Author Topic: Sanity checks requested on my first build  (Read 9521 times)
Offline jfloren
« on: Fri, 26 July 2024, 14:20:20 »
I'm embarking on my first custom keyboard build, out of a desire for a keyboard that's compact but also has lots of keys, something well-suited to Unix use rather than focused on minimal size, gaming, etc. I'd really appreciate if some more experienced builders could look over my plans and tell me if I'm going wrong anywhere.
My basic plan is to get a stainless switch plate, clip the switches on the plate, hand-wire the matrix, then use standoffs to position the switch plate over a corresponding base plate. This will get it up and running quickly & cheaply, then later I hope to get a nicer case made either by 3d printing, woodworking, or metal fabrication.
I did my layout on keyboard-layout-editor.com (cribbing heavily from various Lisp keyboards) then copied the JSON data into http://builder.swillkb.com/. I selected the following options:
- Switch Type: MX
- Stabilizer Type: Costar Only (to keep the cuts simple, and based on my reading I think I want to use Costar stabilizers anyway)
- Case Type: Sandwich
- Mount Holes: 8, 3.2mm hole width (for M3 screws), 8mm edge width
- Edge Padding: 30mm top, 10mm elsewhere
I put extra padding at the top so I have a place to put the microcontroller. I picked Sandwich case type so it would generate a base plate for me.
Q: Am I going to have problems with flex due to the size of the plate? It comes out to 401x192mm.
Having generated the CAD, I downloaded the switch layer and the bottom layer, then uploaded those to Ponoko. I selected "Sheel Metal Fabrication - 304 Stainless Steel - 1.50mm" for both parts, with Human DFM Analysis for the switch plate and automated analysis for the bottom plate (since it's just a rectangle with some holes). This looks to be about $135 total.
Once I get the plate, I'll order the switches (I've got a Cherry MX sampler on the way so I can figure out which ones I want), plug them into the plate, and wire up the matrix, then connect the matrix to my microcontroller.
Q: What's the best microcontroller for a large keyboard these days? I've got 102 keys across 8 rows and 19 columns using kbfirmware.com's layout.
Once everything is wired up, mount the switch plate to the base plate, program the microcontroller, and then presumably start the process of debugging what I've wired wrong!
My current plan for keycaps is to start off with a cheap set from Amazon and fill in the rest with blanks purchased piecemeal. However, if I'm satisfied with the keyboard overall, I'd ideally like to get a set made with precisely the font and labeling I want.
Q: What's the best option for getting custom keycaps at a small scale? I have a 3d printer, but I really love the deeply spherical & glossy keycaps you find on very old terminals, so something like that would be ideal.
Offline jfloren
Re: Sanity checks requested on my first build
« Reply #1 on: Fri, 26 July 2024, 14:21:20 »
Here's the plate:
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #2 on: Sat, 27 July 2024, 14:10:25 »
The plate will be stiffer once you have the switches in there, but it might still flex in the center given how wide it is. I wonder if a few more standoffs placed between switches would keep it from potentially sagging?
Ponoko can be really expensive; I've had good experiences using SendCutSent for metal plates for much cheaper. (Note: Never, ever use SendCutSend for plastic. I've ordered sets of identical acrylic plates from them, only to have some arrive too long or short, with randomly-sized drill holes, and switch cutouts off by 3-5mm in any given direction.) But for aluminum, steel, and brass plates, they've always been perfect.
Offline jfloren
« Reply #3 on: Mon, 29 July 2024, 10:38:58 »
I'll compare SendCutSend, thank you!
I'm currently thinking about turning all those 2U keys around the sides, top, and below the spacebar into 1.5U keys just to cut down on the sheer number of stabilizers I'd have to install... it would also reduce the width just a smidge. On the other hand, it would mess up the alignment with the 1U keys on the bottom right...
Offline wjrii
« Reply #4 on: Mon, 29 July 2024, 19:58:00 »
Your basic approach should work absolutely fine, and frankly it will be immensely satisfying if you feel like it's something you want to do. Weird, completely bespoke boards that are still pretty cheap is exactly the spot in the hobby I've become most comfortable, and I love it.
Price wise, I found Xometry gave me a good quote for some TKL-size aluminum plates.  I also use my 3D printer and cheap diode laser to do them at home.  Your uploaded pic might be a touch older, but looking at it, I'd say that going with the eight perimeter mounting holes you mentioned would be better than four, certainly at least six, and one or two standoffs in the middle-ish would do you well, even with steel.  That's not a HUGE board, but it's not small either and it's taller than many.  You can always leave a screw out if you have them put in too many holes, but drilling new ones accurately is not going to be a lot of fun, finally, make sure you fillet the corners, either in swill or in a 2D CAD program.  Don't want nasty sharp corners.
Layout, and specifically how it interacts with commercially available keycap kitting becomes the other thing you're going to have to deal with.  Only you can know what's really important to you, but one of my struggles has been finding cost-effective keycaps that fit my layouts.  This is especially true for sculpted profiles like Cherry and MT3.  For instance, I make a lot of boards that need a 1.25u capslock key.  Every set comes with tons of 1.25u, but very few for Cherry sets (to give one example) are in the correct shape for Row 3, and when they are they often have "tab" as the legend because they're intended for 40% keyboards. Looking at your layout, 2U top-row keys won't be hard to source, but that many will get pricy and you will have a lot that are either blank or say "Backspace." Similar situation with those bottom row ones and "0."  You could pull something together with XDA, which has blanks available for pretty cheap, and eventually DSA or R3 SA could provide a slightly more high end experience while still having the kitting work out.  Every time I try to price out dye-subbed SA in PBT from Signature Plastics, it comes out to about $160, and I only needed about four or five keys that weren't in some sub-kit.  Do some window shopping on AliExpress and Amazon, and decide where and how you want to compromise, and think about whether accurate legends are important to you.
Like I said though, there's nothing like using your own creation as a daily tool, and we're fortunate that a DIY keyboard can work just as well and feel as nice as, if not the tippy top of the custom keyboard scene,  then a very solid mid-range mechanical board.
EDIT to add:  I've done 102 keys with a sane matrix layout on a Rasperry Pi Pico, or rather a clone with USB-C. Lots of GPIO, MHz to spare, and rather cheap.    It is supported by QMK/Via now, and the new POG application walks you through generating and maintaining a Python based KMK firmware.
« Last Edit: Tue, 30 July 2024, 08:18:42 by wjrii »
Offline jfloren
« Reply #5 on: Tue, 30 July 2024, 13:18:25 »
Thanks, this is good info!
I think adding another standoff in the middle is a good idea; with a little fiddling in swill I got a custom 3.2mm hole right between some keys near the center... I assume there's still enough material left that the cutter won't make a mess of it:
The keycap kitting is a real challenge for me so far. I'm seeing lots of pleasant-colored kits on AliExpress but as you say, the bottom row and the 2U keys around the edges are a real challenge. I'm not sure how grotesque it would look if I just slapped something like https://www.amazon.com/Tqyijhy-Personality-Supplement-Multiple-Accessory/dp/B0D2517MS4 on those... Now, if I went with a flat profile across the whole thing, like on my Ergodox, it would probably work out ok?
Offline wjrii
« Reply #6 on: Tue, 30 July 2024, 15:32:59 »
For my plates these days, I use swill for the basic switch layout, because "ain't nobody got time for that," but I've taken to importing the DXF files into a 2D CAD program (LibreCAD comes to mind, though even Illustrator and Inkscape can be made to work) and doing adjustments and additional cuts myself.  I think for steel you should be fine with that placement; your average steel-plate gamer board will have screwholes with a similar amount of shoulder.  If you're feeling nervous, plopping a couple down inside of your main mods (e.g. Tab, Caps, Enter) on R2/R3 ought to let you be balanced while having plenty of meat to cut into.
Your idea for keycaps should work perfectly if you stick with XDA (I think those 2u are XDA... could be wrong... poorly worded listing), and if you mix profiles, that's up to you, though if you do, for aesthetics I'd consider maybe splitting them out from the main block and still being mindful of average heights. Usability wise, the LISP boards you mentioned (Space Cadet and Symbolics stuff?) must have been pretty usable, but I don't know that I've ever seen one with keys below the spacebar.  Make sure your typing style really accommodates that. In the end though, it's your board; I make crap like THIS, so what do I know?  :p
A thought occurs that https://fkcaps.com/ might be right up your alley;  either do the whole thing with them or find a reasonably priced set in one of the profiles they have, in order to get your basics, and use them to supplement.  It's also possible to do an okayish job dye-subbing at home with a straightening iron or laser engraver (see the white enter keys from that pic I posted).
« Last Edit: Tue, 30 July 2024, 15:34:48 by wjrii »
Offline jfloren
« Reply #7 on: Tue, 30 July 2024, 16:28:03 »
fkcaps.com seems like exactly the thing for my custom 2U keys! I wish there were other colors available, but I'm thinking maybe I could get a cheap colorful XDA set like https://www.amazon.com/Keycaps-Dye-Sublimation-Switches-Mechanical-Keyboard/dp/B0BHWHZR13?th=1 for the alpha keys and just buy all the mod keys in plain grey for a nice contrast.
