Author Topic: "403 Forbidden" Errors  (Read 31376 times)
« on: Thu, 17 July 2025, 15:04:46 »
Update 2025-07-21: Post editing and most other causes of the 403 errors should be resolved now. If you are still seeing errors, please share details here so we (MattMD ;) doing all the heavy lifting here - huge thanks) can help track them down. Thank you!
Hey all, many of you have noticed and brought it to the mod team's attention in the last few weeks that you are experiencing 403 Forbidden errors when making new posts or editing existing posts. I've been responding to folks as it has come up, but obviously it is affecting enough people that a post is warranted.
The (small, but diligently working) dev team is aware of the 403 error situation, and is working on diagnosing exactly what is causing it. In the meantime, unfortunately, we will need to use workarounds or simply work within the confines of the current state of things. Apologies in advance for all of the headaches that this causes.
Cause:
For some reason, posts that exceed a character limit are not allowing preview or post actions to process correctly, causing the 403 Error to appear. This character limit is small enough that it causes significant issues creating an IC or GB thread in particular.
Workaround:
It's not easy, and it is no better than the obvious. Posts will need to be split into multiple smaller segments in order to accommodate the character limits. For GB threads, since those all require approval in the first place, please feel free to "Reserve" multiple posts after the OP, even if you are not currently using those posts as part of the existing GB thread content. There will be no trouble getting a few responses in before anyone else can.
Resolution:
As stated earlier, the root cause and therefore solution to the problem is not known exactly at this time. The dev team is working on it, but it will require some time before these 403 errors are completely resolved. I will update here as more information is available and/or the errors are completely resolved.
« Last Edit: Mon, 21 July 2025, 15:08:26 by HoffmanMyster »
Online Rob27shred
  • Insane in the Membrane! 👻
Re: "403 Forbidden" Errors
« Reply #1 on: Thu, 17 July 2025, 15:24:38 »
Pleas have them look into why the "403 Forbidden" error is happening when trying to change anything in your profile too. I've been wanting to change my profile pic, but get the error every time I've tried in the past month.
« Reply #2 on: Thu, 17 July 2025, 16:09:12 »
Will mention this case as well, thanks for bringing that up in particular
Online Rob27shred
« Reply #3 on: Thu, 17 July 2025, 17:06:36 »
Appreciate it man! :thumb:
Offline phinix
« Reply #4 on: Fri, 18 July 2025, 19:20:42 »
I keep getting this error when trying to attach jpg file and post it.
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline MattMD
« Reply #5 on: Sun, 20 July 2025, 15:58:17 »
Hey everyone, I do believe I have fixed the profile picture, post size, and attachment issues on posts. I have been able to successfully post a large post with multiple attachments that are a few megabytes each. If other people on the forum could validate that for me, and I know you will ;), I would appreciate it. Again, I'm sorry for this dragging on so long, I have been trying to track down the issue that ultimately still stems all the way back from the DDoS that geekhack was seeing weeks ago. I do believe I was successful in doing that today, so please, help keep me honest and let me know if the 403's have disappeared for you.
Of course if you're seeing them anywhere else than what I called out, please let me know as well, because these were the only reports I was aware of. Thank you for your understanding and your patience.
Cheers,
Matt
Offline hasu
  • @tmk
« Reply #6 on: Sun, 20 July 2025, 18:09:55 »
I confirmed that I can modify my large post successfully without 403 error now.
Thank you for your great admin service to the community!
Offline Piperaceae
« Reply #7 on: Mon, 21 July 2025, 07:59:36 »
Confirmed I can now post a lengthy draft IC and preview it without getting a 403. Thank you!
Offline cartersrush
    • Discord
« Reply #8 on: Mon, 21 July 2025, 09:44:44 »
What is the character limit? It would be nice to know these things.
Also if you add more than 2-3 images (even if its a imgur link) you get the error as well.
Though it's good that this is finally being looked into cuz I had this issue a year back as well and it's gotten way worse.
« Reply #9 on: Mon, 21 July 2025, 15:14:00 »
Are you still having issues with imgur embeds? I just tested with 12 imgur images embedded in a post and it worked just fine, any info/screenshots/etc you can share about that would help diagnose.
Offline phinix
« Reply #10 on: Mon, 21 July 2025, 17:54:23 »
Yes, confirming - works fine now.
