Author Topic: [IC] ENV75 | Update* Badge Remove  (Read 5857 times)
Offline TheLetterM
« on: Thu, 11 July 2024, 05:33:17 »
IC Form
ENV-75
Render
Solder
Hotswap
Specification
- Layout : 75 %
- Weight : ~3kg
- Mounting : Top and Gummy O-ring
- PCB : Solder and Hotswap ,QMK and VIA Support. (Will try ISO support on hotswap)
- Plate :
Alu, CF , PC , PP And POM *More or less depend on IC form*
Material
- Top & Bottom : Aluminum 6063
- Weight : Copper, Brass and Stainless Steel
Weight Finish
- Sandblast
- Brush
- Polish
*Clear Coated*
Price
- Depend on vendor and options (300-400 USD)
Kit Includes:
  • Keyboard Kit
  • PCB
  • Daughter board
  • PC Plate
  • 50A O-ring
  • All necessary screws
  • Silicone Feet
  • Carrying Case
Color
Black, Beige, White, Silver, Green, Blue, Navy, Red
IC Form
Contact
Discord: Link
« Last Edit: Mon, 28 October 2024, 12:13:55 by TheLetterM »
Offline rondg
Re: [IC] ENV75
« Reply #1 on: Thu, 11 July 2024, 08:49:37 »
Please consider making the badge optional - the user will have a choice to put a badge or a switch.
Also, the badge kinda reminds me of Gmail...
Offline leftcoastfunk
Re: [IC] ENV75
« Reply #2 on: Mon, 22 July 2024, 20:35:15 »
I second that. The board overall looks nice, but gets a bit busy with the badge there too. I'd rather have an extra key there. Maybe instead of the top right badge, you could make the logo above the exploded arrows accept optional badges (by default would just be as-is)
Offline ookmonito
    • cluster rush
Re: [IC] ENV75
« Reply #3 on: Tue, 30 July 2024, 02:11:34 »
The bottom design is nice but the top just feels like it's missing something.
Offline feedj
Re: [IC] ENV75
« Reply #4 on: Wed, 14 August 2024, 21:36:26 »
I hope you'd be able to make the badge optional and/or offer other colors for the badge. A tricolor badge matching the theme of the bottom housing would be sick with this board too.
Offline Cringelord
  • Crack Connoisseur
Re: [IC] ENV75
« Reply #5 on: Thu, 15 August 2024, 03:05:16 »
This actually looks really nice. Badge is lame.
Re: [IC] ENV75
« Reply #6 on: Thu, 15 August 2024, 03:47:06 »
I dig it
Sent from my Pixel 8 Pro using Tapatalk
