Author Topic: IC] Domikey - Terrazzo  (Read 4389 times)
Offline Fannie_w
« on: Tue, 29 October 2024, 13:17:11 »
Domikey Terrazzo
Hi!!It's Fannie again and again :)
Inspirition
When I was making resin artisan keycap before, I came across another comprehensive material named jesmonite.
Jesmonite material will be very similar to terrazzo, but lighter and more suitable for smaller objects.
At the same time, I'm a big fan of @brazenstudio .I love the keyboards they made, so I said why not make a set of terrazzo keycaps! :)
At first, I was considering using PBT Dye-sub for this design, but after a few tests, I still couldn't get the desired result.
So I contacted @domikey_official to help me realize the effect of this design, so we tested a lot of mix plastic materials and finally making a satisfactory finished product :cool:
I hope you will enjoy this new material manifestations!
Kits
BASE IS ABS DOUBLE-SHOT MIX PLASTIC PARTICLES INJECTION
SCREEN PRINT NOVELTIES
Renders
PHOTOS
PHOTOS BY XIAMU
PHOTOS BY SACHIO
COLLAB
DOMIKEY TARRAZO X LABY85
KIT PRICING
TBA BUT THE KEYCAPS WILL BE IN STOCK
VENDORS
GLOBAL:Kprepublic
OTHERS:TBA
CONTACT ME
WELCOME TO JOIN THE DISCORD  TO DISCUSS
OR PM ME ON INS IF U HAVE ANY GOOD SUGGESTIONS ^-^
Offline bombay.duck
Re: IC] Domikey - Terrazzo
« Reply #1 on: Tue, 29 October 2024, 14:14:24 »
Offline Fraaaan
« Reply #2 on: Tue, 29 October 2024, 15:54:27 »
You've got a duplicate r4 PgDn. I assume the one next to the numpad was supposed to be an equals symbol. I also can't find an F13 anywhere.
IMO the novelties don't really look good and feel out of place. I understand what they're supposed to be and definitely think you can make the idea work, but I don't think the current ones compliment the keyset well. It just looks like you took some royalty free "minimalist" images and slapped them onto your keyset because you wanted some novelties. The ANSI Enter stairs in particular look jarring.
Offline keepoto
  • HHKB top for TKL pls
« Reply #3 on: Tue, 29 October 2024, 21:59:16 »
2 Terrazzos on the same page!
Offline ivanh98
« Reply #4 on: Wed, 30 October 2024, 12:16:12 »
prefer this version of terrazzo more. GLWIC
