Author Topic: [IC]New Vintech Series 06 All-in-One Desktop Terminal  (Read 29311 times)
Offline cndisk6
« on: Fri, 20 December 2024, 03:11:21 »
Vintech Series 06 (VS06) — English IC
Status: Interest Check
Intro
Hello everyone. This is Fusion Lab Studio, a custom keyboard team with independent design and manufacturing abilities.
Over the past two years, we have developed a secondary-display solution that uses one USB 2.0 cable for both power and display, with millisecond-level latency.
This technology was successfully applied to our debut project, Vision75.
We also organized a community group buy to reproduce the 9009 keyboard, which has been loved by many friends.
About Vintech
With our passion for classic vintage keyboards and terminal devices, and backed by a mature design, machining, and manufacturing system, we aim to merge:
— Vintage — classic retro design
— Technology — modern usability
We use “Vintech” as a tribute to classic products and to create a series of keyboards built for the custom keyboard community.
Vintech Series 06 (VS06) carries a hardcore retro industrial aesthetic while integrating modern geeky functionality.
Next, let’s look at the original inspiration — the Weytec MK06.
Design Origin — Weytec MK06
MK06 / WEY RAY 06 was designed by Switzerland’s Wey Technology, mass-produced in 2006, and manufactured by Germany’s GMK.
It was a professional industrial-control / multi-workstation keyboard used in environments such as monitoring centers and trading floors.
Although the MK06 is now discontinued, it remains popular among vintage keyboard enthusiasts thanks to:
— Rich I/O for connecting multiple devices
— A futuristic triple-segment color display
— Modular expansion areas (touchpad, buttons, fingerprint module, etc.)
Using an original MK06 today often requires additional adapters and cables, increasing both cost and complexity.
Connection
VS06 simplifies this dramatically.
Only one USB 2.0 cable is required to power the keyboard and run the display.
About VS06
VS06 is not just a restoration of an old keyboard.
We want to give this classic model a new life, allowing enthusiasts to own a brand-new, modernized MK06-inspired keyboard at a reasonable price.
Fusion Lab brings a full technical upgrade:
— Aluminum alloy precision CNC case
— Newly developed PCB and optimized internal structure
— The original display becomes a fully usable computer secondary display
No extra video cable
No extra power cable
No Thunderbolt required
With only USB 2.0, the computer can directly recognize the device and enable:
— Secondary display extension
— Parameter adjustment
— Touch interaction
Appearance
We reproduced the MK06’s dimensions, shape, layout, and lines almost 1:1.
Due to the fixed screen size, the upper section is slightly larger, adding one extra row of keys compared to the original.
Structure
VS06 supports two mounting structures.
Plate Top (Hot-swap / Soldered)
— Plate mounted to the top case with screws
— Solid and classic typing feel
PCB Top (Plateless Soldered)
— PCB mounted directly to the top case
— Plateless structure similar to the original MK06
— Flexible yet stable typing experience
Screen
Specifications
— 8.8-inch IPS touch display
— 1920 Χ 480 resolution
— 60 Hz refresh rate
Connection
— Single USB 2.0 cable
PCB & Layout
— Hot-swap PCB — 1.6 mm, single-color SMD LEDs
— Solder PCB — 1.6 mm, multi-layout support with 2-pin LEDs included
Dials
On the original keyboard, the two dials controlled the brightness of the built-in screen.
VS06 restores this experience.
— Dial 1 — secondary screen brightness
— Dial 2 — system volume (remappable in VIA)
Expansion Modules
Button Module (Default)
— DIY combinations supported
— Switch freely between 1u and 2u layouts
Fingerprint Module (Optional)
A fingerprint unlock module is planned as an optional add-on.
Additional modules (mini screen, touchpad, etc.) will be revealed later.
Manufacturing & Finishes
Machining
— 4-axis CNC machining
Estimated Weight
— ~5 kg kit weight
— Up to ~12.5 kg with optional weights
Surface Finishes
— Anodizing
— Powder coating
Kit Contents
— 6063 aluminum case (top & bottom)
— 1.6 mm PCB (QMK firmware, VIAL support)
— Plate (stainless steel / carbon fiber)
— Sound pack (Poron + IXPE)
— Plateless structure spacers
— Screws and feet
— USB-C daughterboard, dial board, magnetic connector board
— Packaging box
Release Plan
— Estimated Sales Start: April  2026
— Estimated Lead Time: ~1 month
— Quantity: 50 kits
— MOQ to Form GB: 30 kits
— Vendor: Sold on Keyspensory Only
About This IC
VS06’s appearance design and structural validation are nearly complete, and sample production is currently being arranged.
Real photos will be available soon.
We would love to hear your feedback on:
— Appearance
— Structure
— PCB
— Module design
Fusion Lab thanks everyone for your support.
See you in the next update.
For more information or latest updates, please join our discord channel
« Last Edit: Thu, 19 March 2026, 20:58:28 by cndisk6 »
Offline Randomlosername
  • Gacha Done Got Me
    • IG
Re: 75% Layout Keyboard with Built-in Touch PC Second Screen
« Reply #1 on: Fri, 20 December 2024, 04:29:31 »
This seems very interesting. Can you share more details like if the board is using a flex-cut pcb or no? Also what plate materials would be offered?
Offline cndisk6
« Reply #2 on: Fri, 20 December 2024, 04:47:01 »
A
« Last Edit: Sat, 07 March 2026, 21:10:30 by cndisk6 »
Offline gak1234
Re: [IC]75% Layout Keyboard with Built-in Touch PC Second Screen
« Reply #3 on: Sat, 28 December 2024, 20:16:20 »
Missed opportunity to make the numpad able to plug into the left side for a southpaw configuration? I want the numpad on the left and the screen on the right. That would be amazing!
« Last Edit: Sat, 28 December 2024, 20:21:00 by gak1234 »
Offline tankLancer
« Reply #4 on: Sun, 12 January 2025, 00:18:54 »
Will this keyboard be mass-produced?
Offline cndisk6
Re: [IC]New Vintech Series 06 All-in-One Desktop Terminal
« Reply #5 on: Thu, 19 March 2026, 20:46:59 »
Vintech Series 06
Offline meowoofun
  • Design Critic
« Reply #6 on: Fri, 20 March 2026, 15:17:57 »
GOD TIER Maximilian set!
This has everything the "other one" didn't have. FULLY optioned and customizable layout. Close to 30 pounds, **** me. I'm in!
« Last Edit: Fri, 20 March 2026, 15:32:01 by meowoofun »
Offline tulaine
« Reply #7 on: Sat, 21 March 2026, 15:01:40 »
insane work
Duck Eagle V2, Noxary 280, Geon F1-8X 722, G81-1000 SDF, G80-1861 HAF (x2), G81-3468 HKNXX, G81-0991 HCF, Olivetti G81-3000 HBF, Sailor Radio G80-1800 HAU
Offline KeyMaze
    • KeyMaze
« Reply #8 on: Sat, 21 March 2026, 21:11:06 »
This is one of the most interesting keyboards I have ever seen!
Offline blondie
« Reply #9 on: Tue, 07 April 2026, 14:22:16 »
I like it a lot. I wonder if this is ever produced, will I get one before my Hyper7 arrives.  ;D
"I like big keyboards and I cannot lie..."
« Last Edit: Tue, 07 April 2026, 14:27:27 by blondie »
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline kenny_25
« Reply #10 on: Sun, 26 April 2026, 12:14:12 »
NGL, this is crazy. A mordern battle ship on the desk. GLWIC!
Offline Unenlightenment
« Reply #11 on: Mon, 04 May 2026, 18:36:58 »
It would really be awesome if they could make a southpaw variant, though the upper left sqaure is the perfect size for a whole numpad already, will have to do for now I guess
