:04:23 »
Great work, zlobin!
Offline zlobin356
« Reply #33 on: Wed, 24 July 2024, 05:53:17 »
Offline zlobin356
« Reply #34 on: Wed, 24 July 2024, 05:53:40 »
Thanks for info!
Offline zlobin356
« Reply #35 on: Wed, 24 July 2024, 06:35:38 »
OTD 360C/360corsa - Last release from OTD, was made in 2013, designed by Eungsam, iconic piece of keyboard design and true grail, classic round proportions, iconic side profile, go-through weight, engraving above arrows. one interesting feature in 360c is the weight, if you use clicky switches you can delete the weight and have better sound with clicky switches. This type of weight is more expensive to manufacture but fulfills need of inner weight. Board uses unified plate and pcb, if you were 356.2 owner you could add half pc plate to it and have different feel, also supports A356 controller by GON. There is one unit in gunmetal silver color, owned by coookiecurls. The history of this unit is unique and i think you need to check it on reddit. https://www.reddit.com/r/CustomKeyboards/comments/z7kouv/otd_360c_in_gunmetal_gray/
Mount: Top Mount
Quantity: ?
Colors: Apple Silver, Hyper Gray, Gunmetal Silver
Connectivity: PS/2
Plates: Aluminium
There are also prototype pictures, first proto haves strange screwholes on top.
photo credits: photekq, coookiecurls, eungsam (otd),  병정 (otd),
« Last Edit: Tue, 20 August 2024, 11:29:09 by zlobin356 »
Offline xeoomd
« Reply #36 on: Wed, 24 July 2024, 08:07:07 »
v2 only have red with 7u bottom row
black is only in v1, if you see black with 7u, probably it's a swap
Offline zlobin356
« Reply #37 on: Thu, 25 July 2024, 15:41:39 »
modified
Offline zlobin356
« Reply #38 on: Mon, 29 July 2024, 16:12:57 »
OTD MXmini - PCB format for compact 75 percent keyboards, was used in many opensource cases back in the day. Developed by fully by OTD. The cool feature here is duplicated usb ports on each side.
« Last Edit: Tue, 20 August 2024, 11:29:32 by zlobin356 »
Offline zlobin356
« Reply #39 on: Tue, 30 July 2024, 05:46:19 »
SSS - Case made of steel and acrylic, uses Korellas A.87 PCB. Standard sandwich structure
Materials: Acrylic, Stainless steel
Mount: Sandwich Mount
Quantity: 1
Colors: Transparent/Silver
Connectivity: PS/2
Plates: Aluminium
Photo credits: heymark, : 한별장군 (OTD)
Sources: https://www.kbdarchive.org/otd_archive/album_post.php?post_id=80994 , https://www.instagram.com/p/C4hLu76vtMx/?img_index=1
« Last Edit: Tue, 20 August 2024, 11:29:51 by zlobin356 »
Offline zlobin356
« Reply #40 on: Tue, 30 July 2024, 05:53:42 »
Aqua (OTD) LIMKB - FRL project like MXmini, you could buy OTD pcb with MCU and make case for it, first prototype used ML switches
Materials: Acrylic in proto
Mount: Sandwich mount
PCB: Aqua LIMKB CEM-3 pcb
Quantity: ?
Colors: transparent (proto)
Connectivity: PS/2
Plates: Aluminium
prototype:
thx for Mr.Pig for sharing pics
« Last Edit: Tue, 20 August 2024, 11:30:13 by zlobin356 »
Offline zlobin356
« Reply #41 on: Tue, 30 July 2024, 05:59:01 »
OTD Cyclopia - Small project made around 356n pcb, the main point of it is to make WKL 6.25u layout, simple stacked case
Materials: Acrylic
Mount: Stacked mount
PCB: KlKlKl 356N CEM-3 pcb
Quantity: 1
Colors: White
Connectivity: PS/2
Plates: Acrylic
« Last Edit: Tue, 20 August 2024, 11:30:25 by zlobin356 »
Offline zlobin356
« Reply #42 on: Tue, 30 July 2024, 06:05:54 »
2017 - Unknown OTD keyboard project, probably nevermade, mentioned that it should open new serie?
sources: https://geekhack.org/index.php?topic=78597.200
« Last Edit: Tue, 20 August 2024, 11:30:36 by zlobin356 »
Offline zlobin356
« Reply #43 on: Tue, 30 July 2024, 06:16:30 »
Cat Pad - Unreleased numpad by Korellas, haves same design as koala. No proto of case, only PCB made
Materials: NIL
Mount: Top Mount (?)
PCB: Korellas Numpad PCB
Quantity: 0
Colors: Silver (on renders)
Connectivity: PS/2
Plates: NIL
« Last Edit: Tue, 20 August 2024, 11:30:49 by zlobin356 »
Offline zlobin356
« Reply #44 on: Fri, 30 August 2024, 11:36:05 »
should we add keycaps to this wiki ?
Offline onlymisn
« Reply #45 on: Mon, 02 September 2024, 22:48:38 »
Hello, I am a Korean custom keyboard user.
Recently, I also wanted to document the history of OTD, so I wrote an article.
It's a pity that I couldn't refer to this article when writing.
I hope that the material in my article will also be helpful to this article.
https://blog.naver.com/hariappa/223498003524?trackingCode=blog_bloghome_searchlist
Offline Jampot_298
« Reply #46 on: Sat, 07 September 2024, 07:22:29 »
Yes pls!
Offline zlobin356
« Reply #47 on: Fri, 13 September 2024, 02:07:21 »
yup, i seen your article, its good and usefull!!!
