Author Topic: DIY trackball kits  (Read 27581 times)
Offline TomahawkLabs
DIY trackball kits
« on: Sat, 15 February 2025, 11:28:08 »
Does anyone know of any good trackball kits? I am looking at making a keyboard with an integrated trackball. Curious if anyone has any any experience with cheaper/diy type builds. Ideally, I would be able to mount the trackball hardware to the plate from the bottom so the trackball is flush with the plate.
Something I had found on my search was the http://xahlee.info/kbd/aball_trackball.html. This is very close to what I am looking for, just curious if there are better kits than something like this.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline Apachez
Re: DIY trackball kits
« Reply #1 on: Fri, 21 February 2025, 13:12:41 »
Im looking at getting a keyball from holykeebs.
Offline YALE70
    • Hackjob
« Reply #2 on: Wed, 05 March 2025, 21:49:21 »
I'd check out the Ploopy Nano if you haven't already found something. The bearings might sit a little too far up for your purposes, but it is open source so you could modify it to suit your needs.
« Reply #3 on: Sat, 08 March 2025, 00:17:46 »
2nd recommend for Ploopy
