Author Topic: [GB] gwŷdd65 - Thermally Modified Wood Keyboard  (Read 15072 times)
Offline roffelsaur
« on: Wed, 06 November 2024, 06:00:20 »
gwŷdd65
Surely this wood be good?
Greetings to Fellow Wood Enjoyers :D
I'm super happy to announce that the gwŷdd65 (known by some as the "good wood") is now in group buy! For those of you unfamiliar with the board and the journey we've taken to reach this point, please do feel free to check out the IC Thread.
Group Buy Dates
4th November 2024 - 4th December 2024
Base Kit Pricing
TWD$12,199 (approx. USD$380 / €350), 100 MOQ
Estimated Fulfilment Date
Q1 2025
Purchase Link Here
Base Kitting
  • Keyboard case (bottom base + top frame)
  • Wrist rest
  • M3 and M2 screws required for assembly + some additional (in case you lose any)
  • PCB - 1.6mm thickness, QMK, VIA, VIAL compatible. Default is solder (ANSI + ISO, 6.25u + 7u, split backspace), hotswap (ANSI only, 6.25u + 7u, split backspace) requires upgrade purchase or separate add-on purchase.
  • USB-C daughterboard
  • Plate (choice of Aluminium, Carbon Fibre or 3mm thick Polycarbonate)
  • Addon purchases of PCB and plates available
  • 12 adhesive gasket strips (70A) for each plate purchased
  • Geonworks W1-AT Silicone Feet (black), extras will be included
  • EVA Hard Carrying Case, custom-fit to hold keyboard and wrist rest
  • Small tub of wood maintenance wax.
Add-ons
  • Aluminium Plate (1.5mm, Black Anodised)
  • Carbon Fibre Plate (1.5mm)
  • Polycarbonate Plate (3mm)
  • Solder PCB (extra)
  • Hotswap PCB (extra)
  • All PCBs are 1.6mm thickness FR4 material. Daughterboard and JST cable included with each purchase.
    - Solder (Supports ANSI + ISO, 6.25u + 7u, split backspace)
    - Hotswap (Supports ANSI only, 6.25u + 7u, split backspace)
Specifications
  • Case Angle: 9
  • Wrist Rest Angle: 9
  • Material: Thermally Modified Taiwanese Acacia
  • Mount type: gasket strip (70A)
  • Weight: Approx. 510g unbuilt, 875g built, wrist rest 336g
  • Effective Front Height: 22.5mm
  • Screws: 8x M3 (4x 30mm, 4x 14mm), 2x M2 (5mm)
  • PCB designed by Maelk
  • Feet: 4x Geonworks W1-AT Silicone Feet (black)
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=123940.0][img width=360 height=240]https://i.imgur.com/jk9dkUm.jpeg[/img][/url]
« Last Edit: Mon, 11 November 2024, 21:51:11 by roffelsaur »
Offline Minisofu
  • Aspiring Keycap Designer
Re: [GB] gwŷdd65 - Thermally Modified Wood Keyboard
« Reply #1 on: Thu, 07 November 2024, 01:07:31 »
GOOD LUCK FOR GB!!!!
Offline roffelsaur
« Reply #2 on: Thu, 07 November 2024, 18:59:12 »
Thank you! The age of wood is upon us :D
Offline blondie
« Reply #3 on: Thu, 07 November 2024, 20:54:39 »
What color is this wood. Some photos make this look like black walnut, but in other photos it is reddish in color. The walnut brown color has been overdone, and the reddish wood looks nicer and more unique to me. But I see no way to ensure that's the color I get from the order page.
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline roffelsaur
« Reply #4 on: Fri, 08 November 2024, 04:20:02 »
Great question! So the reason for this is twofold. First we have lighting conditions, which brings out different tones of the wood (the photos on the websites are of 2-3 different units). The second is the cut of the wood and the wood grain itself. I've noticed three major variants in how the units turn out:
  • Dark and muted
  • Reddish brown
  • Highly chatoyant and very streaky
On top of these three major variations, you'll also sometimes get a mix where the board goes from dark to reddish, with or without chatoyant streaks, for example. This just boils down to the chaotic nature of acacia and the way it grows and forms its wood grain :D
On my end, after machining is done and I have to pick a wrist rest to match the case, I often pick one that gels the best with the vibe of the case. Some cases end up with a gradient and so slapping a wrist rest that is a solid colour instead of itself having a gradient then wouldn't make sense, for example, but after mixing and matching wrist rests with cases I have noticed that some pair together better than other combinations.
When it comes to wood grains there's no consensus on which of these variants is "prettier" or "better", as that does ultimately boil down to personal preference. I've brought the same batch of 5 prototype units out and showed various people and they've all picked different ones as their "favourite" with no single variant being a clear winner or preferred option. Some people prefer the plain nature of the dark and muted while others prefer the wild streaks and flashiness of chatoyancy, it really depends.
That said, if you'd like to support the project but are concerned about how your unit "wood" end up looking, please feel free to drop me a DM (here or on discord) and I'd be happy to help selecting a unit which matches your colour/variation preferences!
Offline KeebRehab
« Reply #5 on: Sun, 10 November 2024, 04:46:18 »
The good wood  :thumb: :thumb:
Offline jd
  • 60%
« Reply #6 on: Sun, 10 November 2024, 11:09:54 »
Great project, everything seems well thought out about this. Good luck with the group buy!
I would love to see something like this but with a 60% format.
Offline roffelsaur
« Reply #7 on: Sun, 10 November 2024, 22:46:25 »
That's how everyone is pronouncing "gwŷdd" these days xD
Thank you!
Yes, if the project is successfully completed I'd be looking at the next form factor to tackle. 60% stands out as the less complex compared to a TKL, but let's get this project over the line first :D
Offline shansoft
« Reply #8 on: Tue, 12 November 2024, 14:35:28 »
If it's TKL, it would be a no brainer for me.
Does the PCB support both mx and alps switches?
Offline roffelsaur
« Reply #9 on: Thu, 14 November 2024, 00:30:57 »
I was in the process of exploring the potential next form factor and for TKL there are concerns about the blockers/dividers being potential failure points due to the thickness. Will definitely keep looking at whether 100% wood is available or if it requires metal inserts for strength and stability!
Sadly the PCB this time around doesn't support alps, as it didn't come up as something that people wanted during the IC phase >_<
Offline blondie
« Reply #10 on: Thu, 14 November 2024, 22:42:32 »
What does "Thermally Modified" mean? Is this a fancy way of saying "kiln dried?"
Offline roffelsaur
« Reply #11 on: Fri, 15 November 2024, 02:28:34 »
Thermal Modification is when the wood is placed in a vacuum chamber and then heated to between 160C-260C, depending on the type of wood. The process typically takes between 72-110 hours. In contrast, kiln-dried wood is placed in a similar chamber but temperatures range from 49C-88C and the process lasts between 6-8 weeks. Thermal modification essentially boils out all the moisture from the wood and also collapses some of the intercellular structures (such as the lignin), which vastly reduces the wood's ability to reabsorb moisture, since the spaces which the moisture would have been absorbed into have been collapsed. In addition to this, the high heat treatment also removes carbohydrates from the wood, making it a less attractive meal for organisms that usually like to feed on the wood :)
« Last Edit: Sat, 16 November 2024, 11:07:02 by roffelsaur »
Offline roffelsaur
« Reply #12 on: Thu, 28 November 2024, 12:15:35 »
5 more days until the end of GB :D
Offline roffelsaur
« Reply #13 on: Mon, 09 December 2024, 22:40:40 »
Hey everyone, just wanted to leave a quick update here as well (full update can be found on discord here)
We missed the 100 MOQ of the group buy but I will be proceeding with initial production of 50 units so that the original timeline is not affected for people who have already purchased units. In the meantime, the group buy will continue until the end of the year, giving more time for anyone who's still on the fence or hasn't heard about the project yet to participate.
Thank you everyone for the support so far and I look forward to getting some wood into everyone's hands :D
