Author Topic: [IC] Key Kobo - Cherries | The Cherries Are Ripe  (Read 16736 times)
Offline Sensitive Works
  • SENSITIVE WORKS
« on: Wed, 12 June 2024, 02:23:17 »
Key Kobo  Cherries
Hey, It's a pleasure to see you guys again!!!
I'm KLXH from SenSitive Works.
The Cherries Are Ripe.
·Inspirition·
The color scheme is inspired by cherries, with the primary color being cherry red and the accent color representing fully ripe cherries.
Legend color is the color of cherry pits. In the base kit, additional gradual colors are provided to symbolize the ripening process of cherries.
Novelties are designed based on cherry blossoms and ripe cherries.
·Kitting·
·Renders·
(just for reference)
·Specifications·
Material: ABS
Manufacturing Method: Double Shot Injection Moulding
Keycap Profile: Cherry
Manufacturer: KeyKobo
Compatibility: Cherry MX and MX clone switches
Designer: SenSitive Works
·Vendors·
TBD
·Contact·
 ;D
« Last Edit: Wed, 19 June 2024, 10:08:20 by Sensitive Works »
Offline tactilesbad
Re: [IC] Key Kobo - Cherries | The Cherries Are Ripe
« Reply #1 on: Wed, 12 June 2024, 03:22:01 »
nice. can we have a mono cyrillic alpha kit
  • SENSITIVE WORKS
« Reply #2 on: Wed, 12 June 2024, 03:52:43 »
Thank you for your valuable suggestions, but I'm very sorry that we don't have a mould with the Cyrillic.
Offline tactilesbad
« Reply #3 on: Wed, 12 June 2024, 05:31:31 »
I know, I'm saying have molds made. good opportunity, given the colors, I'd say
Offline DaaDaa
« Reply #4 on: Wed, 12 June 2024, 05:39:31 »
Looks great. Of course text miss would be better but people here like icons or even worse text/Icon so I guess most sets will be mid
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline spambox2312
« Reply #5 on: Wed, 12 June 2024, 09:14:32 »
Do you have a comparison for how this looks compared to other red keycaps (GMK Perestroika, GMK Blot, JTK Ride, etc)?
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #6 on: Wed, 12 June 2024, 10:28:48 »
every doubleshot manufacturer will now offer white on burgundy
Offline Fraaaan
« Reply #7 on: Wed, 12 June 2024, 10:32:07 »
R1 End and PgDn can be moved to numpad kit because those are for 1800 layouts.
Any chance for an ISO novelty or accent?
  • SENSITIVE WORKS
« Reply #8 on: Thu, 13 June 2024, 00:44:51 »
Sorry we haven't borrowed these caps for comparison temporarily, I'd like to compare the color with other red caps.
Don't worry,I will do it  in time after sample be produced. :D
  • SENSITIVE WORKS
« Reply #9 on: Thu, 13 June 2024, 00:52:51 »
Actually the legend color is the color of cherry pits, It's not white.
Offline dan1mmm
« Reply #10 on: Thu, 13 June 2024, 12:19:54 »
Hope you try UV print Cyrillic sublegend & Translucent numrow. Lovely color, I'm in
« Last Edit: Thu, 13 June 2024, 12:23:40 by dan1mmm »
Offline konstantin
  • Formerly constexpr
« Reply #11 on: Thu, 13 June 2024, 16:24:08 »
Looks tasty!
One thing though: the R1 End, PgDn keys should be moved from base to the numpad kit, since they're exclusively used on boards with a numpad (1800/CP/96-key). Here's an example from a concurrent IC.
Also, the light alphas kit is missing R1 \|; R3 \|, scooped F, J; R4 <> (all 1u) to match all the alpha keys from the base kit.
You might also want to consider adding light-colored F1–F4, F9–F12 keys to the alphas kit.
« Last Edit: Thu, 13 June 2024, 16:29:40 by konstantin »
  • SENSITIVE WORKS
« Reply #12 on: Thu, 13 June 2024, 23:16:21 »
The Accent color ISO enter has been added.
  • SENSITIVE WORKS
« Reply #13 on: Thu, 13 June 2024, 23:18:21 »
Looks tasty!
Thank you so much, I will revise it in time.
Offline cookingallianz
« Reply #14 on: Fri, 14 June 2024, 02:21:21 »
Do you have a comparison for how this looks compared to other red keycaps (GMK Perestroika, GMK Blot, JTK Ride, etc)?geometry dash
This can help you see how each set compares in terms of color vibrancy, font style, and overall aesthetic.
Offline sauvieng
« Reply #15 on: Fri, 14 June 2024, 20:58:56 »
Please monolegend Cyrillic (for the memes of course)
Offline codecoffeecode
  • refill needed by Glenn Jones
« Reply #16 on: Sat, 15 June 2024, 00:04:46 »
I'm really liking this colorway; I'd love to see samples compared with other red keycap sets.
Personally, I'd like see 2u, 2.25u, and 2.75u spacebars in the 40s kit, either in addition to or instead of the ortho support.
  • SENSITIVE WORKS
« Reply #17 on: Sat, 15 June 2024, 07:34:12 »
Updates:
1:Add F1-F4, F9-F12; scoop F&J; and other caps in Alpha Kit
2:Add the accent color ISO enter in Base Kit, remove two function caps from Base Kit to Numpad.
Offline kkai
  • Discord#theboredkai
« Reply #18 on: Mon, 17 June 2024, 05:11:37 »
 :thumb:
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #19 on: Mon, 09 September 2024, 14:49:53 »
Key Kobo announced yesterday on their Discord server:
hi everyone,Keykobo Cherries are about to be produced and sent to the following regional Vendors:
US: Divinikey
Canada: Unikeys
Taiwan:PNK
UK:SerpentKeys
Australia:KeebzNCables
France:DeltaKeyCo
Singapore: Ktechs
