Author Topic: [LIVE] TAIKO-01 100% Funded on Kickstarter in <8 hours  (Read 15718 times)
Offline dailytadpole
« on: Thu, 17 July 2025, 12:44:18 »
Edit:
Kickstart is now LIVE! TAIKO 01 just hit its Kickstarter funding goal and we are absolutely buzzing right now.
Early bird discount won't last much longer It's only until tonight.
Grab it while you can for $300 at $100 off MSRP: https://www.kickstarter.com/projects/taikohub/taiko-01-keyboard
With the TAIKO 01 keyboard, you're getting a battle tested design that's been iterated on for the last 4 years over >120 users. QMK compatible, hotswappable, curved keyboard with an incredibly ergonomic thumb cluster that's designed around hand anatomy. Best of all, there's a 1 year warranty and a 30 day return policy.
TLDR:
  • Concave, split & tented: Mirrors the natural movement of your hands, so you stop reaching and start resting
  • Clinically grounded design: Built around real anatomy and biomechanics, not aesthetics
  • Tested and iterated for 4 years with >120 users
  • Fully customizable keymap with QMK, VIA, Vial
  • 30 day return policy
  • 1 year warranty
317371-0
317373-1
317375-2
Original Post:
I wanted to share a couple images for a keyboard I'm in the process of making. I've used dactyl-like keyboards before and I've always wanted one that feels solid with high quality injection molded cases instead of the 3D printed one I had, so this is me giving it a go. I didn't show it in the pictures, but it would be hotswappable and it'd have legends and blinds on the keycaps. I've previously operated a small online store called TaikoHub where I was selling 3D printed dactyls that I designed from scratch.
If you're interested, please check out the interest check here:
https://taiko.taikohub.com
313747-3313749-4313751-5313753-6
Materials: Injection molded ASA plastic.
Target price: ~$300.
Wired/Wireless: The product would come wired. But may introduce a wireless module afterwards.
Progress to date:
Finished keyboard matrix PCB with Kailh Sockets
Finished PCB Shield (Protects the PCB during hotswap)
Visited manufacturer in Shenzhen
Pending Tasks:
Order prototype
Design for manufacturing to optimize for injection molding
« Last Edit: Wed, 03 June 2026, 16:12:06 by dailytadpole »
Re: [IC] Introducing the TAIKO-01
« Reply #1 on: Thu, 17 July 2025, 13:50:48 »
Approval :thumb:
(Sorry for the 403 errors and issues uploading pics, will hopefully have that resolved soon so you can share photos here as well)
« Reply #2 on: Fri, 18 July 2025, 13:26:44 »
Not sure why but I'm still getting the 403 forbidden error when I try to attach an image. Here's pictures of the issue.
https://imgur.com/a/AkDypYk
« Reply #3 on: Thu, 24 July 2025, 15:59:39 »
313745-0313745-1
Offline kathleengord
« Reply #4 on: Tue, 05 August 2025, 22:36:58 »
Looks beautiful! What do the innards of this keyboard look like, is it individual little PCBs for each socket then wired together?
« Reply #5 on: Wed, 06 August 2025, 21:14:20 »
Thanks! It's a giant circuit board. It's not small PCBs, I find those to be too fragile.
« Reply #6 on: Sun, 10 May 2026, 22:57:12 »
As an update, Here's some pictures of the new keyboard at the bottom of this post.
It's been some time since my last post. A lot's happened since then. I ended up doing a full redesign, getting an engineering firm to do DFM, securing component suppliers and switching to a Kickstarter launching June 2nd. This is the Kickstarter page and this page shows the product development process. If you sign up for the waitlist now, you can get a discount on top of the promotional launch price.
### 1. How this keyboard started
A bit about me. I developed carpal tunnel syndrome and wrist tendinosis back in 2020, tried a bunch of things like physio, wrist brace, etc that helped but didn't fix my problems. I ended up looking into workplace ergonomics and made my own split dactyl-like keyboard. By sheer coincidence, I ended up making keyboards for people for the past 4 years. I've talked to a ton of awesome users over those years, made a ton of iterations. I quit my job this year to create the TAIKO-01 based on their feedback.
### 2. Updates
Since the last update, I did a full redesign of the keyboard. This was to optimize design for manufacturability. But now it's finally done, so everything is ready for injection molding. Since I've been doing this for years, you wouldn't think it'd take this long. But it ended up taking an entire year 😱. It's humbling how hard it is going from 3D printing to injection molding.
### 3. What's special about this keyboard
You might've seen split concave keyboards like Kinesis Advantage, Glove80. Here's how the TAIKO-01 is different:
1. It's more compact, which makes it easier to transport.
2. It has a thumb cluster that's easier to reach because it's oriented at a downward angle. This lets you use thumb abduction instead of thumb extension, clarified by this [diagram](https://www.researchgate.net/publication/387167221/figure/fig2/AS:11431281300207709@1735349306942/Thumb-flexion-extension-left-and-palmar-adduction-abduction-right.tif). Thumb abduction is much more ergonomic than thumb extension, which is what happens with  Kinesis Advantage, Moonlander and Glove80. This is because thumb abduction puts you in a handshake position.
3. Layer keys (LOWER and RAISE) are offset at a lower height compared to other keys on the thumb cluster so you won't accidentally hit it. Note that layer keys let you toggle or temporarily switch to a different keyboard layout.
4. It's hotswappable. It's also QMK compatible.
5. If you want to see a side by side comparison with the Kinesis Advantage, I made a quick video here: https://youtube.com/shorts/GId4orK1fn0?si=lI4tkaxdlz51owd3
6. Does the concave shape actually make a difference?
Anatomically it makes sense because your fingers are not the same lengths. Think of how glove have different lengths for each finger. You'd expect each column of a keyboard to have a different curvature to match your finger's range of motion and a different height to match it's length.
### 4. The ultimate goal
But it's one thing to be confident from anecdotal evidence and another to be confident from clinical evidence. The goal is to save enough from sales to do a clinical study so we know how split concave keyboards helps people and what exactly it helps with (carpal tunnel, wrist tendinosis, de Quervains, epicondylitis, etc). From user feedback (n>120), there seems to be strong feedback it helps people with their wrist/hand/elbow pain. It's just what exactly it helps and under what circumstances it helps (used with standing desk, augmented with physio, etc) is muddled.
If you're interested, please check out [taiko.taikohub.com](https://taiko.taikohub.com).
316988-0
316992-2
« Last Edit: Sun, 10 May 2026, 23:10:17 by dailytadpole »
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #7 on: Mon, 11 May 2026, 02:10:09 »
I envy your posture.
« Reply #8 on: Mon, 11 May 2026, 10:41:28 »
Haha thanks  :D
« Reply #9 on: Wed, 13 May 2026, 13:05:29 »
Some pictures to compare the ergonomics of this keyboard and other keyboards
317031-0
317025-1
317027-2
317029-3
« Last Edit: Wed, 13 May 2026, 13:07:35 by dailytadpole »
Re: [LIVE] TAIKO-01 100% Funded on Kickstarter in <8 hours
« Reply #10 on: Wed, 03 June 2026, 16:12:39 »
We are now LIVE on Kickstarter!
« Reply #11 on: Thu, 18 June 2026, 15:19:11 »
Added a few more units of the Early Bird. If you weren't fast enough to get the Early Bird discount, now's your chance haha.
Offline nathanchere
« Reply #12 on: Sat, 20 June 2026, 08:32:58 »
Would be appealing if it wasn't on kickstarter. I know the keyboard group buy 'scene' is often a shi*tshow at the best of times but Kickstarter makes it way too easy for both incompetence and outright scamming.
