Author Topic: Why does my GPU constantly spool up and spin down?  (Read 44174 times)
« on: Mon, 11 November 2024, 18:24:01 »
It is like I'm constantly listening to waves crashing on a beach, or wind blowing through branches, but no, it is just my 2070 Super consistently spinning up the fan and immediately winding it down. Over and over, all day long.
Frankly it is kinda maddening, and I tried adjusting the fan settings to be smoother, but nothing seems to work. The only time the fan spins at a consistent rate is when I'm actually playing games. Then it spools up and stays there. But when I'm working, on the internet, watching a movie, all I hear is the fan making washing machine noises.
Why?  :confused:
Offline Leslieann
Re: Why does my GPU constantly spool up and spin down?
« Reply #1 on: Tue, 12 November 2024, 03:42:59 »
Sounds like an airflow issue, specifically a dead zone.
Fans kick on, blow out the heat around it, then it heats up again and the fans kick on again.
You need something to keep the air moving around it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Tue, 12 November 2024, 04:08:15 »
It has been a couple years since I've done a dust blow out. That may ease the air flow sitch a bit, hopefully.
Offline Aljami25
« Reply #3 on: Sun, 05 October 2025, 02:40:02 »
Yeah, that ramp-up/down cycle can drive you nuts. Try setting a custom fan curve in Msi Afterburner with a small flat zone at lower temps. It’ll keep the fans steady instead of constantly kicking on and off.
« Reply #4 on: Sun, 05 October 2025, 03:26:33 »
So yeah... I did spend 11hrs deep cleaning my entire case, replacing some of the case fans w/ nice new ones, and repasting my cpu & gpu w/ some MX-6
entire project cost me around $350 in new parts
dropped my overall temps by around 40° across all my hardware. Solved that cpu issue as well.
was it worth the time and effort? depends on how rich and lazy you are.
Offline phinix
« Reply #5 on: Fri, 02 January 2026, 08:08:06 »
Sounds like its on the edge off fan-off setting and kicks in all the time. Maybe play around with gpu fan settings for fan spin or something like that, if exists in its settings.
I had psu doing that some time ago.
« Reply #6 on: Tue, 20 January 2026, 20:49:08 »
I've since learned it is just the way they work on some EVGA cards, fans power off when below certain temps and power usage
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #7 on: Wed, 21 January 2026, 20:34:40 »
If the software allows to set a custom fan-curve, you can prevent that.
Instead of 0-10-20-30-40-50... You go 20-20-20-30-40-50...
A Ghost From The Past
Offline Aljami25
« Reply #8 on: Sun, 07 June 2026, 08:38:29 »
Why?  :confused:
Yeah, that’s pretty common. The card keeps hitting the temp limit where fans turn on, then cools just enough to shut them off again, so it repeats. A simple fan curve that keeps a low steady speed usually fixes it.
