Hello,This is Moyu.stduio
This time we are bringing wild gardenia switch, designed by Moyu.studio and produced by Wekt.
Who is Wekt?They are the latest switch manufacturing factory and also the inheritors of lichicx.
They have a complete set of production lines and molds, as well as a complete set of technology inherited from Lichicx, and are still continuously innovating, making them a very powerful new factory
Wild Gardenia is also the first product of Moyu.studio's collaboration with Wekt
![[IC]Wild Gardenia linear Switch 312520-0](https://geekhack.org/index.php?PHPSESSID=52a1vc0tjl8ve21va1tv9jjskre63aea&action=dlattach;topic=124600.0;attach=312520;image)
Wild Gardenia switch specifications
- Linear
- 22mm lengthening spring
- Modified POM stem
- POK top housing
- PA66 Nylon bottom housing
- Factory lubrication
- 3 pin
- 4mm travel
- Pre-travel: 2.0mm
- Actuation force: 45g
- Pressure point force: 56g
- Designed by Moyu.studio
- Made by WEKT![[IC]Wild Gardenia linear Switch 312522-1](https://geekhack.org/index.php?PHPSESSID=52a1vc0tjl8ve21va1tv9jjskre63aea&action=dlattach;topic=124600.0;attach=312522;image)
![[IC]Wild Gardenia linear Switch 312524-2](https://geekhack.org/index.php?PHPSESSID=52a1vc0tjl8ve21va1tv9jjskre63aea&action=dlattach;topic=124600.0;attach=312524;image)
At the beginning of the design, our design concept was to create a switch that features a typing sensation.
So we chose a spring pressure similar to the traditional cherry red switch, but the difference is that we extended the spring to 22mm to achieve a more elastic feeling.
In terms of material selection, we also chose very traditional POM stems and PA66 bottoms. The combination of these two materials makes typing smoother, and the combination with POK tops is also very good.
Overall, the Shanye Gardenia Switch is a switch that is more inclined towards typing, and everything is designed to serve typing,On this basis, the wild gardenia switch also has a relatively dull sound, which is unique among lichicx switches.
In terms of color, we chose white with a hint of light purple, giving a very elegant feeling that fits the theme of wild gardenia flowers.
The Wild Gardenia Switch is a very distinctive switch. If you want to try a fresh switch, I think you would be willing to try the Wild Gardenia Switch.
Sales method: Inventory sales
Price:0.3$/PCS(Adjustments will be made according to the region)
