Author Topic: How a carbon keybroad look like  (Read 29675 times)
Offline dipincoke
« on: Fri, 23 May 2025, 10:55:07 »
It is an honour for miestertype to offer to everyone the world's first fibercarbon keyboard.
As you may be aware, this material is used in the space sector as well as hypercars.
But why is it the case?
Concerning the Carbon 65 specifics
The frame is made of inner chopped carbon and wrapped in a weaving pattern (optional).
Mount
We use our new invention in mounting system identical to gasket system but without the screw between plate and case, which allows for individual customization not only on material but also on whereas sound make different (ex: spacebar plate without gasket makes this particular spacebar sound more hollow and louder).[img][/img313607-0313609-1313611-2313613-3313615-4313617-5]
Pcb Pcb comes with a 65% layout, both solder and hotswap options, bluetooth, and wiring.
Brass weight is built within 2.2kg and is appropriate for fixed setup.
Non-brass weight construction 0.8kg ideal for mobility
The material's stiffness causes the sound to be distinct.
Individual sound modification is possible due to the mounting technique.
Why should you have this art at your office?
This is a masterpiece that is handcrafted with a distinctive look that emphasises the owner's characteristics. The rigidity and durability of this item make it survive longer than time and trust worthy for every usage
Offline kovakeys
    • Kova Keys
Re: How a carbon keybroad look like
« Reply #1 on: Thu, 16 October 2025, 01:47:26 »
That's very cool. How is this going? I see that it's been a while since anyone has replied to it. Have you been able to bring this to market?
I was working with some carbon fiber material with some Chinese vendors. It's very expensive to make some prototypes. Carbon fiber is much more expensive to work with than PC and aluminum. How have you found this in your manufacturing process?
Offline Esme_Hong
« Reply #2 on: Tue, 01 September 2026, 01:32:47 »
Carbon fiber seems like a really interesting choice for a keyboard case. The weight difference between the brass and lighter version is pretty significant too. I’d be curious to hear how the sound and feel hold up after extended daily use.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #3 on: Wed, 16 September 2026, 19:58:03 »
Lookin good, dip :cool:
