Author Topic: Keyboard adapter for IBM 5160 XT  (Read 6441 times)
Offline SexieWASD
« on: Mon, 28 October 2024, 17:58:39 »
I just picked up an old IBM 5160 xt with no keyboard. Before I go buying a 40 year old keyboard on eBay, does anyone know of any projects to adapt a modern preferably usb keyboard to be used on an XT? I know there are adapter projects for going the other way, using XT keyboards on modern computers
Offline kbd0
Re: Keyboard adapter for IBM 5160 XT
« Reply #1 on: Fri, 01 November 2024, 22:08:08 »
This guy made one for PS/2:
https://www.mattmillman.com/building-an-at2xtkb-at-to-xt-keyboard-adapter-on-prototype-board/
I'm sure the folks over at vcfed have figured this out as well
As this is geekhack I have to recommend getting the original Model F keyboard, arguably one of the best keyboards ever
Offline SexieWASD
« Reply #2 on: Tue, 05 November 2024, 09:45:35 »
It looks like I will end up getting a model F, it's 3x the price of the computer it came with 😆, nevermind trying to get the original monitor!
Offline wjrii
« Reply #3 on: Tue, 05 November 2024, 13:50:11 »
If the goal is simply a working keyboard, search ebay for XT 5-pin din keyboards.  There are some 90s membrane boards that can be had for fairly cheap, though shipping can be annoying.  If you see one that's XT compatible but has a PS/2 connecter, a passive adapter should work.
Offline raffas
« Reply #4 on: Mon, 02 December 2024, 04:54:44 »
I don't have specific knowledge about this one, but when it comes to these really old keyboards and adapting them back and forth to newer standards, people usually make their own custom solutions using different controllers and whatnot. You might Google around to see if there's a way to DIY a converter for this if you can't find a ready-made one to purchase.
