Author Topic: [IC] Valkyrie1800 - An 1800 Keyboard  (Read 13042 times)
Offline CrispySenpai
« on: Tue, 21 January 2025, 20:17:05 »
Valkyrie1800
Designed by Zizzi
311986-0
Specifications
Case:
Layout - 1800
Mounting - leaf spring o ring gasket
Material - Anodized 6063 Case top & bottom, Brass mid-piece
Weight ~3kg/6.6lbs unbuilt
Typing angle - 7 degrees
Front height -  18mm
Standard plate - 5052 Aluminum full plate & half plate, anodized black
PCB - Designed by Gondo
PCB Layout support
311953-1
Plate Design
311984-2
Design & Mounting
(Why 1800?)
The Valkyrie was designed first and foremost with my preferences in mind, and the 1800 layout is my personal favorite layout option - it strikes a balance between full functionality, while also not taking much more space on the desk compared to a TKL. I have received a lot of feedback that choosing a TKL layout or smaller would likely perform better and receive much higher sales. While this may be true, not only have I put my personal preference above that, but I do believe that the larger keyboard layout space has not yet been quite as saturated with countless amazing options as has the TKL and 65 spaces.
I decided to employ my personal favorite mounting system; leaf spring o ring gasket. The sound and feel produced by this mounting system is, in my opinion, unmatched.
Depicted on the underside of the keyboard is the well known mythological valkyrie from Norse mythology, crowned in her winged helmet, ready to guide slain heroes to the afterlife. After making so many trips to the afterlife, it seems that she, too, has been touched by the rot and plague and death of the afterlife herself, hence the use of patina in the weight and the intermingling of materials. The side profile aims to depict that very inner rot being visible through the grated helmet that is the top case. On the top side, there is a PC badge of a flower bursting with the infectious rot she has stored within her (any similarity to a recognizable video game character is purely coincidental).
Rendered Colorways
Goddess of Rot
311955-3311957-4
311959-5311961-6
Undefeated Valkyrie
311963-7311965-8
311967-9311969-10
Blade of the Empyrean
311971-11311973-12
311975-13311977-14
Sales Info
TBA
Still in the process of aligning with the factory that can produce the patina finish. The performance of this interest check will influence that alignment.
Discord to follow updates; https://discord.gg/XfjXhgPP
311996-15
« Last Edit: Wed, 22 January 2025, 17:26:21 by CrispySenpai »
Offline Gtour
  • Just a random guy passionate about keyboards.
Re: [IC] Valkyrie1800 - An 1800 Keyboard
« Reply #1 on: Wed, 22 January 2025, 04:44:11 »
Why do I keep hearing: ''I am Malenia, Blade of Miquella'' :-\
GLWIC, the red patina brass fits the theme really well :)
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Wed, 22 January 2025, 17:10:36 »
Ok, good job Crispy! I really like what you've come up with here. Definitely got a unique look & I'm a sucker for a good 1800 also. Two things I'd love to see here are a Cherry lip (you got a low front height already but I think it would make the KB that much more comfortable & look great too) & support for split - on the numpad on the PCB. GLWIC!
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #3 on: Thu, 23 January 2025, 10:08:39 »
This is a really cool project!
Offline jd
« Reply #4 on: Thu, 23 January 2025, 18:44:44 »
I approve of this.  :thumb:
Offline hwalker84
« Reply #5 on: Thu, 30 January 2025, 10:38:32 »
Discord link is expired.
« Reply #6 on: Sun, 02 February 2025, 20:16:37 »
Apologies for the expired link! Try this one; https://discord.gg/H24jje7d
Offline vodanhdaisu
« Reply #7 on: Wed, 12 February 2025, 01:48:03 »
Im very interested in this project. I love 980 and 1800 layout. This keyboard definitely will be 1 of my collection
« Reply #8 on: Sun, 16 March 2025, 17:41:28 »
https://discord.gg/tFHB23aVh9
I fixed the discord link so it shouldn’t expire any more, apologies
Offline herc1203
« Reply #9 on: Tue, 07 October 2025, 22:37:52 »
GHIs this still active?
Offline Tune Lab
« Reply #10 on: Wed, 15 October 2025, 03:36:02 »
It is simply a piece of art tbh :D
