Author Topic: [IC] KAP T.O.T. (Theatrum Orbis Terrarum)  (Read 12419 times)
Offline keepoto
  • HHKB top for TKL pls
« on: Tue, 07 January 2025, 07:20:16 »
I forgot what my last design was but new year new design here we go -
IC Form | Discord
If you are interested in the set or wish to leave comments, please do not forget to fill in the IC form and pop by my discord!
Intro
Theatrum Orbis Terrarum is inspired by the eponymous 16th century atlas created by Abraham Ortellius. It represents the pinnacle of cartographic craftsmanship at its time and is considered to be the first true modern atlas.
The keyset draws inspiration from the elegant ink colours of the atlas. Novelties consist of iconic structures from late medieval and renaissance period, ranging from China in the orient to Central America in the new world. I sincerely hope you will enjoy this exciting cartographic voyage on your keyboard.
Specs
Profile: KAP (Cherry)
Material: PBT doubleshot (base kit) / PBT dyesub (novelties)
Manufacturer: Keyreative
Kitting
Note: renders are indicative only and colours of the final product may differ.
Renders
Note: renders do not represent final kitting. For subsequent changes, please see the latest update post in this thread.
Bina103 by Teahouse
Constance TKL by Aiglatson Studio
Lila60 by Freather
Deskmat & Collabs
soon!
Vendors & Pricing
TBD. Please kindly contact me on discord (keepo87) if you are interested in becoming a vendor for / collaborating on this project.
« Last Edit: Sun, 10 August 2025, 10:29:35 by keepoto »
Offline keepoto
Re: [IC] KAP T.O.T. (Theatrum Orbis Terrarum)
« Reply #1 on: Tue, 07 January 2025, 07:20:44 »
Reserved McReserveface
Offline xLeHoy
  • weeb board enjoyer
« Reply #2 on: Tue, 07 January 2025, 07:29:52 »
Time for another Keepo classic
GLWIC
Offline Ammonite
« Reply #3 on: Tue, 07 January 2025, 12:21:45 »
Definitely interested in this, but it needs 40s support!
Offline richardliu1124
« Reply #4 on: Tue, 07 January 2025, 21:02:55 »
This is an amazing design!GLWIC :thumb:
Offline örange_stone
  • No fancy life But fancy keyboard
« Reply #5 on: Thu, 09 January 2025, 03:17:22 »
That Novelties art is an awesome piece of work! It's a fascinating pick of a theme. :thumb:
GLWIC!
Offline keepoto
Re: [IC] KAP T.O.T. (Theatrum Orbis Terrarum) - Kitting changes, GB soon
« Reply #6 on: Sun, 10 August 2025, 10:26:58 »
As we are nearing GB, here's a couple of significant changes:
Base Kit: changed to icon+text upon popular demand - some kitting trimming due to costs concern.
Numpad Kit has also been separated from Base upon demand.
Novelties Kit: changed to dyesub (from doubleshot+dyesub) due to feasibility and cost of doubleshot+dyesub technique. Dark novelties dropped for a slimmer novelties kit.
NorDe Kit: added
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #7 on: Thu, 21 August 2025, 20:37:20 »
GB running 18 August - 15 September.
See KeycapLendar for vendors.
Offline konstantin
  • Formerly constexpr
« Reply #8 on: Thu, 21 August 2025, 23:44:36 »
FYI, there are currently two white 2.25u Shifts (three in total) in the base kit. You likely intended one of them to be 2u since you've also included a 1u Shift (the two are most commonly paired together to cover GK64-style layouts). If that's indeed the case, you may want to fix that before this set goes into production.
« Last Edit: Thu, 21 August 2025, 23:54:14 by konstantin »
Offline GG-Bond
    • github
« Reply #9 on: Sun, 31 August 2025, 16:29:21 »
Is KAP the same as Cherry? Just a bit curious.
Offline GG-Bond
    • github
« Reply #10 on: Sun, 31 August 2025, 16:29:40 »
But I’ve bought keycaps from Keyreative before and the quality has always been excellent.
Offline kapowaz
    • kapowaz industries
« Reply #11 on: Tue, 02 September 2025, 17:59:45 »
Yes; it’s a standard Cherry profile, but with custom legends.
