Author Topic: 65% ISO Hotswap 2.4GHz keyboards (links updated:28/Feb/2025)  (Read 25382 times)
Offline jackcalico
« on: Sun, 06 October 2024, 10:10:43 »
Hi all,
As there are not that many 65% ISO Hotswap 2.4GHz custom mechanical keyboards, I thought I would create a thread to keep track of them. I was already bookmarking all the ones I found, and hopefully keeping track of them here will help more people (and let me discover keyboards that I had missed).
Zoom65
QK65
Neo65
Luminkey65
Tess65
Fox65
KV1-65
POLYGON-7
Neo65 CU
« Last Edit: Fri, 28 February 2025, 01:08:31 by jackcalico »
Offline jackcalico
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:06/Oct/2024)
« Reply #2 on: Mon, 07 October 2024, 00:43:03 »
Enter67
As much as I would like to add it, I don't see ISO layout support on that board.
Offline jackcalico
« Reply #3 on: Sun, 20 October 2024, 11:03:16 »
It's a GB, but hey, it checks all the boxes: Tess65
Offline jackcalico
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:20/Oct/2024)
« Reply #4 on: Sat, 26 October 2024, 10:16:57 »
Looks like we have a new one: Fox65
Offline MarkXT9000
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:26/Oct/2024)
« Reply #5 on: Sun, 27 October 2024, 06:01:43 »
Hi all,
Zoom65
QK65
Neo65
Luminkey65
Tess65
Fox65
Lucky65 V2
Offline jackcalico
« Reply #6 on: Sun, 27 October 2024, 07:53:45 »
Lucky65 V2
Does the Lucky65 support ISO layout? I can't seem to find any spec or pic that shows that.
Offline lorde
« Reply #7 on: Tue, 19 November 2024, 21:36:17 »
Hi all,
Zoom65
QK65
Neo65
Luminkey65
Geometry Dash
Tess65
Fox65
It's great that you're compiling a list of 65% ISO Hotswap 2.4GHz custom mechanical keyboards! These types of boards are becoming increasingly popular due to their versatility and wireless functionality.
Offline jackcalico
« Reply #8 on: Thu, 05 December 2024, 14:45:16 »
New GB, this time from Velocifire: KV1-65
Offline GrayMatter4tw
    • @pump_upp - best crypto pumps on telegram !
« Reply #9 on: Tue, 10 December 2024, 15:32:53 »
Great list, thanks for sharing! I've been looking for a 65% ISO hotswap option, and this is super helpful. Out of these, do you have a personal favorite or any thoughts on their wireless performance? I’ve heard good things about the Zoom65 but haven’t tried it myself.
Offline jackcalico
« Reply #10 on: Wed, 11 December 2024, 01:14:26 »
As always in this hobby, this is a matter of preference. From this list, my favorite is probably the QK65, but lately, I have enjoyed the Luminkey65 quite a lot.
Offline jackcalico
« Reply #11 on: Fri, 07 February 2025, 13:26:27 »
Not exactly an orthodox 65%, but close enough: POLYGON-7
Offline jackcalico
« Reply #12 on: Fri, 28 February 2025, 01:06:55 »
One more from QK: Neo65 CU
Offline timd
« Reply #13 on: Fri, 28 February 2025, 16:22:05 »
I have a Lucky65 in ISO format.
My only current issue is that the left shift comes in long size (2.25). The PCB has positions for short shift + "|" key, but has no hotswap sockets soldered in for them - it just has a central hotswap socket for the long left shift key.
I've desoldered the long shift hotswap and soldered in new hotswap sockets for short shift and "|" key, my only issue is that the "|" key is being recognised as another "z". According to my multimeter, the two switches are not wired the same way. I just need to work out how to alter the via json to map it correctly.
Offline jackcalico
« Reply #14 on: Sat, 01 March 2025, 00:29:08 »
You may want to reach out to the vendor and/or manufacturer as that is quite odd, mine had the correct hotswap sockets right out of the box.
Offline calvin2sr
« Reply #15 on: Thu, 27 March 2025, 03:55:53 »
Where do you buy the lucky65 v2 iso plate with small left shift? I don't find it anywhere. Thank you.
Offline jackcalico
« Reply #16 on: Thu, 27 March 2025, 07:46:24 »
I bought mine at DeltaKeyCo, but they no longer sell them. You may want to contact other vendors, like CandyKeys or CoffeeKeys.
Offline Eclairz
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline jackcalico
Re: 65% ISO Hotswap 2.4GHz keyboards (links updated:28/Feb/2025)
« Reply #18 on: Thu, 24 July 2025, 09:18:41 »
Ah, true; I guess that technically meets the criteria. However, that is a low-profile board. Also, is the case made out of plastic? If so, that is quite different from the rest of the boards listed.
Offline Ethancarter
« Reply #19 on: Sat, 18 April 2026, 04:59:02 »
Hi all,
Zoom65
QK65
Neo65
Luminkey65
Tess65
Fox65
KV1-65
POLYGON-7
Neo65 CU
Could you provide more details about the features and specifications of each of the listed 65% ISO Hotswap 2.4GHz keyboards, such as key switch options, build quality, and any unique functionalities they may have?
Offline jackcalico
« Reply #20 on: Sat, 18 April 2026, 05:07:25 »
Sure... there is this cool thing called Google...
