Author Topic: [IC] GMK MTNU Dashboard-Updated Novelties  (Read 21203 times)
Offline madmax13
« on: Wed, 04 December 2024, 14:46:38 »
Inspiration
Taking inspiration from 1980s and early 1990s digital car dashboards, particularly GM and Audi, this set attempts to match the color and vibe of these early dashboards.
311323-0
I am excited that this will be only the second all-new MTNU design, after MTNU Rascals. This set has gone through a lot of changes in its history, mostly to try to get the colors correct, and I think I have gotten it "right" with the color and kitting choices I have made on this set. This set was done in MTNU after trying the colorway in SA, KAT, and DSS because I think the Son of a Doubleshot (SOD) typeface fits best for the vibe I am looking for this set. I originally wanted to run this set without novelties, but the overwhelming preference is to have novelties related to the theme of the set. To this end, I have adapted the standard dashboard indicators (and a few others) from the appropriate NHTSA manuals, in the public domain. If you enjoy this set, I would appreciate if you filled out the IC form below and/or joined my discord. I take feedback very seriously and hope you like the set.
Interest Check
Designer Discord
Designer Instagram
Kits
Renders
Geon F1-8X
Bakeneko
Smith and Rune Iron 165
Trashman V4NGON
Please add this banner to your profile if you want to support this set.
Samples
Vendors
CA: TBD
CN: TBD
UK: TBD
EU: Coffeekeys
SEA: KTechs
CN: ZFrontier
KOR: TBD
« Last Edit: Wed, 14 May 2025, 13:52:54 by madmax13 »
Offline KenGuru
Re: [IC] GMK MTNU Dashboard
« Reply #1 on: Wed, 04 December 2024, 14:53:58 »
Colorway might not be 100% for me, but i kinda like it. Kitting is excellent imo.
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Wed, 04 December 2024, 16:46:52 »
I like the colorway, does give "electronic" dashboard look from back in the 80s vibes IMO. I'd love to see the green & orange swapped. Not sure how feasible it would be, but two different bases (one with orange alphas legends & green mod legends, then one with legend colors swapped) might be something to think about. Filled out the IC, GL with this project! :thumb:
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #3 on: Wed, 04 December 2024, 19:33:47 »
This could be Green Screen's relative, Green Screen Dark. Green Screen had two legend options.
Online Rob27shred
« Reply #4 on: Wed, 04 December 2024, 20:14:00 »
100% agree! Also great example to back up the feasibility of what I suggested!
Offline madmax13
« Reply #5 on: Wed, 04 December 2024, 21:52:40 »
I will look into the feasibility of doing it both ways. The amber alphas/green mods came from the inner ring of the speedometer being KM/H (in Amber) and the outer in MP/H (in Green). Give me about 25 minutes, and I'll run a render of it the other way (not annotated, of course). As a conceptual exercise, this is great- but once venders come in, we'll see.
Also, I love SA Green Screen, just wish it's not $160 base.
« Last Edit: Wed, 04 December 2024, 22:14:57 by madmax13 »
Offline madmax13
« Reply #6 on: Wed, 04 December 2024, 22:06:54 »
Here's the inverse; let me know if it has legs.
311273-0
Online Rob27shred
« Reply #7 on: Wed, 04 December 2024, 23:09:57 »
Oh wow, thanks! For me I actually prefer it with green alpha legends! I guess we'll have to see what other's think.
Offline unipanic
« Reply #8 on: Thu, 05 December 2024, 00:02:30 »
I like both the green and the orange, but prefer the orange.
Offline dvorcol
« Reply #9 on: Thu, 05 December 2024, 19:49:58 »
One idea is to have two Alphas kits and two Mods kits so people can mix and match. But this might not be compatible with GMK's MTNU manufacturing/pricing structure.
Offline madmax13
« Reply #10 on: Thu, 05 December 2024, 22:24:07 »
That'll be on my to-do list over the end of the year. Finalize colors (some IC respondents want it a hair brighter, but will see), decide on novs, the 40s/compatibility kit, and then seeing if I can do a dasher/dancer thing with this set.
Offline dvorcol
« Reply #11 on: Fri, 06 December 2024, 00:50:36 »
So that everyone has both accent color options, please consider add two green accent keys: R2 1u ESC and R3 1.5u Enter
EDIT: also two non-accent keys?
« Last Edit: Fri, 06 December 2024, 19:20:58 by dvorcol »
Offline bigmaxnonions
« Reply #12 on: Fri, 06 December 2024, 08:05:42 »
Does MTNU not support barred F and J?
Offline madmax13
« Reply #13 on: Fri, 06 December 2024, 17:59:43 »
When I tweak the colors in the next set of renders, I'll add green accents. On the topic of novelties, I will have something done before the end of next week: adapting some dash symbols.
I don't know, I simply have a preference for scooped.
Offline dskeeb
« Reply #14 on: Sat, 07 December 2024, 15:21:13 »
I struggled with MTNU profile not having barred or dotted F & J keys. The profile, for normal keys, are already scooped so the super scooped keys are even more of a struggle to type on.
In touch typing this matters alot when fingures float as one start typing fast. Often I missed hitting F or J because my figure didn't travel down enough. Also in touch typing one need the bar or dot to realign the position, super fast, to avoid miss hitting keys. It is impossible with MTNU even after modded, albeit not the best, my F & J keys to find them quickly.
I understand the bar is not practical for MTNU profile but the dot is when implemented properly.
Based on this, I cannot justify spending a small fortune to buy something that I know is flawed. There are two MTNU colorways I really like, including yours, but won't buy based on my experience.
If you would like to do something really, really helpful for us, please demand GMK to include dotted F & J keys and be the first one to fix the flawed MTNU profile.
Thank you for your time.
Offline madmax13
« Reply #15 on: Sun, 08 December 2024, 02:45:04 »
I decided to force the 40s accents - I am still planning a compatibility kit, so stay tuned.
Following some good and not-so-good feedback on the IC, I've made a few changes to the kit. I have made the orange and green slightly brighter and made some of the suggested kitting changes. Novelties are in the works, as is the aforementioned compatibility kit. In terms of the styling and presentation of the kit, everything was designed to fit a specific aesthetic, which may seem haphazard but is very in line with the advertising copy of the period from which this set takes inspiration. I view the interest check process as collaborative, so I am always open to constructive feedback.
Offline rrdaud
Re: [IC] GMK MTNU Dashboard- Updated Renders and Colors!
« Reply #16 on: Sun, 08 December 2024, 14:53:39 »
What about COLEVRAK?
Offline madmax13
« Reply #17 on: Sun, 08 December 2024, 21:24:11 »
There is no plan right now; however, if you are interested, please fill out the IC and indicate that specific interest, and I will consider it for future expansion.
Offline madmax13
Re: [IC] GMK MTNU Dashboard- Updated Renders, Colors, and Novelty Preview
« Reply #18 on: Wed, 11 December 2024, 18:22:06 »
12/11/2024 - Updated Kitting and Renders (More a reflection of my growing proficiency in rendering than a substantive change in the kit).
Here's a preview of the novelties, which are in progress. I'm looking forward to your feedback. Please understand that this is a rough draft and still very much a work in progress. Yes, I know I need to make the line thickness uniform.
Finished update, will post previews below.
As Harry Dresden said "Life is a journey. Time is a river. The door is Ajar."
« Last Edit: Mon, 16 December 2024, 23:37:51 by madmax13 »
Offline madmax13
Re: [IC] GMK MTNU Dashboard- Full Novelty kit!
« Reply #19 on: Mon, 16 December 2024, 23:39:04 »
Finished novelties, and to show off a bit, here's a set of board renders.
311518-0
311520-1
« Last Edit: Tue, 17 December 2024, 03:38:26 by madmax13 »
Offline madmax13
« Reply #20 on: Wed, 18 December 2024, 02:13:36 »
Based on further feedback (Thanks Matt3o Discord!), I have further refined the novelties kit. Here's a few new renders featuring the Nemui (眠い) keyboard.
311609-0
311611-1
Offline slothritis01
« Reply #21 on: Sun, 29 December 2024, 19:54:04 »
i really dig it
Offline gak1234
« Reply #22 on: Mon, 30 December 2024, 01:50:02 »
Totally love those novelties
Offline linearscringe
« Reply #23 on: Mon, 30 December 2024, 07:54:13 »
another mtnu set without proper homing keys. pass
Offline Piperaceae
  • Formerly filefish
« Reply #24 on: Mon, 30 December 2024, 10:11:52 »
Barred and nubbed homing key molds don't exist yet, afaik. You're gonna be passing for a long time.
« Last Edit: Mon, 30 December 2024, 10:18:32 by Piperaceae »
Offline dvorcol
« Reply #25 on: Mon, 30 December 2024, 20:24:01 »
For both selfish and logical reasons, I hope GMK adds tooling for MTNU barred homing soon.
CYL sets almost never contain non-homing F & J. Typically both scooped and barred options are offered, with nubs occasionally in the mix. In fact, September's GMK CYL Evil Dolch R2 had five Alpha kits, all with barred F & J. Only the TKL kit had scooped as well.
In contrast, most MTNU sets have had non-homing and scooped F & J options. Why would MTNU customer preference be different?
Offline Piperaceae
  • Formerly filefish
« Reply #26 on: Mon, 30 December 2024, 20:28:59 »
I'd love to see it happen. It just seemed like the implication was that it's some sort of designer oversight, versus the molds just not existing.
Offline madmax13
« Reply #27 on: Mon, 30 December 2024, 22:49:35 »
I'd be more excited with an R5 home row than having barred or nubbed homing keys. As Piperaceae said, with GMK still rolling out molds, there are only scoops for homing. Furthermore, GMK is adding new mods like bars as time goes on. For wit, 6U space wasn't available in the first run of MTNU.
Here's an update on the status of the set: I am communicating with GMK for color matching. I have finalized the physical colors of the set using RAL references for easy matching. For people with a RAL wheel at home, the colors will be:
RAL 2017- RAL Orange
RAL 6014- Yellow Green
RAL 9005- Jet Black
In the new year, I will start approaching vendors as I have incorporated most of the feedback from the IC into the extent sets. I am considering a 40s kit, as there has been some interest, but not enough to represent a critical mass to do the work on the set.
I thank everyone for their feedback and have high hopes for this set.
Offline madmax13
« Reply #28 on: Mon, 06 January 2025, 14:10:36 »
Examining trends with other MTNU sets, the novelties are often considered part of the base kit. As such, I have added a question to the interest check regarding adding the novelties to the base. If so, should I trim the number of keys to keep the kit affordable?
311736-0
311738-1
Offline dvorcol
« Reply #29 on: Mon, 06 January 2025, 20:41:02 »
RAL 9005- Jet Black
Is this what you are thinking for MTNU R5 home row? Would you use it for the bottom row too, like SA uses R3?
Offline madmax13
« Reply #30 on: Mon, 06 January 2025, 22:04:56 »
RAL 9005- Jet Black
Pretty much like that- I am a massive fan of 1-1-2-3-4-3 SA and R5 MT3, and I suspect that kind of arrangement would make MTNU super comfy.
Also, I am considering migrating the colorway to other profiles.
« Last Edit: Mon, 06 January 2025, 22:17:10 by madmax13 »
Offline dvorcol
« Reply #31 on: Mon, 06 January 2025, 23:30:22 »
RAL 9005- Jet Black
Those are my preferences as well. Last I heard there's no MT3 R5 tooling for ABS doubleshot, which is strange considering about 80% of SA sets have R3 bottom row.
Offline madmax13
« Reply #32 on: Sun, 12 January 2025, 00:04:14 »
There is significant interest in the international kit; just over 20 percent of interest check respondents are interested.
Likewise, about 65 percent of the IC respondents are interested in the Novelty kit. However, a significant number of respondents have expressed an interest in placing the novelties in the base kit, which is something I am strongly considering.
The next step for me is finally contacting vendors. I made significant progress in my other active project, SA Welles, due to some developments I will announce later this weekend, which took up much of my spare time and attention this week.
« Last Edit: Mon, 17 February 2025, 02:30:17 by madmax13 »
Offline madmax13
« Reply #33 on: Thu, 23 January 2025, 02:19:05 »
I noticed some inconsistencies with the renders, which I have now replaced from the announcement. Furthermore, I continue to search for vendors.
« Last Edit: Mon, 17 February 2025, 02:30:46 by madmax13 »
Offline madmax13
Re: [IC] GMK MTNU Dashboard- New Renders, Expanded Base Kit, Final Novelties.
« Reply #34 on: Mon, 17 February 2025, 02:33:11 »
Updated Rendors.....Current status of GB Responses:
~93 Percent of respondents want the base kit.
~63 Percent of respondents want the novelty kit.
Only about 40 percent want novs in base, so that'll remain separate.
NorDeUK has an interest rate of 25 percent, which is significant.
Still looking for someone to carry this set, but I think it's something unique and different for this profile.
312379-0
« Last Edit: Mon, 17 February 2025, 02:40:27 by madmax13 »
Offline AMZ
« Reply #35 on: Mon, 17 February 2025, 14:10:12 »
Would you do it CYL? I really like the design.
Offline madmax13
« Reply #36 on: Mon, 17 February 2025, 19:18:48 »
Right now, the focus is MTNU. However, if this set gets a run as MTNU, I might consider repackaging it at a later date.
Furthermore, I have a CYL set that I will be releasing within the next month, so stay tuned there. I also have one that I plan to finish the medium term, so there will be plenty of CYL goodness to go around.
Offline AerosolFNTM
« Reply #37 on: Fri, 28 February 2025, 16:51:13 »
Love the theme here! I will definitely be purchasing when this goes live. Great design.
Offline madmax13
Thank you for that! I hope to have some good news regarding its availability shortly.
Here are a few more renders, which I hope keeps your interest.
312498-0
312500-1
Offline AerosolFNTM
Love the novelties! Will be following this closely, thanks!
Offline madmax13
Re: [IC] GMK MTNU Dashboard- Added Samples, Updated Vendors!
« Reply #40 on: Wed, 09 April 2025, 02:01:46 »
4/9/2024- Added Samples and Vendors
Offline madmax13
« Reply #41 on: Tue, 15 April 2025, 00:10:12 »
4/14/2025: Added Small kits and additional renders.
Offline madmax13
« Reply #42 on: Wed, 14 May 2025, 12:07:42 »
5/14: Changed ANSI and ISO Enter Novelty with a fresh design by switchbox.studio, inspired by the S2000 and C4 Corvette Dash, respectively.
Offline madmax13
« Reply #43 on: Wed, 14 May 2025, 12:09:01 »
5/14: Changed ANSI and ISO Enter Novelty with a fresh design by switchbox.studio, inspired by the S2000 and C4 Corvette Dash, respectively. Added R2 "up" for mod and accent arrows.
Offline konstantin
  • Formerly constexpr
« Reply #44 on: Wed, 14 May 2025, 13:33:42 »
Hi, please consider adding R3 PgUp, R4 PgDn for full 65%/75% layout support. As it currently stands, this set includes quite a few uncommon and/or optional keys (to name a few: 6u space, 1u backspace, several arrow variants, several 40s variants, numpad 00 and =), yet it's wholly missing these two keys which are essential for 65% users like myself.
Moving all of the aforementioned keys (together with Mac bottom row) out of base and into an extension kit is also a valid option that a lot of GMK CYL sets have been choosing recently, for pricing reasons.
« Last Edit: Wed, 14 May 2025, 13:51:24 by konstantin »
Offline ppatches24
Re: [IC] GMK MTNU Dashboard-Updated Novelties
« Reply #45 on: Sun, 18 May 2025, 17:35:36 »
very niceeee
Offline samgo00
« Reply #46 on: Mon, 09 June 2025, 13:35:54 »
I really like the concept, but I would definitely add an orange spacebar. It would definitely add an extra finishing touch
