Author Topic: 65% ISO Hotswap 2.4GHz keyboards (links updated:28/Feb/2025)  (Read 9561 times)
Offline jackcalico
« on: Sun, 06 October 2024, 10:10:43 »
Hi all,
As there are not that many 65% ISO Hotswap 2.4GHz custom mechanical keyboards, I thought I would create a thread to keep track of them. I was already bookmarking all the ones I found, and hopefully keeping track of them here will help more people (and let me discover keyboards that I had missed).
Zoom65
QK65
Neo65
Luminkey65
Tess65
Fox65
KV1-65
POLYGON-7
Neo65 CU
« Last Edit: Fri, 28 February 2025, 01:08:31 by jackcalico »
Offline jackcalico
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:06/Oct/2024)
« Reply #2 on: Mon, 07 October 2024, 00:43:03 »
Enter67
As much as I would like to add it, I don't see ISO layout support on that board.
Offline jackcalico
« Reply #3 on: Sun, 20 October 2024, 11:03:16 »
It's a GB, but hey, it checks all the boxes: Tess65
Offline jackcalico
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:20/Oct/2024)
« Reply #4 on: Sat, 26 October 2024, 10:16:57 »
Looks like we have a new one: Fox65
Offline MarkXT9000
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:26/Oct/2024)
« Reply #5 on: Sun, 27 October 2024, 06:01:43 »
Hi all,
Zoom65
QK65
Neo65
Luminkey65
Tess65
Fox65
Lucky65 V2
Offline jackcalico
« Reply #6 on: Sun, 27 October 2024, 07:53:45 »
Lucky65 V2
Does the Lucky65 support ISO layout? I can't seem to find any spec or pic that shows that.
Offline lorde
« Reply #7 on: Tue, 19 November 2024, 21:36:17 »
Hi all,
Zoom65
QK65
Neo65
Luminkey65
Geometry Dash
Tess65
Fox65
It's great that you're compiling a list of 65% ISO Hotswap 2.4GHz custom mechanical keyboards! These types of boards are becoming increasingly popular due to their versatility and wireless functionality.
Offline jackcalico
« Reply #8 on: Thu, 05 December 2024, 14:45:16 »
New GB, this time from Velocifire: KV1-65
Offline GrayMatter4tw
    • @pump_upp - best crypto pumps on telegram !
« Reply #9 on: Tue, 10 December 2024, 15:32:53 »
Great list, thanks for sharing! I've been looking for a 65% ISO hotswap option, and this is super helpful. Out of these, do you have a personal favorite or any thoughts on their wireless performance? I’ve heard good things about the Zoom65 but haven’t tried it myself.
Offline jackcalico
« Reply #10 on: Wed, 11 December 2024, 01:14:26 »
As always in this hobby, this is a matter of preference. From this list, my favorite is probably the QK65, but lately, I have enjoyed the Luminkey65 quite a lot.
Offline jackcalico
« Reply #11 on: Fri, 07 February 2025, 13:26:27 »
Not exactly an orthodox 65%, but close enough: POLYGON-7
Offline jackcalico
« Reply #12 on: Fri, 28 February 2025, 01:06:55 »
One more from QK: Neo65 CU
Offline timd
« Reply #13 on: Fri, 28 February 2025, 16:22:05 »
I have a Lucky65 in ISO format.
My only current issue is that the left shift comes in long size (2.25). The PCB has positions for short shift + "|" key, but has no hotswap sockets soldered in for them - it just has a central hotswap socket for the long left shift key.
I've desoldered the long shift hotswap and soldered in new hotswap sockets for short shift and "|" key, my only issue is that the "|" key is being recognised as another "z". According to my multimeter, the two switches are not wired the same way. I just need to work out how to alter the via json to map it correctly.
Offline jackcalico
« Reply #14 on: Sat, 01 March 2025, 00:29:08 »
You may want to reach out to the vendor and/or manufacturer as that is quite odd, mine had the correct hotswap sockets right out of the box.
Offline calvin2sr
« Reply #15 on: Thu, 27 March 2025, 03:55:53 »
Where do you buy the lucky65 v2 iso plate with small left shift? I don't find it anywhere. Thank you.
Offline jackcalico
« Reply #16 on: Thu, 27 March 2025, 07:46:24 »
I bought mine at DeltaKeyCo, but they no longer sell them. You may want to contact other vendors, like CandyKeys or CoffeeKeys.
