Author Topic: [IC] ASCII-F : 65TK || Plateless Top Mount - GB LIVE  (Read 54900 times)
Offline enomooshiki
« on: Fri, 26 July 2024, 13:53:33 »
ASCII-F
PCB Top Mount 65TK
When I picked up an old WYSE ASCII off Craigslist, it reminded me of a keyboard layout I desired a few years ago: a full 65% keyboard with a complete numpad that includes arrow keys, a navigation cluster (PgUp, PgDn, Home, End), and a 2u 0 (zero) key on the numpad.
Taking design cues from some of my favorite keyboards, I kept the bezel quite thin and the overall profile simple and slim.
The Plateless Top Mount provides a soft and 'bouncy' typing experience without being flexible. If soldering plateless is a daunting task for you, we will have options available for hotswap PCBs and plates.
GB LIVE
- enomooshiKey IG
- zenclack IG
- Zenclack Discord
0. CONTENTS
  • DETAILS
  • STATUS
  • VENDORS & PRICING
  • RENDERS
  • PHOTOS
  • OTHER MEDIA
  • FAQ
  • SPECIAL THANKS
1. DETAILS
  • Typing angle 7.0°
  • Front Height : 17.8mm (after cherry lip), 20mm (before cherry lip)
  • Mounting Method : Plateless Top Mount
  • PCB : Designed by Freather with Universal USB-C daughteboard - configurable with QMK/VIA
  • Solder PCB Layout Option
  • Hotswap PCB Layout Option
  • Base Kit
    - Top Case
    - Bottom Case
    - Daughter Board with JST Cable
    - Solder PCB
    - Carry Case
    - Microfiber Towel
    - Case screws
    - DB screws
    - Top Mount screws
  • Case Options
    - Alu Top + Alu Bottom
    - Alu Top + Brass Bottom
    - Alu Top + Copper Bottom (Limited Edition maybe)
  • Colors For Alu Top + Alu Bottom
    - Black Top + Silver Bottom
    - E-Beige Top + Silver Bottom
    - E-Beige Top + Black Bottom
    - E-White Top + Black Bottom
    - Silver Top + Black Bottom
  • Colors For Alu Top + Brass Bottom/Copper Bottom
    - E-Beige
    - E-White
    - Black
    - Silver
  • Weight Unbuilt
    - Alu Top + Alu Bottom = 1.34kg
    - Alu Top + Brass Bottom = 3.46kg
  • Plate Options for Hotswap PCB
    - PC
    - FR-4
    - PP
    - Alu
  • Optional Alu Wrist Rest : matching anodization or e-coat with top case
  • Indicator LED for Caps Lock and Num Lock keys
2. Status
  • Proto v1 was ordered with e-beige top and full brass bottom, along with a matching wrist rest
    - prototype PCB came with no indicator LED
    - Used the fly daughterboard
    - noticed a bit of rattling and pinging
    - rattling was caused by inaccurate PCB size. PCB was too 'tall' and making contacts with top case
    - Modified the PCB in different ways in an effort to remove pinging.
    - Minor adjustments to mounting points and case screw points
  • Proto v2 was ordered with new adjustments and new PCB design, Black Top + Silver Bottom
    - change Daughter Board to Universal Daughter Board with USB-C
    - no more rattle and pinging
    - 2 solder PCB plateless build done on twitch channel
  • Changes to be made for Proto v2.1
    - move daughterboard closer to the edge by 0.5mm
    - Solder PCB bottom row layout has changed a bit
    - Solder PCB will be in yellow. while Hotswap PCB will stay black
  • Update July 29th, 2024
    - Solder PCB color will be changed to 'orange/yellow' to closely match the original PCB color of WYSE ASCII
    - Added Split Backspace option for Hotswap PCB
    - Hotswap PCB color will be changed to 'green'
  • Update August 26th, 2024
    - Found out that orange pcb will cost significantly more. Solder PCB will be yellow
    - Prototype v3 units have been ordered. These two units, along with the v2 unit will be sent out to some content creators
    - Prototype v3 PCBs have been ordered. This round of PCBs will reflect the latest changes, including the new color for solder and hotswap PCBs.
  • Update December 27th, 2024
    - Prototype v3 units and PCBs arrived
    - prototype v3 units scheduled to be sent out to content creators
    - GB price set and updated
    - GB period from January 13th, 2025 until March 1st, 2025
3. Vendors & Pricing
  • Vendors
    -NA: Zenclack
    -Asia/AUS: Zenclack , fulfillment for Korea to be out of Busan
    -UK&EU: Prototypist
    -China: Freather's Studio
  • Price
    - Alu Top + Alu Bottom = $250 (with solder PCB) $280 (with Hotswap PCB + plate)
    - Alu Top + Brass Bottom = $450 (with solder PCB) $480 (with Hotswap PCB + plate)
    - Alu Top + Copper bottom (Limited to 10 units) = $500 (with solder PCB) $530 (with Hotswap PCB + plate)
    - Alu Wrist Rest (color matched to top case) = $50
    - Extra Solder PCB = $40
    - Extra Hotswap PCB = $45
    - Plates = $25
4. Renders
Actual coating and anodizing may look a bit different from these renders. Please use these renderings as a reference.
renders by mur1_fat
Beige Coating Top + Brass Bottom + GMK Hiney Beige
White Coating Top + Black Ano Bottom + GMK WoB
Silver Ano Top + Brass Bottom + GMK Evil Eye
Black Ano Top + Silver Ano Bottom + GMK ASCII
4 Options for Brass Bottom
5 Options for Alu Bottom
Beige Coating Top + Brass Bottom + GMK Blue Alert R2 (special render by Steven Olver)
5. Photos
Proto V1 with matching wrist rest
Proto V2 with GMK WoB Hangul
Proto V2 with GMK DMG
7. OTHER MEDIA
Typing test with Ergo Clear, Plateless, Alu Top and Bottom by TimKeyLess
Review by Keybored
Typing test with Cherry MX Black, Plateless, Alu Top and Bottom
Typing test with HMX Jammy, Plateless, Alu Top and Bottom
Typing test with BSUN BCP, Alu Plate, Hotswap PCB, Alu Top and Bottom
8. FAQ
coming soonTM
9. SPECIAL THANKS
  • My lovely wife, for putting up with my numerous hobbies
  • Tofumania, for putting my vision into Fusion 360
  • Glendel/Zenclack, for having faith in ASCII-F
  • Freather, for coming in clutch with PCB design
  • TimKeyLess, for getting me into this crazy hobby
  • Gok, for letting me use his IC page style
  • Lightning & Manoli, for helping me through IC creation
Thank you very much.
GeekHack Banner Support
If you would like to support ASCII-F, consider adding the signature below to your profile
Code: [Select]
[url=https://geekhack.org/index.php?topic=123371][img width=384 height=120]https://i.imgur.com/jYgUgbS.png[/img][/url]
« Last Edit: Mon, 13 January 2025, 23:44:05 by enomooshiki »
Offline ummmmm
Re: ASCII-F : 65TK || Plateless Top Mount
« Reply #1 on: Fri, 26 July 2024, 13:56:22 »
based layout, I am loving this
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Fri, 26 July 2024, 13:58:24 »
Oo that's a pretty work-versatile layout, and a simple but striking aesthetic to the board. Price is also very appealing. GLwIC! Looks great.
Offline TimKeyLess
    • Twitch
« Reply #3 on: Fri, 26 July 2024, 14:00:12 »
65 good. numpad good. pcb top mount good. very excite. GLWIC
Offline Kaptain Mike
  • discord: kaptainmike
« Reply #4 on: Fri, 26 July 2024, 14:01:50 »
mhm yes. good layout. good price. much good here. good job frankypoo  :cool:
Offline Bokehhbob
« Reply #5 on: Fri, 26 July 2024, 14:21:28 »
Yes on the layout!
Personally think you should add more hotswap layout support.
Split BS and Split LS wouldn’t take that much work to add, considering most hotswap pcbs come with as much layout support as solder PCB’s do now a days I think it would be a good add.
Either way I’ll most likely be in.
« Reply #6 on: Fri, 26 July 2024, 15:26:46 »
Love the variety in layouts we've been getting lately
Sent from my Pixel 7 Pro using Tapatalk
Offline MatthewEncina
« Reply #7 on: Fri, 26 July 2024, 15:42:54 »
Love the layout Frank. Love the simplicity of this. Good luck with the sale!
Offline Meepergon
« Reply #8 on: Fri, 26 July 2024, 17:04:08 »
absolutely love the layout, love the aesthetic, love the mount. excited to see this happen!
Offline Zouabee
  • i sniff
    • Zouabee.com
« Reply #9 on: Fri, 26 July 2024, 17:54:41 »
love the layout! sick design and awesome pics
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #10 on: Fri, 26 July 2024, 18:47:00 »
This is super nice, love the minimalist design language & PCB top mount sound just chef's kiss! Definitely gonna be keeping up with this one, awesome work enomooshiki!
Offline typface
« Reply #11 on: Fri, 26 July 2024, 19:39:31 »
looks amazing with a great layout to boot. glwic!
Offline Keeblord_Elf
« Reply #12 on: Fri, 26 July 2024, 21:24:25 »
 :thumb:
Offline enomooshiki
Re: [IC] ASCII-F : 65TK || Plateless Top Mount
« Reply #13 on: Sun, 28 July 2024, 03:36:57 »
Yes on the layout!
Hello Bokehhbob! Fancy seeing you here.
That's something I can look into. HOWEVER, I would highly HIGHLY suggest folks to consider solder PCB over hotswap with ASCII-F.
It was designed to be plateless.. so if you are able to solder (or find someone who can) , you shouldn't think about getting the hotswap.
Do people use Split LeftShift with ANSI?
Offline Fluxius
« Reply #14 on: Sun, 28 July 2024, 06:59:12 »
I know some people use layouts like uk-iso or german-iso with ansi enter instead of iso enter, but still keep the split left shift.
I think your layout picture for the solder pcb is missing the bottom row option shown here: https://imgur.com/9mQVv95
Offline Poesjuh
« Reply #15 on: Sun, 28 July 2024, 07:19:11 »
This is lovely!
Offline Bokehhbob
« Reply #16 on: Sun, 28 July 2024, 08:48:47 »
Yes on the layout!
Personally would get solder and do plateless, I was moreso thinking of the lines of bringing in more people interested in the board. I feel a large part of the community doesn’t solder (either doesn’t know how or want to)
Just my thoughts.
Either way excited for this board. Love the layout and plateless top mount is a chefs kiss!
Offline rodrimauricio
« Reply #17 on: Sun, 28 July 2024, 08:59:21 »
I am starting in this hobby and this will be my first solder PCB for sure. Congrats on the great effort and results you have achieved with the case design, mount, and sound. I love the layout.
Offline DaaDaa
« Reply #18 on: Sun, 28 July 2024, 09:21:29 »
Love the design. I'm in
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline DaaDaa
« Reply #19 on: Sun, 28 July 2024, 09:23:02 »
Numpad on left please as am option
Offline enomooshiki
« Reply #20 on: Sun, 28 July 2024, 10:43:38 »
haha yes yes, you are correct
the bottom row option shown in the photo will NOT be available in the final PCB design
Offline enomooshiki
« Reply #21 on: Sun, 28 July 2024, 10:44:54 »
Yes on the layout!
Just my thoughts.
I appreciate your thought.
definitely will consider adding few more options for hotswap
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #22 on: Sun, 28 July 2024, 10:58:37 »
Very cool concept! I'll also be following this closely. GLWIC
Offline Deru
« Reply #23 on: Sun, 28 July 2024, 11:18:33 »
Love the layout.  Would like there to be a (1.5u, 1.5u, 7u, 1.5u, 1.5u, arrows) bottom row layout option for solder pcb if possible.
Offline nessMINI
« Reply #24 on: Mon, 29 July 2024, 04:36:59 »
I LOVE this. I have been waiting for this layout for GOD KNOW HOW LONG. I AM IN FOR ONE FOR REAL. LET'S GET THIS GOING! :D
Offline aumz.work
« Reply #25 on: Tue, 30 July 2024, 01:40:48 »
Love the layout and simple design
Offline enomooshiki
« Reply #26 on: Tue, 30 July 2024, 01:59:56 »
Small updates on PCBs
Offline Bokehhbob
« Reply #27 on: Tue, 30 July 2024, 11:02:48 »
MVP!
Can’t wait to see content on this board.
Offline lampmk
  • box art peddler
« Reply #28 on: Tue, 30 July 2024, 16:37:18 »
Great work Frank!
Had the pleasure of trying this out the last time I was in Cali. Awesome board and I hope this makes it to GB!
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
Offline kev_kbd
« Reply #29 on: Tue, 30 July 2024, 19:11:28 »
time to learn how to use a numpad. amazing work frank!!  :thumb:
Offline gasp
  • Formerly 'boop' (NTBCW Booper)
    • none
« Reply #30 on: Tue, 30 July 2024, 21:18:09 »
looking great! loving the commitment to plateless.
Offline Bahm78
    • https://blog.naver.com/hjg7808
« Reply #31 on: Tue, 30 July 2024, 23:00:13 »
fantastic design!! :)
Offline VoodooBear
« Reply #32 on: Wed, 31 July 2024, 21:21:01 »
Numpad gud, plateless gud. Can't wait for this chonker.
Offline Cringelord
  • Crack Connoisseur
« Reply #33 on: Thu, 01 August 2024, 02:41:46 »
Layouts very hot, price very hot, simple very hot. You would probably get a higher buy in from hotswap but plateless top mount is oh so hot.
Offline jpro
« Reply #34 on: Thu, 01 August 2024, 10:56:50 »
Wow, this looks great. Definitely interested. GLWIC
Offline enomooshiki
« Reply #35 on: Sun, 04 August 2024, 17:18:24 »
IC UPDATE
Uploaded 2 typing test video in "Other Media"
Offline ToFuMaNiA
« Reply #36 on: Sun, 04 August 2024, 19:02:55 »
Looks like a good keeb to me GLWIC
Offline DaaDaa
« Reply #37 on: Sun, 04 August 2024, 20:37:16 »
So numpad of left is a no go? Have some decency
Offline enomooshiki
« Reply #38 on: Sun, 04 August 2024, 23:19:10 »
Sorry about that.
Offline bluranerd
    • Youtube
« Reply #39 on: Sun, 04 August 2024, 23:25:23 »
GLWIC! I'm not in the market for a board like this personally, but after seeing it in person at the mini keeblife, I can attest to this looking like a solid pickup for numpad enjoyers :)
Offline ThatGeologist25
« Reply #40 on: Sun, 11 August 2024, 10:21:57 »
A 65% + numpad which is a format im actualy super keen on as i don't find myself using the f row or num row of full size formats. It had a clean and simple retro aesthetic which  im really digging. the only thing extra i could want is an option for southpaw or the ability to flip to southpaw. But this looks amazing im in sign me up for a beige out of the Aus vendor whoever that ends up being.
Offline Jimmy T
  • i could use a chiropractor
« Reply #41 on: Mon, 12 August 2024, 23:46:01 »
Beautiful board and project. GLWIC and sale  :thumb:
Offline enomooshiki
« Reply #42 on: Tue, 20 August 2024, 02:34:20 »
A new typing test video is posted which showcases hotswap pcb build with alu plate.
Renders are uploaded.
Offline NHandKeebs
« Reply #43 on: Tue, 20 August 2024, 20:48:20 »
Awesome! Great aesthetic and layout. Raw aluminum version would be 👌
Offline codecoffeecode
  • refill needed by Glenn Jones
« Reply #44 on: Wed, 21 August 2024, 01:22:40 »
Really nice work Frank! GLWIC!
Offline Keebzncables
« Reply #45 on: Thu, 22 August 2024, 21:40:27 »
love the design
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #46 on: Sat, 24 August 2024, 10:42:14 »
I'm not a fan of numpads but I have to say that this board convinced me, really a great job. GLWIC!!!
Only note: I'm not too sure about the engraving on the wrist rest: it seems uncomfortable to me.
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline enomooshiki
« Reply #47 on: Mon, 26 August 2024, 03:26:19 »
Offline ObsessiveCaps
« Reply #48 on: Mon, 26 August 2024, 15:49:20 »
Definitely in for at least one of these. I'm a 65% enjoyer and love the compactness of the 2u numpad as well for when I need that near full-size experience.
Design language and inspiration is beautiful as well. A fitting tribute with a lot of careful consideration put into the project. Can't wait for the GB.
Offline enomooshiki
Re: [IC] ASCII-F : 65TK || Plateless Top Mount - GB Info Updated
« Reply #49 on: Fri, 27 December 2024, 03:23:27 »
GB info set and updated
