Author Topic: PLU ML-87 with POM keycaps  (Read 71184 times)
Offline manfaux
« Reply #50 on: Mon, 03 January 2011, 15:39:10 »
Quote from: fssbzz;272527
their 87key is 399 rmb
for $60 it seems like a unbeatable deal, bring them stateside please!
Offline laden3
« Reply #51 on: Mon, 03 January 2011, 15:44:00 »
Korean too.
I rrrove brrracks.
Offline kidchunks
« Reply #52 on: Mon, 03 January 2011, 15:46:42 »
Paid a little less when I bought mine with browns. I will see what issues arise when using it.
Topre || BS > *
my root : kidchunks[dot]com
Offline elbowglue
« Reply #53 on: Mon, 03 January 2011, 16:03:53 »
That's more cherry boards than elitekeyboards sold in the same period. :)
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Doober
« Reply #54 on: Mon, 03 January 2011, 20:26:00 »
i got my white version pics are in mail sub forum
and my NKRO is broken too, it is mentioned in there
regardless i missed my browns on my compaq and im loving these plate mounted ones even more..... now to find a use for the noisy M..........
http://geekhack.org/showthread.php?t=13974
-doober
Quote from: ripster;234844
Actually this is what I said.  Taking a factoid and reaching an outrageous conclusion is what I call the Glenn Beck debating style.
Compaq MX11800 (x3), IBM Model M, PLU ML 87, NMB, SIIG Minitouch, Topre Realforce, Filco Majestouch 2
[SIGPIC][/SIGPIC]
Offline iMav
  • geekhack creator/founder
« Reply #55 on: Tue, 04 January 2011, 02:13:13 »
Can someone point me to the appropriate link for a white one with blue Cherrys?  (I can only find browns (assuming the pictures are any indication)).
Offline laden3
« Reply #56 on: Tue, 04 January 2011, 02:19:24 »
I rrrove brrracks.
Offline iMav
« Reply #57 on: Tue, 04 January 2011, 02:20:25 »
Thanks. I forgot about this useful nugget in the wiki:
Cherry MX Blue: 青轴 (they call it green)
Cherry MX Brown: 茶轴 (they call it tea)
Cherry MX Black: 黑轴
Offline speakeasy
« Reply #58 on: Tue, 04 January 2011, 02:20:43 »
http://item.taobao.com/item.htm?id=8437652604
Select the 青轴 option when ordering.
[sigpic][/sigpic]
PiaNoppoo Choc Mini 茶轴
PUNCH THE KEYS FOR GOD\'S SAKE!
Offline fssbzz
« Reply #59 on: Tue, 04 January 2011, 02:21:38 »
Offline kidchunks
« Reply #60 on: Tue, 04 January 2011, 08:18:19 »
The nkro issue has something to do with that damn ELAN chip I bet! Prolly the same reason choc mini's are flaky on macs. Hey doober, be sure to open it up to see if it has the same cut out defect as the blacks.
Can't wait to get mine!
Topre || BS > *
Offline Doober
« Reply #61 on: Tue, 04 January 2011, 12:58:13 »
open mine :( its tooo newwwwwwwwww
agaahgah
-doober
[SIGPIC][/SIGPIC]
Offline kidchunks
« Reply #62 on: Tue, 04 January 2011, 13:14:24 »
Quote from: Doober;273038
agaahgah
-doober
Would have opened mine, but you got it before me :P
Topre || BS > *
Offline nocturn4l3030
« Reply #63 on: Wed, 05 January 2011, 19:30:04 »
are POM keycaps considered cheap? or is it a good?  what material does a Filco/Ducky use?
i'm lookin at the keycap wiki and all i see is that the POM is expensive and not common.. but would like opinions on the feel of these.. thinkin bout getting one of these in white, but not if the keys feel cheap
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline fssbzz
« Reply #64 on: Wed, 05 January 2011, 19:31:20 »
POM are better then Filco's abs.
Ducky use PBT.
Offline kidchunks
« Reply #65 on: Wed, 05 January 2011, 20:40:01 »
Since some reports stated(previous page) that 6kro and even nkro are malfunctioning on this board, I would stay away and look for something else if you plan on doing heavy gaming.
I was planning on using this board at work anyways so it ain't problem that the kro is not working as advertised. Still a sweet looking board!
Guess Doober and me are the only GHers riding the PLU Express.
Topre || BS > *
Offline Doober
« Reply #66 on: Wed, 05 January 2011, 22:52:38 »
Yup , and kidchunks I love mine!!!!
also, the white version isn't POM it is ABS supposedly
also I do heavy gaming lol i have played SC not SC2 since i was in 4th grade, and never had NKRO. I also play CS, CSS, TF2, and WoW.
-doober
lack of or malfunctioning NKRO is disappoint, but maybe some true Geekhacker can figure out a fix :)
edit: i ordered this kb chunks for that very reason to be the first to have it
[SIGPIC][/SIGPIC]
Offline kidchunks
« Reply #67 on: Thu, 06 January 2011, 08:07:50 »
When did you place your order? Placed my order in the mid of December and still haven't received it. But I also ordered some other stuff so they bundled it together. Probably why its taking so long!
Topre || BS > *
Offline Doober
« Reply #68 on: Thu, 06 January 2011, 13:14:57 »
just checked i placed on Dec. 23 2010, then i did DHL (which was a lil high but meh) and i got it 1/3/2011 so roughly 1 week from order date
[SIGPIC][/SIGPIC]
« Reply #69 on: Fri, 07 January 2011, 15:51:21 »
Quote from: kidchunks;273825
ah yea good lookin out...i was thinking about how many keys do i really ever press at one time and at most it would be 3... i would think these boards would at least have 3kro?? kinda sucks because it seems every one of these boards is a "surprise"..u never kno what youre gonna get lol
but the price is so cheap that im really really thinking of taking the risk. that and also i cant find a good white colored blue switch board anywhere except made by ducky...unless someone can help me find one -.-;
[/strike]
[/SIZE]
« Reply #70 on: Fri, 07 January 2011, 15:53:16 »
Quote from: Doober;273872
-doober
can u kindly check for me if your board has 3kro? -.-
[/strike]
[/SIZE]
« Reply #71 on: Fri, 07 January 2011, 18:06:45 »
Quote from: ripster;274880
Although technically possible to get something between 2KRO and 6KRO I've never seen it.  I've only seen sloppy testers who give up too quickly.
Plus they must not teach Mininum and Maximum in Grade School in cities where OCN'rs live.
ah damn i didn't know that.....
hMMMmmmmm
that really sucks.. i only use 2 keys at most but if there's a FPS i want to play i might need 3......
damn the ****ty manufacturing.. guess that explains the price
aklsdfjalkdsfjasdlkjf
[/strike]
[/SIZE]
Offline Doober
« Reply #72 on: Fri, 07 January 2011, 20:21:52 »
ripster is Right, but with this board it is only a few combos that fail.
For instance you cannot hold down more keys if both Shifts are held down. I play CSS and COD, and I used to manage just fine on my IBM model M.
also my PLU 87 passes a lot of the common fps combos, WASD cluster and ctrl, shift, 1-6. c, v, x, z.
i just have never noticed myself in a video game using more than 2-3 buttons at a time.
and with WoW it is usually some form of WASD and Shift and 1-6 it passes that too
if you want what is so far my favorite keyboard and White with cherry browns, then I would go for it.
also something neat, is that they replaced the right windows key with a key that disables the left windows key. it has this neat underglow effect when on.
-doober
[SIGPIC][/SIGPIC]
« Reply #73 on: Fri, 07 January 2011, 20:56:13 »
Quote from: Doober;274949
-doober
awesome, thanks so much for that. pretty sure im going to order this now ;D the price is awesome
[/strike]
[/SIZE]
Offline fssbzz
« Reply #74 on: Fri, 07 January 2011, 22:33:06 »
they are actually gaming optimized KRO
Offline bakageta
« Reply #75 on: Sat, 08 January 2011, 01:54:42 »
Can anyone with this board test the arrow keys? I'm going to be so bummed if I can't hit all 4 at once... :(
Offline Doober
« Reply #76 on: Sat, 08 January 2011, 02:14:02 »
Quote from: bakageta;275048
I believe i am the only one on here currently with this keyboard, and yes I will test that for you.
this is how it goes
Success
Left + Up | Right + Up + Down | Left + Down + Right
Failure
All Four  | Right + Up + Left
is that all i was getting confused lol
-doober
[SIGPIC][/SIGPIC]
Offline bakageta
« Reply #77 on: Sat, 08 January 2011, 02:20:09 »
Going to have to keep my Filco around for Stepmania then it seems... :( Sadly one of the very few games I play that actually needs nkro or something close to it.
Offline zakazak
« Reply #78 on: Sun, 29 May 2011, 15:00:58 »
read that thread and if i got it right:
6 keys at the same time arent working.. however, you can press enough keys on the same time to have no problems at all when gaming?
Offline zakazak
« Reply #79 on: Sun, 29 May 2011, 15:24:12 »
also when using it via USB ?
3 key combos failing.. that would suck.. i sometimes have to press "W" + "A" + "CTRL" + "SHIFT" when gaming.. or "W" + "D" + "CTRL" :/
Offline foliolio
« Reply #80 on: Sun, 29 May 2011, 15:28:22 »
Quote from: zakazak;352881
6 posts above yours on page 6:
Quote from: Doober
Offline foliolio
« Reply #81 on: Sat, 04 June 2011, 10:28:00 »
Apparently there's a new revision of ML-87 with NKRO hitting the stores soon, plenty of shops list this on TaoBao already.
Offline Ryun
« Reply #82 on: Tue, 07 June 2011, 14:13:50 »
Quote from: foliolio;355509
Would you mind shooting a link to this info or elaborating on how to spot the difference? I live in the US so I doubt I'd get any NKRO goodness any time soon, but there are a couple of ebay vendors that carry them. I'd like to ask them about NKRO but I don't know what to ask that would give me a guarantee.
Offline mmm
« Reply #83 on: Wed, 15 June 2011, 09:39:10 »
Mine is from april 2011 (as the little blue sticker says).
Does anyone how to open it? I can't see any screws at the bottom. Is there a screw below the small round ML sticker? (If not, i don't want to destroy that cute little sticker :wink:.)
Beginners question: now that i have tenkeyless, how do i type alt+219? :tongue: (Without buying a numpad.)
The shift + scroll-lock maybe only works on those IBM's?
« Last Edit: Wed, 15 June 2011, 09:48:37 by mmm »
Some KB\'s I have: White PLU ML87, black PLU ML87, Chicony KB5181 TDC3100061, fullsized Lexmark/IBM.
Offline cactux
  • Topre Knight
« Reply #84 on: Wed, 15 June 2011, 09:53:35 »
Did someone ordered one already? I would like to see how good/bad looks the inside
[FS]☠ The temple lol ->HERE<-
Offline mmm
« Reply #85 on: Wed, 15 June 2011, 10:10:32 »
I think a one eyed prostitute would not get much clients and thus go out of business and thus a special symbol would not be needed.
Hmm... Charmap... But it takes ages to find the wanted symbols there... I guess i should have bought a more expensive keyboard with a num-key... (But this one was already almost €70 after shipping and obooking.) They could've used that useless disable_winkey on this keyboard for that.
Btw, the LED's are too bright.
Quote from: cactux;361067
Yes i'm typin on one manfactured april 2011 right now. But i don't know how to open it. And don't want to break it trying to find out...:tongue1:
« Last Edit: Wed, 15 June 2011, 10:15:39 by mmm »
Offline noodles256
  • le legendary
« Reply #86 on: Wed, 15 June 2011, 10:14:22 »
don't worry, my topre is on the way.
nice name change btw
AF | Ducky YOTD |
Offline mmmty
  • bang! bang!
« Reply #87 on: Wed, 15 June 2011, 10:16:55 »
I didn't change. I'm the guy with the block head.
I'll send yours out in about an hour.
Keyboardless
Offline mmm
« Reply #88 on: Wed, 15 June 2011, 10:17:04 »
Topre? I thought this thread was about the PLU ML-87.
Offline noodles256
  • le legendary
« Reply #89 on: Wed, 15 June 2011, 10:17:40 »
i know, i kid
IMPOSTER
AF | Ducky YOTD |
Offline mmmty
  • bang! bang!
« Reply #90 on: Wed, 15 June 2011, 10:19:37 »
PLU ML-87 with Topre?
Keyboardless
Offline mmm
« Reply #91 on: Wed, 15 June 2011, 16:16:01 »
Using a sharpie on the LED's of my most expensive keyboard ever... No way! :)  (No i didn't buy a Happy Hacking one yet... :P.)
Haven't found out how to open the KB anyway... Well i think i have to remove the small manufacturing date sticker.
I think i'll just put some ugly white sticker over it.
A slight factory mod (it almosts fits now) of the keyboard in the future would enable putting a LEGO stud in it (and thus a colored see through LEGO would fit on it).
Like a siamese twin?
« Last Edit: Wed, 15 June 2011, 16:19:20 by mmm »
Offline mmm
« Reply #92 on: Sun, 03 July 2011, 17:41:22 »
First I thought there was a bug with the " and the ' keys, but now I see it happens with another keyboard too. So you can forget about that.
Hate the logo, and I'm not a big fan of the case.
I've got the white keyboard, and the logo is white (both white and black seem to exist), with kinda holographic characters. It isn't 'loud' or very notable. But of course, if you're a minimalist then it could be bothering.
At the bottem it says: G1196999 and SN: 11040483. Anyone know what the G number is?
« Last Edit: Mon, 11 July 2011, 19:31:36 by mmm »
Offline wompwomp
« Reply #93 on: Sun, 03 July 2011, 18:04:34 »
Quick question guys, I'm thinking about buying this keyboard off of qtwan and was wondering is this board is "Gmaing optimized" 2KRO or just straight 2KRO.
Offline mmm
« Reply #94 on: Sun, 03 July 2011, 18:15:49 »
As I hardly play any games, I don't know. Although I think ripster already said something about it, but don't exactly remember what.
If you'll tell me how to test it (without installing games), I might be able to do that for you.
« Last Edit: Sun, 03 July 2011, 18:21:43 by mmm »
Offline daerid
    • Rossipedia
« Reply #95 on: Sun, 03 July 2011, 20:41:14 »
Does anybody know if the white PLU's have POM keys? Just got one from weipm, and I can't tell. He says their ABS, but they feel much, much different than any of my Filco keycaps.
Offline daerid
    • Rossipedia
« Reply #96 on: Mon, 04 July 2011, 01:35:51 »
Would that be the PLUM keyboard? It does say POM keycaps, but the box mine came in doesn't look like the box shown in the source link.
Offline scribble
« Reply #97 on: Tue, 05 July 2011, 15:40:48 »
Quote from: wompwomp;372705
Just got my keyboard today so I can tell you that if you press WASD together, there are no problems if that is your question.
Filco Majestouch Tenkeyless Cherry MX Blue | PLU ML-87 Cherry MX Red
Offline mmm
« Reply #98 on: Fri, 08 July 2011, 17:37:30 »
Quote from: daerid;372794
According to this Ebay entry it is ABS.
PLU ML-87 portable mechanical keyboard (Cherry MX Series Blue Switch)  White Edition:
-Germany Original Cherry mechanical switches, maintaining a fantastic touch-feeling for a long time. Long life (50 million operations per key)
-87-Key only, compared to the standard 104 keys, PLU87 does not have the numeric keypad (17 keys less).
-ABS laser engraving Cap.
-WIN shielding. Reduce misuse.
-Narrow frame design
-Standard 6-keys conflict-free design under USB interface which  covers 99% normal operation. 9-keys conflict-free through the USB adapter to PS/2 adapter.
-Multimedia function keys
« Last Edit: Fri, 08 July 2011, 17:39:56 by mmm »
Offline wompwomp
« Reply #99 on: Fri, 08 July 2011, 19:43:16 »
I believe the white PLU's come with ABS keycaps and the black PLU's come with POM keycaps.
