Author Topic: [In Stock] BK75 Keyboard(3-In-1 Wrist rest, Dust cover, Keyboard display stand)  (Read 8137 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
BK 75
A Keyboard With a Built-in Wrist Rest
Discord | Instagram | TikTok
Intro
Hello guys. Today, we are thrilled to introduce a keyboard designed and manufactured by Bat Knight studio–BK75.
Gallery
Pink
Black Pink
Ink Black
Somke White
Cream White
Glory Black
Milk White
Description
Get ready for the ultimate typing experience with our BK75-WIRELESS mechanical keyboard! With 82 gasket-mounted keys, hot-swappable switches, and a wrist rest with a dust cover and display stand, there are 2 types of wrist rest to choose, you'll have a customizable and comfortable setup. Plus, it can automatically turns on or off with the magnetically removable metal cover. For connectivity, you can choose from Bluetooth, 2.4G, or wired connectivity and enjoy low-latency response.
Highlights
1. 82 keys gasket mount design, hot-swappable switches gaming keyboard
2. Wrist rest, dust cover, keyboard display stand 3-in-1
3. Use the Hall switch/sensor, the keyboard will automatically turn on or off when the Wrist rest is covered or spread
4. Removable magnetic keyboard top metal cover
5. Bluetooth+ 2.4G+ Wired, Supports up to 3 Bluetooth Devices, Low-latency Fast Response
6. Full-key with Rogers Poron Switch Pad
7. Customized POM switches, office or gaming are both suitable
8. Two-stage system switch and footstand
9. Wrist rest, dust cover, keyboard display stand 3-in-1
11. The wrist rest can be used as a dust-proof cover, which in turn can be used as a keyboard display stand.
12. The wrist rest is detachable.
13. The contact surface between the wrist rest and the wrist is made of aluminum alloy, and the overall touch is delicate.
14. Hall switch/sensor intelligent magnetic control power supply
15. The Hall switch controls the keyboard light through the magnet on the handrest and the switch device inside the keyboard
16. When the handrest is turned over into a dust cover, it can automatically power off and sleep.
17. When the handrest is unfolded, the power can be awakened to resume normal operation, preventing the dust cover from being accidentally touched and effectively protecting data intelligently.
Specifications
Case Material: Plastic
Brand: Bat Knight
Keyboard name: BK-75
Number of keys: 80/82 keys+1 knob
Mount: Gasket mount
Product net weight: 1.4KG
Size: 327mm*150mm(Wrist rest 90mm)*46mm
Front height: 20mm
Connection: Type-C
Battery capacity: 4000mAh
PCB: flex cuts, 1.2mm thickness
Wireless transmission distance: max around 8–10 meters
Backlight: RGB, with programmable software
OS support: Compatible with WIN, MAC OS
Anti-ghosting keys: Full keys
Cable length: 1.5m
Typing Test
Popular Review
SeungupKBD
Wabi Sabi
Samuel Tan
리뷰녀
benfromsg
Edwardtanujayaa
If you want to see more reviews, please check them on our product page!
Price
From 79USD
Sale Format
In Stock
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions! :)
« Last Edit: Wed, 15 January 2025, 00:54:51 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline john08099
  • Velocifire MK
  • * Moderator
All Pink BK75 (Special edition) has been released!!!🌹🐱🌿
🌹Design
Adorned with delicate rose motifs, the keyboard’s keycaps and hand rest are intricately designed to evoke a sense of romance. The soft pink and white accents add a touch of luxury to your desk.
🌹Keyboard name: BK75
🌹Keyboard color: Pink (Promise of Rose)
🌹Wrist rest surface: Leather
Offline getrxrarea
Many online games involve playing classroom 6x with others, requiring players to communicate, cooperate, and work together towards a common goal. This fosters teamwork and collaboration skills.
Offline ColeHarry
Love it. I think play this escape road game with these keyboard keys are awesome.
