Author Topic: [IC] PlaketXL by Flatbrains! | GB Ended  (Read 19735 times)
Offline louckousse
Re: [IC] PlaketXL by Flatbrains! - 60% with double f-row
« Reply #50 on: Tue, 24 September 2024, 09:41:54 »
I've updated the first post with new vendors joining us. We now have a nice coverage.
We also decided to run the GB from November 5th to December 5th.
Last but not least, I heard you and I started working on a hotswap PCB. Doing my best to be able to propose it for the GB.
Thanks for the support so far, we're really happy with the reception, it means a lot. ♥️
« Reply #51 on: Tue, 24 September 2024, 10:12:21 »
Definitely interested in this one
Sent from my Pixel 9 Pro XL using Tapatalk
Offline actionbastard
« Reply #52 on: Fri, 11 October 2024, 11:30:50 »
Maybe dumb question but what size spacebar do I need for this in wk format?
Offline Prelim
« Reply #53 on: Fri, 11 October 2024, 11:39:52 »
7u spacebar as it is (WKL)
if last row was WK, then 6.25u
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline jd
« Reply #54 on: Mon, 14 October 2024, 13:47:56 »
100% in, though it would be nice to have a hotswap pcb option if possible.
Offline Woovie
« Reply #55 on: Sat, 02 November 2024, 01:25:58 »
I unfortunately assumed the pricing on clickclack was accurate, and was really excited. I think it's a great design but not in a 400+ mood right now in the hobby. Good luck with your GB, it's a beautiful board!  :thumb:
Offline kbd0
« Reply #56 on: Sat, 02 November 2024, 18:36:27 »
Always been a fan of old boards with layouts like this. Lots of keys without losing mouse space and looks really good. GLWIC
Offline FoxandFoundry
« Reply #57 on: Tue, 05 November 2024, 20:36:06 »
Is there a way to do red and silver? Also is the main promo shot red and silver or red and beige (the group buy choice) because it looks like silver to me?
Offline louckousse
Re: [IC] PlaketXL by Flatbrains! | GB Live from November 5th to December 5th
« Reply #58 on: Wed, 06 November 2024, 17:04:15 »
Hey folks!
Quick update: The GB is now live until Devember 5th!
You can find the list of vendors and links to product pages in the first post.
We've tried to listen to your feedback as much as possible, so here are a few changes:
- Hotswap PCB is now available! (with the keyboard kit and as an extra)
- Extra plates : Alu silver w/ flexcuts and clear PC w/o flexcuts
- Accent and top pieces available separately
- the black kit now comes with a red alu plate instead of a silver one
Unfortunately, we're unable to create a thread in the GB section of the forum.
For this reason we'll use this IC thread's second post for updates about the GB as well.
Bisous !
Offline louckousse
« Reply #59 on: Wed, 06 November 2024, 17:08:10 »
The promo shot (wasn't really a promo shot tbh) is in silver/red because we used early unit before even doing this GB. We used the pictures because they are beautiful and show well the design of the keyboard. But yeah unfortunately we decided to not go with silver/red for the GB because we felt that beige/red was more close to the retro vibe we wanted. Having silver/red also would have been redundant, so silver/blue appeared.
The closest you can get is by ordering a modern blue with red accent as extra. You'll only miss the red plate.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #60 on: Thu, 07 November 2024, 03:10:37 »
me likey
