Author Topic: [IC]EQUILIBRIUM 6 R2 by SCRIBBLEB for International  (Read 7495 times)
Offline SCRIBBLEB
  • never give up on pursuing your hobbies
    • SCRIBBLEB
« on: Fri, 27 September 2024, 16:19:01 »
Index
1. INTRO
2. DESIGN
3. SPECIFICATIONS
4.LAYOUT
5. CONSTRUCTIONS
6. COLOR OPTIONS
7. PRICING
8. VENDOR
9.KIT REAL-WORLD DISPLAY
10. MEDIA
1. Intro
Hello everyone, we are SCRIBBLEB (an abbreviation for SCRIBBLE LEB).After a year and a half of hard work, we proudly introduce the EQUILIBRIUM layout mechanical keyboard kit, featuring an extremely symmetrical design with custom function keys evenly distributed on both sides. The exclusive cyberpunk-inspired mother-of-pearl inlay backplate combines traditional craftsmanship with modern personalized design, with colors changing based on the viewing angle. Each backplate is unique. R2 will soon be available for sale, and we are recruiting regional agents worldwide.
2. Design
Light (Open and close independently)
Front
Back
The inner oblique cut of the weight and the badge
   The inner oblique cut of the USB interface surface
3.Specifications
- Layout: 4+60+4 / 4+64+4
- Mounting system: Bottom mount and battery cover plate mount
- Typing Angle: 5°
- Plate:Plate: 1.5mmPC , 1.5mmFR4
- PCB: 1.2MM(Hot-swap)
-Connection modes:1.Single mode (supports VIA/QMK)
                             2.Tri-mode (2 x 1200mAh batteries + 2.4G receiver)Wired, Bluetooth, 2.4G (does not support VIA/QMK)
- Weight after assembly: ± 1600g (aluminum kit)
Parts included with the kit:
-Keyboard case: Alu top case / alu bottom case
- Battery cover
- Badge
- Weight
- Plate
- Hot-swap PCB
- 2.4 Receivers
- Daughterboard cable
- Batteries 1200mAh x 2
- Light guide silicone gel
- 4X custom-designed rubber feet
- 12X gasket silicone pellets
- Poron cotton
- Poron sandwich cotton
- Ixpe pad
- Light-blocking foam
- Hand-carry keyboard bag
4.Layout
Optional slotted or unslotted PCB, with the choice of hot-swappable tri-mode (does not support VIA) or hot-swappable single-mode (supports VIA/QMK).
4+WK+4
4+64+4
2u backspace can replace with 2 1u
5. CONSTRUCTIONS
•Size
• Inner padding mounting method(two options)
1、Silicone pellets
Assembling effect
2.Poron
6. Color Options
•Case
-Anodized Aluminum
Bottom case
Top case
The colors of the anodized top and bottom covers can be freely mixed and matched.The following pictures are only part of the mix and match display.
- Spray Coated Case(Spray-coated with glitter)
Sparkling Gray、Sparkling Black、Sparkling White(The colors of the Sprayed Coating top and bottom covers also can be freely mixed and matched.)
Spray coated finish by Sparkling Gray and Black.The image cannot fully capture the sparkling effect of the keyboard's coating.
•Weight
4 Patterns to choose from
In addition to patterns, there are various surface finish options for the weight, including sandblasted matte, polished mirror, and glitter-coated finishes.
The real product photos will be introduced next.
-Mother-Of-Pearl inlay Weight
Green Shell, Luminous Shell, and Abalone Shell。Three types of inlays are shipped randomly.
Combining traditional craftsmanship with modern personalized design, also known as "Cyber Mother-of-Pearl".
Each mother-of-pearl inlay is set by hand, which is time-consuming, labor-intensive, and has a high material loss rate.
However, the result isfantastic! Please note: Due to different angles, the glossy effect varies. Each mother-of-pearl counterweight is unique and cannot be identical to thereference picture.
Please refer to the actual product received for the final appearance.
The color changes when you look at it from different angles.In the R2 group purchase, the central stripe and numbers do not have mother-of-pearl inlays.
- Plain Stainless Steel Weight (No Pattern)
- Graffiti  Weight(Mirror/Spray Coating)
Graffiti /Spray Coating/Black
Graffiti /Mirror/Black
- Forest Weight(Mirror/Spray Coating)
Forest/Mirror/Black
Forest/Spray Coating/Black
•Badge
Stainless Steel / Sandblasted / Gold
Frosted Transparent(PC)
Stainless Steel / Mirror /Steel Color
Stainless Steel / Mirror /Black
•Battery cover
Battery cover free choice, included in the kit.
7.Pricing(Est.)
Tentative price, up to $25 variance.
Mother-of-pearl inlay weight is not available for additional purchase.
8.Vendor
Recruiting regional agents worldwide.
Discord: https://discord.gg/uPqMHy4TpB
9. Kit Real-World Display
The actual effect of freely combining the case, weight, and Badge of the kit.
- Anodized Sliver(Top:Sliver, Bottom: Sliver) + Mother-of-pearl inlay Weight + Stainless Steel / Mirror / Steel Color Badge
-  Anodized Deep Red (Top:Red , Bottom :Red ) + Mother-of-pearl inlay Weight + Stainless Steel / Sandblasted / Gold Badge
- Anodized Navy Blue (Top: Blue, Bottom: Blue) + Forest /Mirror Finish / Black Weight + Stainless Steel / Mirror / Black Badge
- Anodized Black (Top: Black, Bottom: Black) +Graffiti / Spray Coating / Black Weight +Frosted Transparent(PC)Badge
- Anodized Black & Red (Top: Black, Bottom: Black) +Graffiti /Mirror Finish / Black Weight + Frosted Transparent(PC)Badge
- Spray Coated Sparkling Gray (Top: Gray , Bottom: Gray )+Stainless Steel /Mirror/Black Weight (No Pattern)+Stainless Steel / Sandblasted / Gold Badge
- Spray Coated Sparkling Black (Top: Black , Bottom: Black )+Mother-of-pearl inlay Weight +Frosted Transparent(PC)Badge
10. Media(R1 Dual mode version)
https://www.bilibili.com/video/BV1Mi4y1z7fh/?spm_id_from=333.1350.jump_directly&vd_source=55d38caab3f5af674c6819b0198440c6
Anodized Deep Red  (Top: Red , Bottom: Red )
https://www.bilibili.com/video/BV1Hw41137aK/?spm_id_from=333.1350.jump_directly&vd_source=55d38caab3f5af674c6819b0198440c6
Anodized Black  (Top: Black , Bottom: Black)
https://www.bilibili.com/v/jump-middle-edge/?spm_id_from=888.80997.embed_other.whitelist&bvid=BV1kT4y1W7hA&mode=play
Anodized Black & Red (Top:Black , Bottom :Red)
https://www.bilibili.com/video/BV1v5411B7ER/?spm_id_from=333.1350.jump_directly
Anodized Green (Top:Light green , Bottom :Green )
https://www.bilibili.com/video/BV19t4y1f7AL/?spm_id_from=333.1350.jump_directly&vd_source=55d38caab3f5af674c6819b0198440c6
Spray coated Sparkling Gray Black &  Sparkling  Gun Gray
https://www.bilibili.com/video/BV14t4y1f7xg/?spm_id_from=333.1350.jump_directly
"If you're interested in our keyboard, please join our Discord: https://discord.gg/uPqMHy4TpB. Share your suggestions and feedback, and stay updated on our latest developments. Additionally, we're looking for reliable vendors. If you're interested, please contact us via Discord.
Thanks for viewing!"
Re: [IC]EQUILIBRIUM 6 R2 by SCRIBBLEB for International
« Reply #1 on: Fri, 27 September 2024, 18:57:37 »
Have you reached out to any reputable vendors in the US yet?
Offline SCRIBBLEB
    • SCRIBBLEB
« Reply #2 on: Fri, 27 September 2024, 21:40:21 »
Not yet, and I don't really know which channels to contact
« Reply #3 on: Fri, 27 September 2024, 21:45:19 »
I'd reach out via email to vendors like NovelKeys, Cannonkeys, DangKeebs, or Divinikey. They've all done group buys with international partners at varying scale and are good about communication and fulfillment
Offline SCRIBBLEB
    • SCRIBBLEB
« Reply #4 on: Fri, 27 September 2024, 22:17:13 »
Thanks for your help.my friend.
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #5 on: Fri, 27 September 2024, 22:56:27 »
This looks so freakin COOL. Definitely interested in this one.
Offline KeebDweeb_
    • KeebDweeb
« Reply #6 on: Fri, 27 September 2024, 23:23:05 »
Count me in for at least 1.  This is dope
Offline KeebDweeb_
    • KeebDweeb
« Reply #7 on: Fri, 27 September 2024, 23:26:24 »
3.Specifications
- Typing Angle: 5°
Any chance we can get a 1.6mm PCB Hotswap and Solder
« Last Edit: Fri, 27 September 2024, 23:29:43 by KeebDweeb_ »
Offline SCRIBBLEB
    • SCRIBBLEB
« Reply #8 on: Sat, 28 September 2024, 00:26:49 »
3.Specifications
- Typing Angle: 5°
yes,I'll add this option to the GB
Offline KeebDweeb_
    • KeebDweeb
« Reply #9 on: Sat, 28 September 2024, 01:47:00 »
3.Specifications
- Typing Angle: 5°
Fantastic news, thank you very much
Offline kennnyshiwa
« Reply #10 on: Mon, 30 September 2024, 20:47:59 »
Definitely interested and in for one, especially with that mother of pearl inlay! Would also be potentially cool to maybe try out an orange color and see how it works with the designs, I feel like it would go well with most of those weight designs you've posted.
