Author Topic: Amiga keycaps profile  (Read 6293 times)
Offline phinix
« on: Mon, 23 September 2024, 09:43:14 »
I was wondering, what was Amiga keycap profile and is there any new/in production profile that is close to it?
I would like to have something like that mounted on modern cherry mx switches :)
310056-0
Offline HungerMechanic
Re: Amiga keycaps profile
« Reply #1 on: Mon, 23 September 2024, 11:53:39 »
To be honest, Amiga keycaps always struck me as not too-far-off, conceptually at least, from WYSE keycaps:
Sure, the font, colours, and legending methods are not identical. But they are comparable.
Look at the WYSE numpad arrows. The philosophy is not that different.
So if you wanted something conceptually similar, you could get some old WYSE keycaps, restore them, and use a Moogle kit. Or maybe SP could produce something close to Amiga-styled keycaps in DCS. They already produce some of the obscure longer keys and uncommon legends.
« Reply #2 on: Mon, 23 September 2024, 12:05:15 »
Looks as if there have been some attempts to create Amiga tribute keyboards and keycaps:
1. Amiga-style keyboard for PC
https://www.reddit.com/r/keyboards/comments/n2pbxz/til_a_company_is_making_amiga_style_keyboards_for/
2. Amiga Cherry-profile keycaps
https://audiophilestyle.com/forums/topic/25443-commodore-amiga-keys-for-your-pc-cherry-mx-keyboard-kickstarter-campaign/
3. New keycaps for Amiga
https://www.a1200.net/shop/amiga-keycaps-a1200-theme/
I think the imitation Cherry-keycaps look pretty crude. The a1200.net people might be able to produce their new Amiga keycaps in an MX-compatible format as well, who knows?
« Reply #3 on: Mon, 23 September 2024, 12:31:43 »
There were a few different types of Amiga keyboards, including Cherry-made keyboards with Cherry-profile doubleshots, but I suppose you mean the Mitsumi KPR type.in the Amiga 1200 in the picture.
I have an Amiga 1200 and 500 with Mitsumi keys right here, and compared against Cherry (from an Amiga 2000), DCS and OEM profiles.
The keys are a little bit sunken into the case, i.e. the skirt is not aligned with the top surface of the computer case.
The keycap height is similar to OEM profile but the angles are in-between that of Cherry and DCS. The top two rows are completely flat, and the other rows are more angled than Cherry profile but not as much as DCS.
If I lay Cherry profile on top of the Amiga's case surface, the keys are the same height, meaning that if the skirts had been that height the key height would be identical as well.
I suspect but can not confirm that other Mitsumi keyboards had the same profile.
« Last Edit: Mon, 23 September 2024, 12:33:29 by Findecanor »
« Reply #4 on: Mon, 23 September 2024, 12:34:00 »
Thanks, Findecanor. That's helpful.
Amiga keycaps seem to be very similar to the other low-profile cylindricals of the day.
For Phinix, these people might be producing Amiga-style MX-keycaps:
https://www.checkmate1500plus.com/Products.aspx?id=371
« Reply #5 on: Mon, 23 September 2024, 12:37:40 »
I believe the final result of that project did not look like that but was a standard Cherry MX keyboard with OEM-profile keycaps.
BTW, there have also been several projects creating replacement keyboards for Amiga computers with Cherry MX (-alike) switches. A couple have changed the bottom row a bit, presumably because their keycap source did not offer 9u space bars.
« Last Edit: Mon, 23 September 2024, 12:46:53 by Findecanor »
Offline phinix
« Reply #6 on: Mon, 23 September 2024, 16:35:01 »
Yeah, you see, I like the top of the keycaps, their profile is not same as cherry mx, kinda flat and wider, edges not the same too. Plus finish is different, I mean I never tried brand new Amiga, but it feels a lot more like well used cherry mx caps, slightly shiny and smooth.
