Author Topic: [IC] Vida - A Lively 60% from CannonKeys  (Read 21153 times)
Offline upas
« on: Tue, 16 July 2024, 10:31:24 »
V  I  D  A
60% - Wireless - Magnet closure - USB 2.0 hub
VIDA COMING SOON PAGE
FEEDBACK FORM
Design brief/what we want to achieve:
With Vida, we wanted to try something a little bit different. Typically we like to develop things as much as possible in-house using our own vision exclusively before sharing the idea with the wider community. This time round, we are mid-way through development and wanted to share our early findings with you all, and genuinely wanted your feedback before we push this project through to the final stages.
Simply put, we wanted to create a keyboard that had all the trappings of a custom keyboard that we all expect, but designed carefully in a way to achieve a much more affordable price tag without compromising on the design and quality. Of course, this is easier said than done, and we can never truly compete with offerings from various Chinese brands solely on price as we don’t manufacture our boards in-house, but we wanted to take a similar ethos and add our own shine to it.
Design so far/our findings/next steps:
We have already had one prototype made and through thorough testing, we’ve found a few hiccups and decided that a few changes need to be made:
1) The case is closed using magnets and for the initial prototype, we experimented with various shapes and sizes to see what would be the most effective and ultimately, some long, horizontal bar magnets were the size that we landed on. The next step with these is working with Hongtu to ensure that these are pre-installed cleanly and effectively.
2) Due to how the top and bottom case are held together, you would need to press on the keys while pulling the top case up to remove it from the bottom. Because of this, we have opted to bottom-mount the plate on some soft gaskets to ensure a nicely cushioned typing experience. The current gasket design was great on paper, but in practice they sometimes got chewed up by the screw thread when fixing the plate down. From here we will need to amend the gasket design to ensure that once installed, they’re not at risk of being caught by the screw threads.
3) The top and bottom case have fairly tight tolerances between them (~0.2mm all round), but because there aren’t screws to hold the top case in a fixed position, the top case can move laterally for the full ~0.4mm. This doesn’t sound like much but it does make a noticeable noise if you intentionally move the parts yourself. To combat this, we plan to implement some alignment pins/pegs to slot the case parts together and eliminate any lateral movement (shown in the exploded view below).
4) We have ordered a wireless PCB but it hasn’t arrived yet - we have only tested using a Bastion 60% hotswap PCB so far to great success, but we will add our findings on the wireless testing once we have the PCB in hand.
We’re hoping for some genuine, constructive feedback from this IC so please make your thoughts and suggestions known in the IC form (feedback form here). If any of your feedback seems useful or viable, we will be sure to implement this on the next (and hopefully final) version of the board.
Current specs & features:
  • 8 degree typing angle
  • 19mm effective front height
  • Wireless/bluetooth PCB
  • USB 2.0 hub (2 ports)
  • 6063 aluminum top/bottom case
  • Anodized aluminum inner (2) and outer (2) weights (tested) - other materials and finishes planned
  • Bottom mount plate (with poron dampeners)
  • Designed by James from AKB
Prototype photos:
Current PCB support:
Hotswap (wireless):
The first PCB prototype we ordered has support for split backspace and split right shift. Currently it doesn’t support stepped caps lock due to the placement of the bluetooth switch, and it is fixed to a 7u bottom row to allow room for the bluetooth module. However, we are currently working on including stepped caps lock and a 6.25u bottom row by moving these components around and seeing what fits. We have also tested various plate materials with this PCB (including aluminum) and the signal remains clear and strong with all.
Hotswap (non-wireless):
Includes full/stepped caps lock, full/split backspace, full/split right shift and both 6.25u/7u bottom row options.
Solderable (non-wireless):
Includes all options currently available on our Bastion 60% solderable PCB: full/stepped caps lock, full/split backspace, full/split right shift, ANSI/ISO, 6.25u, 7u & split space bottom row support.
GB plans:
None yet - hopefully this year, subject to interest, but we need to perfect the design first.
We're hoping to achieve an MSRP of $225 or below - more details to follow as we progress further through development.
A general meta comment on pricing and how we see Vida’s place in the market:
Many boards by QK, Meletrix, TKD, etc. are able to be sold for relatively lower prices due to the sheer quantity of boards that they can sell. The Chinese market is really big, and they’re able to use their combined audience to commit to buying multiple thousands of units - leading to a really low list price.
For Vida, we’re choosing to target a $225 or less starting price solely based on pricing at a lower MOQ. Depending on interest, we know we can reduce that to $200 or even less - and we're excited to be able to do that after gauging interest.
If a $225 price turns your “Yes I’m interested in this board” into a “No, I’m not interested in this board”, please let us know! Or even better - let us know how much you’d be willing to pay for a board like this.
Boards that aren’t sold en-masse with thousands of units sold are going to have a cost premium compared to the ones that sell at higher volume, but the reason we are still making this specific board is because we think that option and variety are what makes our keyboard hobby interesting.
With that in mind - we’re offering Vida because it’s different from other lower-priced options out there. If the design language, aesthetic, specific featureset, mounting style, or acoustics of Vida speak to you - that’s exactly what we’re going for! Our goal here isn’t to check all the boxes when it comes to features, but rather to offer something cohesive and curated that offers a great experience. We’re excited to be able to finally reveal Vida, and believe it has something great to offer the community and the hobby.
We've also opted to run the wireless PCBs on ZMK, especially given that the ZMK Studio GUI suite will be ready by the time Vida ships to customers. In addition, the alpha build is now live!
Learn more about our future plans for working with ZMK Studio on our blog post here: https://cannonkeys.com/blogs/news-and-updates/zmk
FEEDBACK FORM
We’re looking forward to hearing your feedback on this project, so please feel free to let us know on the link above!
« Last Edit: Tue, 17 September 2024, 08:37:53 by upas »
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
Re: [IC] Vida - A Lively 60% from CannonKeys
« Reply #1 on: Tue, 16 July 2024, 10:35:30 »
YES PLEASE
Offline Maxximum
    • My printables
« Reply #2 on: Tue, 16 July 2024, 10:42:35 »
That target MSRP is crazy. 100% in
Offline sipp11
« Reply #3 on: Tue, 16 July 2024, 10:44:15 »
Please consider usb type-c hub as an option. I know it's USB 2 as of now, but imagine USB 3.x + USB type-c hub as another option. I'm sure I'm not the only giving you $.
Oh, I'm voting for HHKB layout in whatever forms (6u or any *u)
Offline xLeHoy
  • weeb board enjoyer
« Reply #4 on: Tue, 16 July 2024, 10:44:42 »
Personally I don't really like USB hubs in keyboards but I am sure many will enjoy having it. I like the board design wise but the hub really sticks out and distracts me a bit.
GLWIC though!
Offline upas
« Reply #5 on: Tue, 16 July 2024, 10:53:20 »
Oh no, I forgot a reserved post :(
Offline upas
« Reply #6 on: Tue, 16 July 2024, 10:58:33 »
YES PLEASE
We hope we can get the MSRP even lower with enough interest!
GLWIC though!
We can consider some sort of hub cover I guess? It'll still stick out though, since it's there.
Please share this in the IC form too, so if others share this opinion, we can make some changes.
The Hub can't be used wirelessly either - so there might be some other options.
Given the target price - USB 3.0 is probably not in the cards for this particular board, but we'll definitely consider it for others.
I think HHKB 7U will be supported at least, unsure about 6U though.
« Last Edit: Tue, 16 July 2024, 11:00:32 by upas »
Offline Cobertt
    • Control on Caps
« Reply #7 on: Tue, 16 July 2024, 11:30:41 »
Will you be targeting a higher battery life by using ZMK instead of QMK similar to the BakenekoGo? Is the hub only available in wired mode? Will this be a single color release like the Caerdroia by AKB or are other colors planned? In for one regardless as it's by James and has a USB hub in the best layout.
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65 |  Midway LE |  Kei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline upas
« Reply #8 on: Tue, 16 July 2024, 11:37:43 »
It will use ZMK and there's built-in room for batteries under the internal weights - we should have great battery life.
Hub is wired only. You can plug in the board with the wireless PCB, and both the keyboard and the hub will work. But if you're using the board wirelessly, the hub won't work.
We'll be doing multiple colors, but we're not sure what yet. Let us know what you'd like to see in the IC form!
« Last Edit: Tue, 16 July 2024, 12:15:07 by upas »
« Reply #9 on: Tue, 16 July 2024, 11:56:34 »
Yes! FINALLY a 60 from y'all! Also really love the Ano Silver Top & Grey Bottom Color combo for the case. Hopefully that's an option along with Grey Top too.
The PCB layout options for Hotswap Wired seem to satisfy every crowd which is nice to see.
Overall, I'd say y'all have the nicest 60% offering I've seen at this territory since the Tempo (though that was only HHKB and was a smidge more expensive). Definitely watching this one
Sent from my Pixel 7 Pro using Tapatalk
Offline upas
« Reply #10 on: Tue, 16 July 2024, 11:59:22 »
Took a quick sound test using my desk setup.
There is background noise, etc. but it's at least something!
https://vocaroo.com/1mncQqQ5wKP3
Vida
PC Plate
Dark Amber Switches (Lubed)
PBS MV Classic (pls consider PBS)
No Foam
I'll try to take another sound test with GMK caps on it later
Offline upas
« Reply #11 on: Tue, 16 July 2024, 12:02:20 »
We really love how this color turned out - so it'll likely stay for production as well.
Other than that one color way, we don't have anything else set in stone yet. We'll definitely offer more colors, but we're open to suggestions.
Thank you for the high praise!
Offline Natetypesfast
« Reply #12 on: Tue, 16 July 2024, 12:12:32 »
Sounds great and I think that price is totally fair given the presumed quality of the board and thoughtful design.  Excited for this one
Offline mr_foggy
  • neue = nope
« Reply #13 on: Tue, 16 July 2024, 12:14:59 »
at this price it looks like a no brainer. nice little board.
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #14 on: Tue, 16 July 2024, 12:32:51 »
nice
French keyboard streamer
Offline lkkedward
« Reply #15 on: Tue, 16 July 2024, 14:04:09 »
Not an enjoyer of adhesive poron gaskets. Would it be possible to use silicon (and maybe in different hardness)?
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #16 on: Tue, 16 July 2024, 14:35:36 »
Filled out the IC, hopefully you see a ton of interest in this project and are able to get the price down to $200. At that price with USB passthrough and it being a 60 I think it will sell like hotcakes. Looking forward to watching how this project grows!
Offline IBMweMissU
« Reply #17 on: Tue, 16 July 2024, 16:10:17 »
Yes, yes, yes
definitely in, filled the IC, can't wait
Offline ShadowBlade
  • Just a newbie in the land of keyboards
« Reply #18 on: Wed, 17 July 2024, 01:14:27 »
Great pricing, would love it even more if you were able to reduce it even further via MOQ
Offline hzh0525
« Reply #19 on: Thu, 18 July 2024, 10:34:05 »
balanced price and design~
Offline Cringelord
  • Crack Connoisseur
« Reply #20 on: Sat, 03 August 2024, 00:39:59 »
I love AKB's design language on the last few boards, this especially. Nice to see potential weight options that aren't just aluminum-not sure why people still bother with machining out aluminum for aluminum weights for the sake of a design.
Offline RozenKristal
« Reply #21 on: Sun, 11 August 2024, 22:14:28 »
It is nice. Though I think the 2.0 USB hub is kinda dated at this point. Possibly doing USB-C or just remove them?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #22 on: Mon, 12 August 2024, 16:42:05 »
Love the ideal & the board look great! I'm pretty well sold as it stands, if it gains enough interest to be priced even lower I think this will be a home run for you guys. Good luck moving forward with this, I filled out the IC & will be keeping up with this!
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #23 on: Sun, 25 August 2024, 05:00:18 »
The board is really interesting and I'm really curious to evaluate the next prototype. GLWIC!!!
Are half-plates also planned? Will the plates be universal? Is it possible to have dedicated ISO plates?
There are two aspects of the board that I'm not completely convinced by:
  • the mounting system: it would be interesting to also have at least a gasket option, similar to what was done for the Cycle7/8;
  • why is the USB hub mounted upside down? This makes it incompatible with some devices, such as Yubico security tokens and similar; moreover it exposes the PCB fixing screws: IMHO I find them ugly to look at, in fact they pass through the internal weight and are not symmetrical.
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Osidian
« Reply #24 on: Sun, 25 August 2024, 20:45:54 »
Love this 60%. Looks phenomenal, love the route chosen to go with magnetic case construction. Easy to modify with a balanced and simplistic design. GLWIC :thumb:
Offline Keebzncables
« Reply #25 on: Mon, 26 August 2024, 07:51:32 »
Lookin' good fellas
« Reply #26 on: Tue, 27 August 2024, 08:18:39 »
When I sat down to design this board I was initially thinking something more traditionally gasket-mounted, but when I looked around at other boards being offered it seemed like the majority of boards already offer this and I figured I'd try something a little different. The idea with the mounting here was that the entire assembly would fix down into the bottom case to make the overall assembly much simpler (no fiddly cables connecting the top and bottom together). This also allowed us to have a simpler top case design internally which helped us get to a more competitive MSRP. Plus I like bottom mount and we don't see it often enough :D
I don't believe so. Yes. Probably not (unless a vendor specifically asks).
Because of space, basically. The USB-A ports aren't small so the cavity needs to be deeper than what your usual USB-C daughterboard requires. If you mounted them with the USB ports on the top side of the daughterboard you would no longer have the required depth in the case material to screw the daughterboard down, and I didn't want to increase the case angle further or make the board any taller in general  :thumb:
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #27 on: Tue, 27 August 2024, 15:10:05 »
Yours the board, yours the choice. I'll live with that.  ;)
Do you think it would be possible to consider designing those plates and then make their files available at the end of the GB?
I imagined that was the reason, thanks for the confirmation. However, I think that this choice should be carefully considered because it significantly limits compatibility with some devices.
If you don't want to increase the case angle, maybe you could use the same type of approach that you used for the bottom mount and... try something different: how about a hub with USB-C ports?
Thanks for your kind replies, once again: GLWIC!!!
Offline LMNPI
  • QAZ is love.
« Reply #28 on: Thu, 29 August 2024, 17:00:11 »
Not sure if I really need another 60 board - but I'm in I guess.
« Reply #29 on: Tue, 03 September 2024, 11:03:37 »
This is something I'll have to discuss with the rest of the team, but I'd imagine we'd do that at some point ;)
Definitely a solid bit of feedback to consider for a future project :thumb:
Offline upas
« Reply #30 on: Tue, 17 September 2024, 08:36:29 »
Wireless testing update:
We've done thorough testing using the wireless PCB with various plate materials, including aluminum, and can confirm the signal is clear and strong with all plate materials.
Offline nebben42
« Reply #31 on: Fri, 20 September 2024, 14:50:17 »
Thank you Cannonkeys for listening to us. This is a great step in the right direction!
Offline CaptainSterling
« Reply #32 on: Fri, 20 September 2024, 15:58:31 »
I really like the overall styling and concept of this one. Hoping for some decent battery life!
Offline jd
  • 60%
« Reply #33 on: Sat, 21 September 2024, 20:48:46 »
Very interested in this.
Offline scorcher36
« Reply #34 on: Wed, 06 November 2024, 18:45:45 »
Why does CannonKeys label inner and outer aluminum pieces as "weights"? Aluminum board sections are typically machined to fit actual weights made from other materials, and sometimes even batteries or components. It might be more fitting to refer to these as "inner" or "outer pieces" instead. CannonKeys works with talented designers to create unique products but the marketing approach of segmenting niche color and material combinations at premium prices feels deliberate and often creating an artificial sense of scarcity/FOMO. If you're running a group buy or offering in-stock items, it would be more transparent to provide customers with genuine options to select what they truly want. Since, it better preserve the passion and enthusiasm for these products, rather than letting marketing overshadow their authenticity.
Offline JQ27
« Reply #35 on: Thu, 07 November 2024, 05:27:25 »
With all the pictures and videos show far showing fixed layout plates, what's the take with universal/diff layout plates considering the PCB can support it (and is being advertised as such)?
