Author Topic: [IC] Juna 60% - New Prototype Photos, Sound Test, Color Samples added!  (Read 14849 times)
Offline LogolicusZ
  • Location: Land of Cheese with many holes and Tall Mountains with chocolate
A comfy, fun-to-type-on 60.
Discord • IC Form
1. Inspiration
This design is one of my earliest from-scratch attempts, inspired by classics like the OTD 360c but modernized.
The name and theme of the board stems from the Charm Album by Clairo!
2. Specifications
  • Layout: WK only
  • Case Angle: 7.5°
  • Keyboard mount: Top Mount & Gasket O-Ring
  • Front height: 17.8mm (Non Effective height)
  • Net Weight: ~1.25kg (With internal brass weight built)
  • Case Material: Aluminium
  • Weight Material: Brass
  • Hardware Material: Stainless Steel (case screws & daughterboard screws)
  • Plate Materials: Aluminium
  • PCB: (Board was Designed around H60 PCB footprint)
    • 1.6mm FR4/CEM3
    • QMK & VIAL Configurable
    • Daughterboard with ESD protection
  • Plate Layout Options:
4. Progress
Keyboard
  • 1st Prototype already in hand. Pictures & Sound test taken already.
  • Will be ordering a second prototype
Carrying Case
  • Is planned!
PCB
  • CEM3 Mechlovin PCB used in prototype.
  • Will switch to FR4 PCB for second prototype.
5. Sales & Pricing !Updated MOQ & Price!
Pre-order base kit price: MOQ 25 -> Price ~350usd
Kit includes:
  • 1x Keyboard Case (hardware pre-assembled)
  • 1x Alu Plate
  • 1x Solder-only PCB, daughterboard & JST cable
  • 4x 8mm bumpons
  • (1x Carrying Case)
FCFS on TBA
Pre-order target date: 2025–2026
Targeted Completion: TBA
Manufacturer
Prototype was produced by DDS, in talks with other Manufacturers so might change which is used for the Run.
3. What are the differences of the final Design to the V1 Prototype?
The version that is going to run is the one in the renders!
Changelog:
  • Smaller Top Bezels
  • Side has moved back a bit to allow the corsa side to be bigger
  • Corsa side angle has been made more pronunced
  • Bottom Corners are rounder now
  • Adjusted Feet Placement
  • Top case fillet to chamfer
  • Higher typing angle
  • Different Plate cuts
  • Bigger Weight
  • Different Engravings
6. Renders & Photos
Render are not indicative of the final color and should only give a idea!
Seafoam Mint
Cyan
Exploded View
Plate
Prototype v1 (Produced by DDS)
Prototype v1.5 in Mint (Produced by DDS)
Color Samples (Produced by DDS)
7. Sound Tests
8. FAQ
  • Do we really need more Corsa looking 60s?
    No, not really, yet I still wanted to do this Project
  • Will ___ color/plate/layout be available?
    I am trying to keep the SKUs small so depending on the interst shown might have the option for other Weight materials and Layouts. Plate will be made public after fullfilment.
  • Any vendors available?
    TBA
IC Form
Please fill out the form!
Thanks
Thanks to all my friends for pushing me to continuing this project!
8. Socials
Discord Instagram
UPDATES!
Vendors:
Europe /UK: Prototypist (Main Vendor)
Asia: Kibou
USA/NA: Click Clack
Prototype:
New Prototype has been ordered in Mint and also a sample of the Cyan ano!
Small additional change to the design is a Daughter board cover, renders will also be updated for the GB
Manufacturer for the proto and GB will be DDS!
Additional offerings:
You asked for WKL and you shall have it! WKL is now going to be an option at the GB.
« Last Edit: Thu, 13 November 2025, 05:00:54 by LogolicusZ »
Offline LogolicusZ
Re: [IC] Juna 60%
« Reply #1 on: Wed, 16 July 2025, 14:34:25 »
Reserved
- Fixed the IC and Discord Links
- Updated a few Items do to feedback! (Changelog, PCB Details, Plate Render)
06.08.2025
- Added Updates section
- Vendor has been added
- Prototype has been ordered
- WKL as an option has been added
« Last Edit: Wed, 06 August 2025, 14:28:56 by LogolicusZ »
Re: [IC] Juna 60%
« Reply #2 on: Thu, 17 July 2025, 13:42:11 »
Approval :thumb:
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
Re: [IC] Juna 60%
« Reply #3 on: Thu, 17 July 2025, 13:48:42 »
Cool board with cool theme!
That photo of the proto :chefskiss:
Offline Raiden_Shogun
Re: [IC] Juna 60%
« Reply #4 on: Thu, 17 July 2025, 13:56:15 »
What pantones are the mint and cyan?
Offline cht1821
Re: [IC] Juna 60%
« Reply #5 on: Thu, 17 July 2025, 14:21:26 »
based wk 60%  ;D
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] Juna 60%
« Reply #6 on: Thu, 17 July 2025, 17:52:25 »
dawg you either need a new manu or perspective on designer fee if you're gonna charge 450 for ten units on something this simple
Offline Flybeck
Re: [IC] Juna 60%
« Reply #7 on: Thu, 17 July 2025, 22:50:28 »
Good job! Many people don't understand how MOQ and price work :). Best of luck!
Offline ratix
Re: [IC] Juna 60%
« Reply #8 on: Fri, 18 July 2025, 11:18:06 »
In! Excited to see this run. Left my comments in the IC form.
Offline bluranerd
    • Youtube
Re: [IC] Juna 60%
« Reply #9 on: Fri, 18 July 2025, 18:51:51 »
GLWIC!!! I’m rooting for you dude. Glad to see this board finally reach IC  :thumb:
Offline azhdar
  • Praise the AZERTY god
Re: [IC] Juna 60%
« Reply #10 on: Sat, 19 July 2025, 01:09:16 »
ISO
Azerty Propagandiste
Offline OrinNYC
Re: [IC] Juna 60%
« Reply #11 on: Tue, 22 July 2025, 16:04:06 »
looking good!!!!
Offline KOBO ISSHI
Re: [IC] Juna 60%
« Reply #12 on: Wed, 23 July 2025, 03:01:26 »
Top work!  :thumb:
Offline eaglevee
Re: [IC] Juna 60% - New Prototype Photos, Sound Test, Color Samples added!
« Reply #13 on: Thu, 23 April 2026, 03:05:25 »
Looks good, but doubt it will sell with this price
Offline 1manny
« Reply #14 on: Fri, 24 April 2026, 08:51:42 »
New price is $325  :thumb:
