Author Topic: Best option for custom keycaps now that WASD Keyboards is gone?  (Read 45601 times)
Offline alexcr
« on: Thu, 06 February 2025, 05:01:17 »
I've used WASD Keyboards several times for custom keycaps, both full sets and individual one-off keycaps.  I was saddened to discover just now that they've closed shop.
Who are the best alternatives for this kind of thing?
Offline SwearWolf
Re: Best option for custom keycaps now that WASD Keyboards is gone?
« Reply #1 on: Wed, 03 December 2025, 09:33:19 »
Late response, but YUZU custom keycaps might have what you need!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #2 on: Wed, 03 December 2025, 14:58:40 »
Link - https://yuzukeycaps.com/
Offline goodnaruk
« Reply #3 on: Fri, 05 December 2025, 10:27:45 »
big fan of www.thockfactory.com you have more color options and far easier to upload your own art where yuzu makes you use vectors.
Offline dvorcol
« Reply #4 on: Fri, 05 December 2025, 14:29:11 »
Thank you, hadn't seen this before!
One question (I am probably missing something obvious). Looking under Custom Keycaps there are three lists: Layout, Keyboard, and Language. Clicking "more..." at the bottom of any of these lists takes me directly to the editor. Do you know how I can see the full lists?
Offline ehov
    • Thockfactory
« Reply #5 on: Sun, 25 January 2026, 09:44:36 »
Founder of Thockfactory here! The complete list is in the configurator itself, at the top left where the layout selector is. There are about 100 layouts implemented currently, but if you need something specific I can send you a custom config file for it :thumb:
Offline dvorcol
« Reply #6 on: Sun, 25 January 2026, 15:37:40 »
Hey everyone!  ;D If you’re into custom mechanical keyboards, you should definitely check out Gimsun Custom. They’ve got all kinds of layouts and keycap styles, and you can even customize your own design. Take a look here: https://gimsuncustom.com/
 – it’s worth exploring! :thumb:
newgimsun recommended this in another thread.
Offline N8N
« Reply #7 on: Tue, 11 August 2026, 14:25:52 »
hey thanks for posting that.  I'm sorely tempted to see if they'll do two color dye sub on one cap or if that is not possible - then I'd try to duplicate an old Model M
