Author Topic: [IC] DK1-TKL- Budget Copper Bottom Board  (Read 12561 times)
Offline Metakeebs
    • metakeebs
« on: Thu, 15 May 2025, 10:18:00 »
Hi all,Charlies here from MetaKeebs.
Today we would like to bring you a new keyboard from GDK Lab. We have set the price and the configuration of it for the moment. If you are interested or have any suggestions, you can leave your opinions on the IC form or in the comment section. Your suggestions are the greatest help to us!
IC Form: https://docs.google.com/forms/d/e/1FAIpQLScKXHU0i_57P4Mk-FIKKDjVHJbJtmCVnEAFlUO8Ue9o39Sisw/viewform?usp=dialog
After a period of preparation, we bring you this Full Copper Bottom TKL - the most budget, but no less premium.
Design:
The D-Series is a new line of products that GDK Lab is working on, which still maintains the geometric style of line-cutting as the main focus in design.
We wanted the new line to be innovative and change the way we use materials and play with the core.
The All Bottom Case of DK Series is made of copper/Brass,
for which we have brought two finishes:
Brass/Copper Original Color:
The surface finishing of the copper is the major reason for the delay in progress.
It is very difficult to make the copper to achieve the smooth and delicate texture like anodized, we have gone through 5 times of prototyping and debugging,
the finished product makes us very satisfied, so that the copper bottom has the same feeling and fineness as the 180 mesh anodized.
Brass Bottom Case:
Copper Bottom Case:
Coating Brass/Copper Bottom Case:
Front Design:
We have adopted a narrow bezel processing, the front of the most eye-catching when it comes to the badge above the arrow keys,
we use two pieces of stainless steel parts combined with the same cutting and counterweight to modify the level of the same way,
and at the same time will be the plane and the corner of the plane and the cut surface of the same body with a bright fog pvd process
to do the visual differentiation, the sense of hierarchy is more intense.
In the light strip we also carried out physical layering, so that the light can also be presented from bright to dark excessive effect!
Stone pattern process.
We have added a stone process replacement for the front Badge, through a special process so that the metal can also show the effect and texture of stone.
Side Profile Design:
The side expresses hierarchy by overlapping the top, middle and bottom parts,
and we narrowed the front edge of the top cover to make the front edge visually more low-slung
Bottom Case Design:
DEFINED is shaded in the center of the bottom case and is also the theme of the whole keyboard.
We have set up multiple materials and processes for the counterweights to give them different visual effects when combined with the bottom case
Structure:
Slotting:
As the picture expresses, on the Bottom Case we have used a deranged slotting method, which greatly reduces the cavity space in its original state,
allowing the kit to have a much better performance while completely forgoing Foam additions
Core Daughterboard:
We have adopted the previous DIY player's sub-panel idea, the main control and key components integrated in the DB,
while in the bottom case reserved signal openings, so that the stability of the wireless and the link distance is guaranteed,
and then through the customized magnetic row of pins will be the matrix output to the board to achieve functionality,
this move allows us to further reduce the cost of the board, allowing players to try a lower price for more guts to replace the game!
Gaskets Structure:
We set up a dual structure, silicone Plate Gasket structure and silicone PCB Gasket structure.
At the same time we provide 1.6mm PCB and 1.2mm Flex-Cuts PCB, two kinds of pcb using different force arm and silicone parts,
and each kind of silicone parts have two kinds of hardness, players can according to their own preferences for assembly.
Two very different styles of inner liner can meet the needs of most players!
Ball-Catch :
Features:
TKL Layout
Full Copper/Brass Bottom Case
Geometric Line-Cutting Design
Stone Texture Badge Option
Dual Gasket Structure
Budget-Friendly Premium Build
Innovative Daughterboard
Deranged Slotting for Sound Optimization
DEFINED Theme & Customizable Counterweights
Flexible PCB Options
Light Strip Layering
Case Color:
Anodized:
Silver, gunmetal gray, titanium gray, dark gold, black, dark purple, burgundy
Coating:
Flash White, Wheat Whirlwind, Sunflower Yellow, Star Gray, Milk Curry, Ultra Light Pink, Canvas Blue
Specification:
Front height: 15.5mm
Typing Angle: 7°
Weight (tri-mode version):
Aluminum Weight assembly : 2870g
copper Weight assembly: 3350g
PCB:
1.6mm solder
1.6mm hot-swap
1.2mm Flex-Cuts hot-swap
Plate:
Aluminum:
FR4:
PC:
Foam:
Accessories:
Price:
GB Date: TBD
Vendor List:
US and CA: Unikeys
OCE: KeebzNCables
UK: Prototypist
EU: Keygem
SG: TBD
Thailand: TBD
Philippine: TBD
Indonisia: TBD
Our Discord: https://discord.gg/vUkVgP25jA
To conclude
we hope that GDK Lab can bring you a different product experience and we will continue to develop more innovative products.
Please share your thoughts. We will listen to them and make improvements!
« Last Edit: Sun, 18 May 2025, 01:15:35 by Metakeebs »
Offline keepoto
  • HHKB top for TKL pls
Re: [IC] DK1-TKL- Budget Copper Bottom Board
« Reply #1 on: Thu, 15 May 2025, 10:43:33 »
hhkb top?
Offline ivanh98
« Reply #2 on: Thu, 15 May 2025, 11:00:35 »
oh my those thin side bezels. this peeks my interest (im not a tkl guy). glwic
Offline ivanh98
« Reply #3 on: Thu, 15 May 2025, 11:07:33 »
oh and the price is great!
Offline Metakeebs
    • metakeebs
« Reply #4 on: Thu, 15 May 2025, 11:17:20 »
hhkb top?
No, but if everything goes smoothly, we will have a DK1-60% PO in the future, and then there will be hhkb top :p
« Last Edit: Thu, 15 May 2025, 11:19:31 by Metakeebs »
Offline Metakeebs
    • metakeebs
« Reply #5 on: Thu, 15 May 2025, 11:17:32 »
Offline Mr.RotKiv
« Reply #6 on: Thu, 15 May 2025, 11:20:35 »
Please tell me the final version will support PCB mounted stabilizers..?
Offline Metakeebs
    • metakeebs
« Reply #7 on: Thu, 15 May 2025, 12:55:43 »
Support!
Offline rfcclub
« Reply #8 on: Thu, 15 May 2025, 17:49:10 »
Finally GDK TKL is on geekhack. It's great price for a full copper TKL, even with full brass. GLWIC !  :thumb: :thumb: :thumb:
Offline frankoceanfan_0
« Reply #9 on: Fri, 16 May 2025, 04:38:47 »
Hello there, in some sound tests that I have heard of this keyboard's prototypes the spacebar sounds quite dull and muted. Will this issue be fixed in the final versiom? It's the only thing making me hesitate before getting this.
Offline Metakeebs
    • metakeebs
« Reply #10 on: Fri, 16 May 2025, 19:17:02 »
Thank you!
Offline cijanzen
« Reply #11 on: Sat, 17 May 2025, 09:17:19 »
Looks like the discord link expired, can you setup a new one?
Offline Sieglinde
« Reply #12 on: Sat, 17 May 2025, 16:46:08 »
Looks great overall but I rather not have that swappable accent piece or light strip.
Offline ivanh98
« Reply #13 on: Sat, 17 May 2025, 17:51:56 »
+1
Offline Metakeebs
    • metakeebs
« Reply #14 on: Sun, 18 May 2025, 01:13:05 »
Yeah one moment
Offline Metakeebs
    • metakeebs
« Reply #15 on: Sun, 18 May 2025, 01:14:57 »
Offline Ceyx
« Reply #16 on: Sun, 18 May 2025, 06:44:40 »
hhkb top?
Please, let it have wireless, too.
Don't know if I have the funds now for this, but the 60% will be a sure buy if it will come with tri-mode.
Offline Metakeebs
    • metakeebs
« Reply #17 on: Sun, 18 May 2025, 08:56:00 »
hhkb top?
It has wireless, and DK1 has a very unique design. With the use of Pogopin, the battery can be easily removed. Therefore, the wired version and the wireless version only differ by a battery and some small accessories. Switching to the wireless version is very convenient
Offline Ceyx
« Reply #18 on: Thu, 05 June 2025, 10:22:38 »
hhkb top?
I meant I hope the 60% will have wireless, too.
I am skipping the TKL in favor of 2-3 60%‘s later.
Offline meowoofun
« Reply #19 on: Sat, 07 June 2025, 07:07:53 »
I'm in for this, thank you for supporting wireless!
Offline Metakeebs
    • metakeebs
« Reply #20 on: Sun, 08 June 2025, 04:35:01 »
hhkb top?
Yeah 60% also will have the wireless and battery
Offline tankLancer
« Reply #21 on: Wed, 18 June 2025, 08:19:36 »
the design is fantasitic.
will there be a vendor for China?
Offline IAmAPeach
« Reply #22 on: Thu, 19 June 2025, 02:51:40 »
Ball catch and magnetic JST connector are major flaws to me, would be great if there was a version that was screw and wire
« Last Edit: Thu, 19 June 2025, 02:54:00 by IAmAPeach »
Offline blondie
« Reply #23 on: Sun, 22 June 2025, 13:01:38 »
I'm surprised no one asked this question yet. What are those three sliders on the upper right side? Is this just decorative, or functional?
Looks interesting.
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline ivanh98
« Reply #24 on: Sun, 22 June 2025, 14:40:00 »
decorative according to their discord
Offline KimJongUwU
« Reply #25 on: Sun, 22 June 2025, 15:48:39 »
Looks interesting.
They're for pretending to DJ in front of your computer. We've all done it.
