Author Topic: [Pre-order] GMK Darling R2 | Oct. 4th-25th | Back with MTNU & Latin too!  (Read 11917 times)
Offline Xerpocalypse
Preorder Period:
October 4th-25th, 2024.
NA: Novelkeys
AU: Hibi
CA: Deskhero
CN: KBDfans
EU: Oblotzky
KR: Geonworks
SEA: iLumKB
UK: Prototypist
Estimated ship date: Q1 2025
Pricing:
(Proxy vendor pricing will vary by region)
Artisan collabs:
Latrialum
(Available October 25th)
About:
Inspired by the character Zero Two, and after 4 years of waiting for GMK's queue and the world to more or less return to normal, it's finally time for Darling R2.
This run features generally updated kitting for 2024, as well as new Latin + Icon & Text mods/nav and MTNU base kits! Colors will be the same as R1.
There are also HIBI collaboration keycaps available, Kate really went above and beyond for the second CYL design.
Kits: CYL Classic Base | CYL Latin Base | MTNU Darling | CYL Novelties | CYL Spacebars | CYL/MTNU Intl.
HIBI & Darling:
Renders:
No.2 65
Wampus
Daji TKL
Atom HHKB
A Discord server is also available for updates and any questions: https://discord.gg/9MynJa7
SPECIAL THANKS TO:
- The entire Novelkeys team; they're absolutely fantastic to work with
- Kate/HIBI; Kate's design for the horn artisan is incredible
- Fresh; for being so flexible/acommodating with render changes
Code: [Select]
[url=https://geekhack.org/index.php?topic=123779.0][img]https://i.imgur.com/P5ITp2R.png[/img][/url]
« Last Edit: Tue, 29 October 2024, 18:31:15 by Xerpocalypse »
Re: [Pre-order] GMK Darling R2 | Oct. 4th-25th | Back with Latin & MTNU too!
« Reply #1 on: Sun, 06 October 2024, 21:25:03 »
--- RESERVED ---
Update 10/29/24 - Today I became aware of the issues surrounding Space Cables' groupbuys for Classic Beige and Dandy (see this Reddit thread for more info) and have removed links to the cable collab I had with them from the original post.
I was previously unaware of that situation, but cannot in good faith recommend a product from Space Cables until Ragan can make customers of those groupbuys whole.
« Last Edit: Tue, 29 October 2024, 18:42:44 by Xerpocalypse »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [Pre-order] GMK Darling R2 | Oct. 4th-25th | Back with MTNU & Latin too!
« Reply #2 on: Sun, 13 October 2024, 03:40:43 »
glwgb
Offline mf0176
« Reply #3 on: Sun, 13 October 2024, 05:55:53 »
No 1.5u Super
Smdh
Offline mgsickler
« Reply #4 on: Sun, 13 October 2024, 21:31:12 »
No 1.5u Super
Smdh
1.5u Supers are in there. Check that base kit again.
Offline xLeHoy
  • weeb board enjoyer
« Reply #5 on: Mon, 14 October 2024, 11:24:19 »
It finally happened!
GLWGB!
Offline fojoke8
« Reply #6 on: Tue, 15 October 2024, 04:10:49 »
It's laughable that you think it's appropriate to choose an Australian Vendor that doesn't accept AUD. What's even the point?
GL with your cash grab
Pre-orders should be shipping soon if they haven't already!
The GMK keycaps have already arrived at Novelkeys in the US and orders are being fulfilled.
I was informed that Hibi metal keycaps will be arriving later, probably sometime in the next month or so.
Here are some photos of the MTNU and Latin base kits:
