Author Topic: [IC] Qi65 - A Traditional Gasket Mount and Hefty Board - Yan Studio  (Read 16094 times)
Offline ryanlau998
UPDATES
Hi guys, long time no see, here are some updates regarding this project :)
1. Manu changed to DDS
2. First round prototypes are received and tested, found some issues on the internal, ordered a second round prototype. (Changed the external design a little bit)
3. Colorway changed, renders at the end. Here are some IRL photos taken by my dear reviewers:)
Please Join Discord for more info and Updates! Thank you. (GH Server not allowing to post many things here)
https://discord.gg/ePY4whKvZs
And check my notion page for more detailed info there!
https://www.notion.so/2297c232d7ae8033a08ff2d68e3fc3b0?v=2297c232d7ae8035b39a000c857ab32a&source=copy_link
« Last Edit: Mon, 07 July 2025, 19:00:26 by ryanlau998 »
Offline Randomlosername
  • Gacha Done Got Me
    • IG
Re: [IC] Qi65 - A Traditional Gasket Mount and Hefty Board - Yan Studio
« Reply #1 on: Fri, 14 February 2025, 21:04:21 »
Form filled out! Hyped for the board man. GLWIC and I’ll look forward to a green review unit.  ;) ;)
Offline KeebDweeb_
    • KeebDweeb
« Reply #2 on: Fri, 14 February 2025, 21:16:25 »
This looks sexy, has pricing been determined yet?  Definitely want to pick one up.  You can send a green w/ brass unit my way for GMK BRG to go on.
Offline Bokehhbob
« Reply #3 on: Fri, 14 February 2025, 21:28:04 »
Good lord this is beautiful dude! IC filled out for ya!
« Reply #4 on: Fri, 14 February 2025, 21:34:47 »
This looks amazing!
Offline Flybeck
« Reply #5 on: Sat, 15 February 2025, 12:43:41 »
All the renders you did look solid, can we see some exploded views, views of the plate and internals too?
Offline AerosolFNTM
« Reply #6 on: Sun, 16 February 2025, 22:51:03 »
That green looks amazing! Dark Green & Brass is the one.
Offline Cringelord
  • Crack Connoisseur
« Reply #7 on: Mon, 17 February 2025, 01:23:28 »
Copper Plate.
Offline Gemmmmmmmmmmmmmy
« Reply #8 on: Mon, 17 February 2025, 01:41:59 »
65s aren't really my thing but I really love the side profile and bottom design. GL with the project!
Life seems so much smaller
Swim to the moon
Offline ryanlau998
« Reply #9 on: Mon, 07 July 2025, 18:59:41 »
啟65 - Qi65
Introduction:
Hi guys, this is rkeebs_, I have been taking pictures of my keebs and posting them on Instagram for a while. After a few months of photography, I started to struggle,
I kept thinking about what keyboards I like and what is the standard of my aesthetic and sound profile. Sometimes some keyboards look great but they come with a 1.2mm PCB and not perfect mounting styles and bad keyboard details.
And sometimes keyboards sound fantastic but they are not my type. Therefore, I decided to design one, through months of learning Fusion 360 and optimizing details, now I am glad and honored to introduce 啟65-(Qi65).
I named this 啟 because it means “start” in Chinese and I want to take this step as a start of my keyboard design journey.
Taking some of my favourites as inspirations like Glare65, Neson810E, I came up with this idea using similar keyboard structure and added Poron Gasket mount as my
final decision because after trying many different boards, poron gasket always gives me the cleanest sound profile.
Working along with Dashan from Unikeys, we have been brainstorming how the angles should be, how the edges should look and other aesthetics.
Finally, I am confident to showcase this board.
Design:
The main point I want to go with is to create straight angles and straight edges. I personally have seen too many boards with rounded corners and curves,
I am not saying I don't like them, but when it comes to creating something I like the most, I would go with straight lines and angles.
On the back, there is an engraving of the Chinese character '啟' fitting in a diamond shape to give a sharper feel to the board.
The inspirations comes from the traditional Chinese seal where ancient Chinese people used seals for authenticity.
By splitting the bottom into 2 halves, it can better showcase the copper/brass midpiece as well as the engraving in the middle.
Timeline:
2/14/2024 - Prototypes have been ordered.
Features and Spec:
65% Layout
Front Height: 17.75mm
Weight: About 2.7kg(brass) 2.8kg(copper)
Dimension: 313mm x 111mm x 17.75mm(front) 33.3mm(back)
Typing Angle: 8.2 Deg
Mounting Style: Poron Gasket x 5 (top 3 bottom 2)
PCB: 1.6mm FR4
Plate: Aluminum(Default), PC, CF, FR4 (Pending Options)
Manufacturer: Hongtu
Kit:
Top Case (Alu 6063)
Bottom Case Top (Alu 6063)
Bottom Case Low (Alu 6063)
Midpiece (Copper / Brass)
PCB (1.6mm FR4) QMK/VIA Compatible
JST Daughterboard w/ cable
Plate (Default Alu, Options: PP FR4 CF POM)
Poron Gaskets x 5 (Spare will be available)
Silicone Feet x 4 (Spare will be available)
Thank you so much for checking out!!! If you are interested, please fill out the IC form!
UPDATES
Updates Posted
