Author Topic: Stupid quick PCB design  (Read 25691 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Wed, 02 July 2025, 09:52:23 »
I was wondering if anyone would be willing to design a super simple PCB for me.  Essentially, I want this pcb but tweaked for an RP2040 controller instead of a Teensy 2.0.  I have tried many times to learn KiCad but can never seem to get the work flow down for ****.
Offline zegonix
Re: Stupid quick PCB design
« Reply #1 on: Thu, 03 July 2025, 02:50:09 »
you linked to a post by someone (with the same handle as you) on a pcb manufacturers website. is this a product you want to sell? if so, it would be in your best interest to be transparent.
Offline Melvang
« Reply #2 on: Thu, 03 July 2025, 04:53:09 »
The link is a PCB that I had done years ago, that is my account on Oshpark.  Another GH member did the Kicad work for me, by the name of Moz if memory is correct. I am not looking to sell it, unless there is interest for a GB, but I doubt it. I do plan to make the design public on Oshpark.
Offline zegonix
« Reply #3 on: Thu, 03 July 2025, 05:33:16 »
alright. on the pictures i don't see too much, but from the description i assume, the pcb houses a usb-connector, a power converter and the mcu, whose gpios are just routed to the pins?
i could do this, but it will be just functional, not pretty or sure to work in any environment (i could not guarantee for esd safety, or emi specifications..)
« Last Edit: Thu, 03 July 2025, 05:36:36 by zegonix »
Offline Melvang
« Reply #4 on: Thu, 03 July 2025, 19:31:54 »
I think I am going to give KiCad another go.  It has been probably at least 10 years since I tried KiCad.  Realisitically, I should just have to build a footprint for the through holes on the RP2040, then bring that into a pcb, set my drills for the breakout pads, and go from there, correct?  And I really don't need a schematic, I would think.
Offline zegonix
« Reply #5 on: Fri, 04 July 2025, 02:01:55 »
you never explained your goal with this board, so i can only assume. i would think that you also want a usb connector, a voltage converter, a crystal for a reasonable clock and support capacitors for every vcc pin of the mcu. also as far as i know the rp2040 is available only in qfn packages which is surface mounted and does not need through holes (apart from the vias for the ground pad). depending on your use case the usb connector is optional, usb fullspeed (12 MHz) works quite well even without good impedance matching, so you can route it off the pcb to another one, just route them as differential pair and care to keep them roughly the same length.
Offline Melvang
« Reply #6 on: Fri, 04 July 2025, 08:30:52 »
I do believe we have a slight misunderstanding.  This is the controller I currently have.  I am going to use them for a custom hand wired keyboard that will not have a traditional case, but more of an open frame chassis.  The purpose of the PCB I am wanting to make is to have something to solder my controller to and be able to physically attach it to the keyboard frame with stand offs and 6-32 thread screws.
Offline vvp
« Reply #7 on: Fri, 04 July 2025, 13:02:31 »
If you have an access to a 3D printer then you can design and print an holder for your controller. That will take care of holding it securely which is one of the reasons you want to design your "breakout board". The other feature of your "breakout board" is to provide comfortable access to the pins. But you do not need this feature since your controller already provides it (contrary to a raw MCU SMD package).
You can securely hold you controller in corners. Design slots into which the corners of the controller PCB fit tightly. Secure the corners (which are not constrained from at least four directions) with a screw. If you do this on all 4 corners then it will hold very well. It is often enough to constrain two opposing corners from 4 directions and the other two from only one direction.
See this post as an example how I fixed Arduino Micro (which has a similar PCB) to a plastic case: https://deskthority.net/viewtopic.php?p=181898#p181898 Two opposite corners (with screws) are constrained from 4 directions. The other two corners are constrained from only 3 directions. Holds well enough. It can be dismounted if needed.
Offline Melvang
« Reply #8 on: Fri, 04 July 2025, 17:32:05 »
Working now. I am not going that route because that isn't what I want. The case isn't going to be plastic. All aluminum.  This breakout board is how I want to secure it.
I have been working industrial construction and maintenance since 2007, I understand how to hold things down.
« Last Edit: Fri, 04 July 2025, 17:35:04 by Melvang »
« Reply #9 on: Fri, 04 July 2025, 18:01:30 »
I can't really stand KiCad either.
Have you tried LbrePCB? It is supposed to have a more conventional user interface.
Offline Melvang
« Reply #10 on: Fri, 04 July 2025, 18:21:20 »
I have not yet.
