Author Topic: In search of the perfect THOCK  (Read 5175 times)
Offline Igorzjeh
« on: Sun, 06 October 2024, 02:15:15 »
Hi guys!
So as the subjects says, I am in a search for a perfect deep thock sound of my new keyboard. And since this is my first build i am doing extensive search for a perfect switch! I am building a Zoom65 v2.5, it's been in my closet for months now, and it's time to start building!  :thumb:
In my search for a perfect switch i have read numerus posts, looked and a lot of youtube videos and soud tests and the conclusion is that there is just to many options. So I need your help! I have narrowed my choice to:
- KTT Strawberry
- WS Morandi
Is there anyone that had both options so they can give me a first hand review? Or you can comment on your experience on each of them. Or maybe my choice is not that good and you can add another switch to the mix?  ;D :-\
Furthermore I would like to know what would you recommeng - lube, lube + film. Or nothing since they are prelubed?
Thanks for the help!
Offline QWER|key
Re: In search of the perfect THOCK
« Reply #1 on: Mon, 14 October 2024, 00:25:45 »
I read "I've been in the closet for months now" LOL
Offline Igorzjeh
« Reply #2 on: Mon, 14 October 2024, 02:30:53 »
 ;D
still no recommendations, so i've ordered Morandi.
Offline reflectivebank
    • space waves
« Reply #3 on: Mon, 14 October 2024, 02:55:30 »
Lube, Film, or Neither?
Lube and film can significantly alter the feel of a switch. Here's a breakdown:
Lube: Applying lube to the contact points can reduce friction and make the switch feel smoother. It can also help to dampen the sound.
Film: Adding a film can change the tactile feel of the switch, making it more or less pronounced.
Whether or not to lube or film depends on your desired feel. If you want a smoother and quieter switch, both lube and film can be beneficial. If you prefer a more tactile experience, you might consider only using lube.
Remember: Experimentation is key! You can always try lubing or filming a few switches and see how you like the result.  :thumb:
« Last Edit: Mon, 14 October 2024, 02:59:06 by reflectivebank »
Offline Igorzjeh
« Reply #4 on: Mon, 14 October 2024, 03:08:39 »
Thanks for the info!
I was just thinking about that - you need to try every soluiton, there is no other way.
Offline pixelpusher
« Reply #5 on: Mon, 14 October 2024, 10:47:36 »
Aaand, that's how you end up like me with hundreds of keyboards and thousands of switches.  It is true that in order to fully evaluate you would need to try all of the options.
Top mount, sandwich mount, tray mount, leaf spring, gasket mount, 0-ring mount, metal case, plastic case, wooden case, ceramic case, silicone case, PE foam, plate foam, case foam, tape mode, force break mod, stabilizer type and mods, lubed switches (oil vs thin grease vs thick grease vs a combination), lubed springs, filmed switches (poron vs PC), tactile switches, linear switches, clicky switches, every combination of every type of switch bottom and top housing material, all switch stem materials and pole length, every length of spring in every weight, keycap profile (MT3, DSA, SA, GMK, MTNU, DCS, DSS, etc..), keycap material (PC, ABS, PBT, POM, etc..)
And there are a lot of things I'm probably overlooking.  Imagine the sheer number of permutations there are and almost every single one results in a different sound.
Sometimes, you have to tell yourself it's okay to be content with what you have.  Know there may be a better solution, but there are also many worse.
However, for generalizations, a "thock" sound is often true each of the following:
Softer switch bottom housing material (like POM), lubrication with grease, light to moderate spring weight, long-stem pole, using 1.5mm or thicker keycaps, cases that keep the bottom of the keycap slightly recessed below the bezel, a non-metallic case that has some resonance in the bottom (not too stuffed), a stiffer yet non-metallic plate (something like FR4)
I found when looking for a good deep thock sound that some of these above listed options actually took the sound too far into a muddy, dampened sound.  For instance, grease is great for toning down clacky switches, but if you accidentally get too much on the stem pole, it might result in an uneven and muted thock.  And POM is a great housing material, but again, it can actually sound limp and muted without the proper stem, spring, and lube setup.
« Last Edit: Mon, 14 October 2024, 11:32:08 by pixelpusher »
