Author Topic: [GB] Caerdroia TKL by AKB (GB CLOSED)  (Read 10519 times)
Offline Alchemist Keyboards
    • Alchemist Keyboards
« on: Wed, 26 March 2025, 13:08:54 »
Links:
AKB Website
AKB Discord
See Caerdroia at CannonKeys
See more details on the IC thread here
Specs:
Compatibility:
Fixed plate support,
Solder MX PCB,
Alps PCB:
Hotswap MX PCB
Alps Plate (MX stabs by default)
Plate files with OG stabilizer compatibility will be open sourced
EC Plate
The PCB will support EC Naevies, however the plate will not. Plates will be open-sourced via an EC plate generator from Cipulot at a later date.
Colorways:
Dolch
E-Beige
Verdant
Alta Rubedo
Prototype Photos:
Note: The first top case part was missing an engraving so when a replacement was shipped out it had a slightly different shade, hence the slight two-tone look.
GB Details & Pricing:
  • GB live from Friday, 11th April 2025.
  • Shipping ETA Q4 2025.
Costs may vary between regions
  • Caerdroia (Anodised Colours) - $420
  • Caerdroia (E-Coat) - $430
  • Extra Solder PCB - $50
  • Extra Hotswap PCB - $55
  • Extra USB 3.0 Hub Kit - $50
  • Extra Thicc Plate - $65
  • Alps Kit Add-On (Plate + PCB) - $90
  • EC Kit Add-On (Plate, PCB, Hardware) - $90
  • Extra AKB Feet (16) - $4
Kit Contents:
  • Aluminium Top + Bottom Case
  • Powdercoated Brass Weight
  • PCB
  • Custom Hybrid USB 3.0 Hub/USB-C Daughterboard
  • Molex Cable
  • 4.5mm PC Plate (Smoky Black)
  • Force break gasket
  • AKB Feet
  • CannonKeys Hard Carrying Case
  • Microfiber Cloth
  • Screws And Hardware For Assembly
Vendors:
  • US: CannonKeys
  • UK: Thocc Exchange
  • EU: Keygem
  • CA: minokeys
  • CN: zFrontier
  • OCE: Daily Clack
  • KR: GEON
  • SG: iLumkb
« Last Edit: Mon, 12 May 2025, 09:38:46 by Alchemist Keyboards »
Offline Cobertt
    • Control on Caps
Re: [GB] Caerdroia TKL by AKB (GB live on April 15th)
« Reply #1 on: Wed, 26 March 2025, 20:37:16 »
Absolutely love my Caerdroia from the initial drop. Best of luck, it’s a fantastic board.
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65 |  Midway LE |  Kei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Re: [GB] Caerdroia TKL by AKB (GB live on April 11th)
« Reply #2 on: Thu, 27 March 2025, 12:14:10 »
New vendors announced! (still more TBD)
EU: Keygem
CA: minokeys
« Last Edit: Mon, 31 March 2025, 03:05:22 by Alchemist Keyboards »
« Reply #3 on: Fri, 28 March 2025, 09:57:51 »
CN: zFrontier
OCE: Daily Clack
« Reply #4 on: Mon, 31 March 2025, 03:05:53 »
New vendor announced!
KR: GEON
« Reply #5 on: Mon, 31 March 2025, 12:56:21 »
SG: iLumkb
Offline Punkypj
« Reply #6 on: Sat, 05 April 2025, 07:05:52 »
Will the EC pcb support iso, split ls, split bs etc? Confused as the compatibility just mentions the plate being outsourced?
« Reply #7 on: Sat, 05 April 2025, 08:46:22 »
The PCB will basically support everything - it's just the plate which is fixed. You can see the full PCB compatibility here.
Offline aumz.work
Re: [GB] Caerdroia TKL by AKB (GB live!)
« Reply #8 on: Fri, 09 May 2025, 20:25:37 »
The bottom serem really cool
Re: [GB] Caerdroia TKL by AKB (GB CLOSED)
« Reply #9 on: Mon, 12 May 2025, 10:13:07 »
GB closed, thanks to everyone who joined!
