Author Topic: Three keys dead, how to fix?  (Read 12031 times)
Offline raffas
« on: Sat, 20 July 2024, 04:50:38 »
I recently assembled my first board in years (hello family commitments!) and it seems three of the switchtes aren't registering.
My troubleshooting this far:
I tested all three switches with a multimeter, and I got a beep from the continuity mode when pressing down the switch. I think that means that the switch is OK, and that the soldering is OK.
I then resoldered each switch to make sure it was fine, continuity tested OK but still no keypress registered
I then unsoldered one switch and tested it, passed the continuity test
I then tested the PCB holes for the switch with the same continuity tester, and nothing. Nothing registered.
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Three keys dead, how to fix?
« Reply #1 on: Sat, 20 July 2024, 06:39:50 »
Put some pics up of the PCB (front & back) where the offending keys are. Sounds to me like there is either a few missing diodes or a few dead diodes. The only other thing I can think of is the traces going to those switches could be damaged in some way & have been severed Given the switches themselves are fine.
Offline zegonix
« Reply #2 on: Mon, 01 June 2026, 07:40:20 »
i would check the traces from the controller to the switches, then the diode, then resolder the controller (only when comfortable with soldering surface mounted components).
Offline xyzzy42
« Reply #3 on: Wed, 03 June 2026, 16:58:36 »
If one of the pins on the MCU was bad, then all the keys in the column/row of the bad pin wouldn't work.
So you should look up what row, column the three keys are on.  If they are all on the same row or the same column, that's a sign of one of traces or controller being bad.  If any other keys in the problem row/col work, then you know the MCU isn't bad and its pins are soldered fine.  There would be no point in resoldering the controller in this case.
If a trace is broken, what will happen is that every key after the break will stop working.  So a single break could take out the last three keys, and only the last three, in the row/col.  That would be the most likely problem if they are in the same row/col, but other keys (before the break in the trace) in that row/col still work.
If the three keys are in different rows and columns, then it's probably the diodes that are bad (less likely) or not soldered properly (more likely).
Offline zegonix
« Reply #4 on: Thu, 04 June 2026, 08:20:10 »
what you say is true. thanks for elaborating and potentially saving op unnecessary steps.  :thumb:
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« Reply #5 on: Tue, 14 July 2026, 20:34:05 »
Try plugging the board in and shorting the two switch pads directly with a pair of tweezers:
If it registers a keypress: The PCB circuit itself is fine. The issue is likely a cold joint on the pads, or the metal contacts inside the socket aren't making proper physical contact with the switch pins.
If it still doesn't register: Check the diode associated with that specific switch. It might have a bad solder joint or be dead/damaged.
Offline Esme_Hong
« Reply #6 on: Fri, 28 August 2026, 01:58:21 »
If it’s just three keys that suddenly stopped working, I’d first check whether they’re all on the same row/column. If they are, it could be a PCB/diode or solder issue rather than the switches themselves. A quick switch swap can also help narrow it down.
Offline Shimene
    • Web site
« Reply #7 on: Thu, 10 September 2026, 14:04:49 »
Checking whether the three keys share the same row or column seems like a good first step. That should help narrow down whether it's a trace/PCB issue or something specific to the individual switches.
