Author Topic: Converting a G81 3000 using it's original controller  (Read 19835 times)
Offline blur410
  • Memewhile in World of Tanks...
« on: Tue, 07 January 2025, 15:34:10 »
Was wondering if it is possible to make/map a matrix out for a G81 keyboard controller in such a way as to use MX switches instead of the membrane and what potential limits can be reached with it, like could it be NKRO/work with a PS/2 converter etc. Was trying to find any projects around this but it seems like most handwire projects revolve around a teensy or something else. I do have one but I wanted to use it for a future 40's build and wanted to use the materials I had laying around to try and make something work.
Keyboard Ownership History: Dynex(Rubber dome chicklet keys)-EXTINCT, Macbook Air 2016(Scissor switch)-ACTIVE, Razer Ornata(Mecha-membrane)-EXTINCT, Corsair K68 RGB(Cherry MX Reds)-RETIRED, Razer Tartarus Pro(Razer optical analog)-RETIRED, Idobao ID-75(NK Creams)-SHELF, HHKB Pro 3 Classic(Topre BKE MX Mount)-ACTIVE, New Model F62(Capacitive buckling springs)-ACTIVE, Realforce 23UB(Topre)-ACTIVE, BM60-RGBEC w/KBDFANS 5 Degree Case(NK BOX Pinks)-SHELF, Focus 2001 (Alps White)-SHELF, Unidentified Vintage MX Black Board-SHELF
