Author Topic: Vintage keyboard- not working  (Read 2489 times)
Offline jcoffin1981
« on: Fri, 04 July 2025, 14:56:06 »
An associate of mine knows that I am a keyboard aficionado and gifted me a Dell AT101W that he had lying around.  It worked when last used a long time ago.  It requires a PS2 connection so I purchased an adapter, but even with the adapter Windows does not recognize that a device is plugged in.  I don't know if the board is dead, if it's a driver issue, or maybe an issue with the adapter.  It's possible Windows is very fickle about the adapter used or it is defective.
I'd like to use the board for a bit but am not really crazy about the switches used.  I will probably end up selling it for parts or as pre-owned if I can get it to work.  I'd like to have someone else enjoy it instead of it becoming E-waste.
Unfortunately, I get a message "Forbidden" when I try to post an image.
« Last Edit: Fri, 04 July 2025, 15:03:28 by jcoffin1981 »
Offline Rob27shred
  • Insane in the Membrane! 👻
« Last Edit: Sun, 06 July 2025, 10:47:06 by Rob27shred »
Re: Vintage keyboard- not working
« Reply #2 on: Sat, 05 July 2025, 07:59:45 »
This has been going on for a month or more. Really sucks.
Dell AT101 is a good solid keyboard. I have transplanted better switches into them and been very pleased.
Michael Wolff says he urged Epstein to release information he had on Trump, but Epstein appeared worried about what Trump would do to him.
Epstein told him, “I may be a pervert, but I’m not crazy.” Epstein continued, "Trump is a man without any scruples.”
Offline jcoffin1981
« Reply #3 on: Sun, 06 July 2025, 23:23:54 »
Offline jcoffin1981
« Reply #4 on: Sun, 06 July 2025, 23:30:36 »
Maybe I will keep it then.   The switches appear to be Black Alps, which I know nothing about.  They are a little heavy for my liking, and they feel kind of mushy.  I'm not sure if this is because they are old, unlubed, or if it's just the force curve.
Can I drop replace with any switch of my choosing, or am I limited to certain switches?
« Reply #5 on: Mon, 07 July 2025, 04:09:55 »
Alps switches can be replaced with other Alps switches only, or new replicas from Matias.
Replacing full switches requires soldering. There are no hot-swap sockets for Alps.
However, they can also be opened up from the top with tweezers. Then the slider, spring and click leaf could be replaced with those from other Alps switches. I think there has also been group-buys of custom springs.
When they are open, you could also take the opportunity to lube them.
One has to be careful not to mar the plastic too much, and to put the slider back in the right orientation. A trick is to mark one side of the slider with a marker before opening them.
Offline omnigeek
« Reply #6 on: Thu, 10 July 2025, 17:15:14 »
The Matias clicky or quiet-click switches are a drop-in (that is, solder-in) replacement for Alps switches. I've rebuilt a number of my Northgate Omnikey and CVT/Avant Stellar keyboards using Matias switches, and they work and feel great.  I didn't have the skill or patience to take apart and refurbish the switches, so the Matias were a good option for me.  Every now and then I'll have a switch start keybouncing or will outright fail and I'll have to replace it, but I can live with that and I bought enough spares to last me a while.
Northgate Omnikey Ultra rebuilt w/Matias clickies | Northgate Omnikey 102 | Avant Stellar | [/url]Visit the Typing Test and try!
Offline HaroldHolmes
« Reply #7 on: Mon, 21 July 2025, 01:54:57 »
Thank you so much for the info.
« Last Edit: Mon, 21 July 2025, 01:59:30 by HaroldHolmes »
