Author Topic: [In Stock] Lucky65 V2-VIA&QMK Support, Screwless Structure  (Read 12355 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
« on: Fri, 11 October 2024, 22:06:08 »
Lucky65 V2
Designed by Weikav
Discord | Instagram | TikTok
Intro
Breaking news! The Lucky65 is back with its V2 edition!
Lucky65 V2 has been completely upgraded from V1, featuring a new ball-catch structure and the addition of a magnetic receiver storage slot. Most notably, it now supports VIA and QMK, marking its key distinction from V1.
The pre-order is ongoing, don’t miss out the best budget keyboard this year!
Color Options
Highlights
1. Ball-catch Structure
Brand new design, using 4 sets of beads for quick disassembly. In order to achieve a more beautiful edge thickness, we abandoned the common magnetic beads on the market and independently developed customized steel beads to achieve better disassembly strength (disassembly strength can be freely adjusted)
2.Ice Crystals Weight
Two personalized ice crystal weights, silver and black, are different from other mirrors and ordinary anode weight. They offer a unique visual appeal with a subtly raised frosted texture, providing a fresh sensory experience.
The back of the keyboard is engraved with a four-leaf clover that symbolizes happiness and luck.
3.VIA & QMK Support
Lucky65-V2 fully supports QMK and VIA, you can easily program each key on the keyboard and open source firmware; which means that the keyboard layout, shortcut keys, backlight effects, etc. can be customized by yourself. VIA supports Mac os, Windows, and Linux
4. Magnetic Receiver Storage Compartment
The wireless receiver is hidden under the bottom badge. The magnetic design makes the receiver not easy to lose and can be used at any time. There is a four-leaf clover pattern engraved on the bottom badge, which shows the high-end and is also a major feature of the keyboard.
5.Five Layers of Foam
The five layers of foam and the professional structural design greatly enhance the typing experience of Lucky65 V2.
Review
Specifications
Connectivity: Wired, 2.4G, BT5.0
Material: CNC Aluminum
Surfacing: 150 Mesh Anodized (Carmine, Silver, Black, Green, Purple), Electrophoresis (Milky White)
Weight: Ice Crystals Aluminium Weight
PCB: 1.2 mm Thickness, Supports ANSI/ISO layout, With flex cuts, Plate Mounted Stabs Compatible, Support VIA/QMK (ISO layout does not support)
Net Weight: 1.2KG
Weight With Package: 1.45KG
Size: 326mm * 115mm * 33mm
Plate(In the kit): 1.2mm, FR4 material (ANSI) / PC material (ISO)
Compatible System: Windows, macOS, Linux
Stabs: XinMeng V2 plate mount stabs, Factory Lubed
Rolling rate: 1000Hz (wired & 2.4G) ; 125Hz (BlueTooth)
Battery: 3750mAh
RGB: South-facing RGB
Front Height: 20.5mm
Typing angle: 7°
Price
76USD+
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions! :)
« Last Edit: Thu, 06 March 2025, 03:12:39 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline john08099
  • Velocifire MK
  • * Moderator
Re: [In Stock] Lucky65 V2-VIA&QMK Support, Screwless Structure
« Reply #1 on: Thu, 19 December 2024, 03:28:16 »
Reviews updated!
Offline john08099
  • Velocifire MK
  • * Moderator
« Reply #2 on: Wed, 12 February 2025, 00:56:16 »
✨ Love is in the Air! ✨
This Valentine’s, say it with the Lucky𝟨𝟧 V2 – the keyboard that’s stealing hearts!
Sakura Pink: A dreamy hue that’s as sweet as your love story.
✨ Two ways to love:
▫️ Kit Version: Build your love, one key at a time.
▫️ Pre-built Version: Ready to romance with dye-sublimated PBT keycaps in classic Cherry profile.
Perfect for gifting your special someone (or treating yourself, because self-love is everything).
Available now – because love (and typing) should feel magical. ✨
P.S. Valentine’s sale? Maybe. Stay tuned.
Offline john08099
  • Velocifire MK
  • * Moderator
« Reply #3 on: Wed, 26 March 2025, 00:46:05 »
Lucky65 V2's new color arrives! Photos in real life are more beautiful than render! Check it out!💚
🌳Forest Green🌳
Price: 76 USD
