Author Topic: Keychron keyboards height  (Read 6912 times)
Offline AmigaDisk
  • Formerly ohm-ish
« on: Thu, 13 June 2024, 18:28:25 »
To me it seems like all Keychron's keyboards are very tall.
Isn't this an ergonomic problem?
Or do you just get used to it and relax into it with the wrists hovering that high up?
Offline Rhienfo
  • GOTHETIGES
Re: Keychron keyboards height
« Reply #1 on: Thu, 13 June 2024, 22:04:21 »
Yeah they seem that way as well, never had noticed. 21.6mm for Q1 is a lot (and that's not the effective keyboard height as well, so in practice it feels even higher than that)
Generally you want to do hover typing, putting your wrists on the ground is actually improper, and generally the height you have to hover hand is not really a factor to ergonomics. You will probably get used to it within time. People get used to other boards with large front heights like duck boards (though I think this might be higher than even them)
So basically the only ergonomic problem with the keychrons is if you don't type with hover hand, then it could cause more strain on the hands (as well as being not that great to type on for those people in general)
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #2 on: Fri, 14 June 2024, 01:07:48 »
Ah. I already do hover typing..
I just meant that with the Keychron extra height I would imagine typing on it could be a lil bit straining
But maybe it's not a problem
I just don't think I would want a keyboard that tall
« Last Edit: Fri, 14 June 2024, 01:15:26 by ohm-ish »
Offline Rhienfo
  • GOTHETIGES
« Reply #3 on: Fri, 14 June 2024, 01:29:53 »
I mean for me at least when I hover the typing angle is a far bigger factor than the front height because with front height your typing doesn't change, it's just at a different height so that's why I said that. And even the typing angle isn't that big of a factor personally speaking.
It will be different at first but I don't think it will be more or less straining at different front heights.
Offline Pyre
« Reply #4 on: Sun, 16 June 2024, 17:57:19 »
They are super tall - esp if you keep the original caps they come with. I found my K8 was pretty uncomfortable to use until I grabbed a wrist rest - really helps level the setup out, and you eventually get used to it.
