Author Topic: [IC] 825 - a simple 1800 office keyboard  (Read 5333 times)
Offline yz
« on: Sun, 13 July 2025, 07:16:24 »
825
a simple 1800 office board designed for the 8-to-5 grind (lol sry darien)
Contents
  • Specifications
  • Progress
  • Sales & Pricing
  • Renders & Photos
  • FAQ
  • Socials & Build Vlog
1. Specifications
Case Angle:
Keyboard mount: Tadpole Top Mount
Front Height: 18mm
Effective Keyboard Height: 22.4mm
Net Weight: ~1.5kg (no internal weight, built)
Case Materials: 6063 Aluminium
Hardware Materials: SUS304 Stainless Steel (case screws & daughterboard screws)
Plate Materials: 6061 Aluminium & Polycarbonate (1.5mm thickness)
PCB:
  • 1.6mm FR4 designed by Zeix
  • QMK & VIAL Configurable
  • 3x LED indicators
  • Fly Daughterboard with ESD protection
Layout Options:
2. Progress
  • Keyboard – 1st prototype ordered, internal/external dimensions confirmed
  • Carrying Case – design in progress, prototype to be ordered thereafter
  • PCB – design in progress, prototype to be ordered thereafter
3. Sales & Pricing
Pre-order base kit price: SGD 375 (USD 294)
Extras base kit price: SGD 415 (USD 325)
Kit includes:
  • 1x Keyboard Case (hardware pre-assembled)
  • 1x Solder-only PCB, daughterboard & JST cable
  • 4x 8mm bumpons
  • 1x Carrying Case
50 units
FCFS on shostudios.co
Pre-order target date: Aug 2025
Targeted Completion: Mid-Dec 2025
4. Renders & Photos
Silver
Blue-Grey
Black
Prototype Photos
TBA
Exploded View
5. FAQ
  • Was this inspired by the cypher/hbcp/FC980?
    Yes.
  • Will _____ color/plate/layout be available?
    Nope. Plate files will be made public after fulfilment so feel free to have one made in whatever configuration you'd like.
  • Any vendors avail?
    TBA
6. Socials & Build Vlog
To keep up with the latest information for this board, join my discord server, or follow me on instagram!
Thank you for checking this project out!
« Last Edit: Sat, 19 July 2025, 11:18:33 by yz »
Offline mr_foggy
  • neue = nope
Re: [IC] 925 - a simple 1800 office keyboard
« Reply #1 on: Sun, 13 July 2025, 07:21:36 »
everything about this is actually awesome. I’m very much in
Offline yz
« Reply #2 on: Sun, 13 July 2025, 08:08:08 »
cheers mate, appreciate it
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Sun, 13 July 2025, 10:59:26 »
Very classic & clean design OP, I definitely dig it! The only thing I'd like to see is some internal weights to tighten up the sound some. Wouldn't even mind zinc weights to just add some extra mass to help dull out the higher pitches while still keeping the price reasonable at your 50 MOQ.
Offline Fluxius
« Reply #4 on: Sun, 13 July 2025, 13:14:25 »
Very nice. Will the 6u spacebar support be center, off-center or both?
Offline Raie_de_Boule
« Reply #5 on: Sun, 13 July 2025, 16:49:25 »
I'm potentially in  :-X
Offline yz
« Reply #6 on: Sun, 13 July 2025, 20:52:13 »
thank you. i'll be adding support for both
cheers
this was originally designed for my friends and relatives who wanted a custom keyboard that wasn't too heavy to bring around to-and-from the office, so I thought adding weights would kinda defeat that purpose. perhaps I could add some replaceable aluminium 'weights' and provide brass/stainless steel weights as optional extras
Offline yz
« Reply #7 on: Mon, 14 July 2025, 02:04:45 »
pending name change since there's an existing project by dnworks also called the 925 that I haven't come across until now  :-[
Online Rob27shred
« Reply #8 on: Mon, 14 July 2025, 07:09:09 »
cheers
Ah, I see. I figured there must've been a reason you didn't have a weight designed into this. I'd be more than happy with having replaceable alum weights stock & denser material weights being add ons. Although since you have a prototype ordered already we'll get a chance to see how it sounds as it is designed right now. Never know it might be just fine as is without weights?
Offline yz
« Reply #9 on: Mon, 14 July 2025, 09:15:55 »
that'll be the first litmus test for sure, hoping for it to sound close to a cypher because that board sounds great without weights too
Offline Katumbas
Re: [IC] 825 - a simple 1800 office keyboard
« Reply #10 on: Mon, 14 July 2025, 10:35:01 »
I really like this. I would like to see 1.5-1.5-7-1.5-1.5 bottom row compatibility.
Offline yz
« Reply #11 on: Tue, 15 July 2025, 00:50:32 »
if it doesn't make the bottom row too much of a swiss cheese, I'll request the PCB designer to look into adding this :thumb:
Offline yz
« Reply #12 on: Sat, 19 July 2025, 11:20:00 »
/list removed, cheers for the 🍆 simone
« Last Edit: Sat, 19 July 2025, 11:21:41 by yz »
Offline jd
« Reply #13 on: Sun, 20 July 2025, 12:21:04 »
Great design. I will definitely keep an eye out for the group buy later this year.  :thumb:
Offline LogolicusZ
  • Location: Land of Cheese with many holes and Tall Mountains with chocolate
« Reply #14 on: Mon, 21 July 2025, 07:41:08 »
Definitely interested in this, cool project!
