Author Topic: [IC] Roselle Evolution:Feel the extraordinary touch of the Roselle V2  (Read 3848 times)
Offline Ivan Ren
Since we launched Roselle switch, it has always been loved by a large number of enthusiasts, due to its unique material and touch. In order to repay the love of fans, we decided to do a upgrade version of Roselle. However, when it comes to product upgrades, it is not easy!
Product upgrades is a complex process, involving market research, design, development, testing and other links, but I am a person who particularly love to toss, so after determining the upgrade strategy, after half a year of continuous adjustment and transformation of the mold, lubing technology upgrade and test, so there is the Roselle V2.
If you want to know what changes we have made, please don't miss the following:
« Last Edit: Sat, 23 November 2024, 03:28:41 by Ivan Ren »
Offline Ivan Ren
Re: [IC] Roselle Evolution:Feel the extraordinary touch of the Roselle V2
« Reply #1 on: Sat, 23 November 2024, 03:26:38 »
1. 【RGB diffuser】Make every breath of the keyboard full of charm
In the world of keyboard, the combination of light and force can always create infinite possibilities, so we added a transverse RGB diffuser in Roselle V2.
This RGB diffuser design, can provide better light brightness and uniformity, bring a clearer and brighter visual experience for your keyboard. Every tap, is the ultimate pursuit of light and touch.
Offline Ivan Ren
« Reply #2 on: Sat, 23 November 2024, 03:30:47 »
2. 【4.0mm long travel distance】Make every tap powerful and satisfying
A. The longest travel, The great satisfaction
We chose a 4.0mm long travel, so that users can feel a more complete press and release process when tapping, enhancing the sense of satisfaction and confirmation of the switch.
B. Precise control, Reduce false touch
Longer travel can also reduce the possibility of false touch, the user needs a clearer intention to trigger the key, thereby reducing the probability of pressing the wrong key
Offline Ivan Ren
« Reply #3 on: Sat, 23 November 2024, 03:31:42 »
3. 【37g trigger force, 20mm extended spring】Light feel, strong rebound
A. 37g trigger force makes keyboard tapping easier, long-term use is not easy to cause hand fatigue;
B. The 20mm length of the spring provides a light feel while also having a strong rebound, so that every knock is full of vitality
C. In order to meet the needs of users who like heavy force, we have added an additional 57g extended spring, which can feel a strong feedback whether it is triggered or bottoming.
Offline Ivan Ren
« Reply #4 on: Sat, 23 November 2024, 03:32:15 »
4. 【Big round pole stem】Double upgrade of sound and touch
According to my experience, short travel distance cause good sound, but unwell touch: long travel distance cause comfy touch, but sound...., In order to achieve both sound and touch, we designed a big round pole stem,  It not only makes the sound purer, but also elevates the touch to new heights, experience the double upgrade of sound and touch
A. Enhance the quality of sound
The impact sound of the big round stem in the switch body is more concentrated, the sound is similar to cherry black when typing, but the rustle sound of cherry black is caused by the structure of the mold, and the Roselle is generated by the particularity of the material. This makes the sound of keyboard much more melodious, every typing is a perfect ensemble with the keyboard.
B. Enhance touch experience
The big round stem design provides a smoother pressing feel, Due to its rounded appearance, when pressed to the bottom, it makes the tapping feel much more comfortable, enhance the user's typing experience.experience.[/size][/font][/size]
Offline mr_foggy
  • neue = nope
« Reply #5 on: Sat, 23 November 2024, 08:14:19 »
mans forgot how to forum
