Author Topic: What is best latest TKL keyboard kit I could buy?  (Read 111724 times)
Offline phinix
Re: What is best latest TKL keyboard kit I could buy?
« Reply #50 on: Thu, 08 January 2026, 15:43:47 »
OK, test number.... 113.
Tomorrow new keyboard will be delivered - Nuphy Node 100 (low profile, beige version).
I hope mods on that will be ok. However, it is kinda messed up full size cause cursor cluster is moved :(
I hope that those red switches going to be heavy enoughf or me. I wonder if low profile needs lighter spring for same result as standard profile.
OK, so Node 100. Very good feeling when typing, too light for me, would need to swap sp;rings for something heavier.
Problem is, that layout. Move nav and arrows cluster and I'm dead...
Why the hell Nuphy did Node 100 high profile with normal layout, but low prifle made weird.
Offline HungerMechanic
« Reply #51 on: Fri, 09 January 2026, 10:23:48 »
Because of weird layouts, I avoid those 98-100% keyboards. I figure, they should just go 104 key if they're going to be that large.
That said, the Neo98 seems to be quality and affordable:
https://www.qwertykeys.com/en-ca/collections/neo-product-collection/products/neo98-custom-mechanical-keyboard
Offline phinix
« Reply #52 on: Sat, 10 January 2026, 16:35:49 »
Oh, not for me :)
Its almost same as Node 100.
Are there any other low-profile good keyboards?
« Reply #53 on: Sun, 11 January 2026, 05:01:23 »
I don't have any low-profile keyboards.
The only one I've heard good reviews for is the Nuphy Air75.
Wouldn't mind having one of those. Some of the low-profile tactiles are interesting. From the various Gateron-style 'browns' to some off-brand 'browns' that are non-MX feeling, to the Kailh Sunset which actually have some personality.
It seems to be no cheaper than setting up an MX keyboard, though.
Offline julimma
« Reply #54 on: Thu, 12 February 2026, 19:48:07 »
NEO 80CU or TOFU TKL. Both sounds great
Offline phinix
« Reply #55 on: Fri, 13 February 2026, 04:17:30 »
I missed TOFU GB, need to keep an eye on R2.
Do you have that TOFU TKL? How is it?
So far I can see its heavy as hell, might feel pretty firm, even with that gasket mount, is that right?
I need to watch some typing videos.
I love retro U9 look, but for this keyboard I would pick Mocha.
Offline julimma
« Reply #56 on: Fri, 13 February 2026, 09:15:32 »
One of the content creators in China made a comparison among all the recent TKLs. And I believe the Tofu TKL wins by a big margin, even beating the NEO80cu. Here is the link.
If you missed the GB don't worry. There will be  Gurokawa and Lucy collabs soon.
Offline phinix
« Reply #57 on: Mon, 16 February 2026, 18:15:35 »
Test number... 114 ;)
I just ordered Smurve80. Hopefully it will end up good, cause I'm tired of trying new keebs...
Offline Sup
« Reply #58 on: Wed, 18 February 2026, 11:26:50 »
Phinix, it’s been such a long time and you’re still searching for the best, latest keyboard. I hope one day you find your end game  :thumb:
current
Coming soon
« Reply #59 on: Wed, 18 February 2026, 12:41:05 »
What are your thoughts on the Neo80CU? Does it have different typing characteristics than the regular Neo80?
Also, does the Neo80CU have the same easy disassembly as the Neo80, and are the PCBs compatible? As in, interchangeable.
Offline phinix
« Reply #60 on: Tue, 07 July 2026, 15:18:38 »
OK, after trying out like 8 different keyboards I think I found one that is really good out of the box.
It covers few things that I like in keyboards - standard TKL layout, lovely retro color (beige), stabs lubed and ready to use, cool retro beige usb-c cable 9always a plus:), sounds and feels nice.
Keychron C1 Pro 8K
It comes with different switches, I picked Super Banana (tactile). Caps that it comes with are OSA retro.
Do I like it? Yes, bought 5 of them in a month :D
317660-0
« Last Edit: Sat, 01 August 2026, 06:53:22 by phinix »
Offline pisowifilogins
    • 10.0.0.1 Piso Wifi
« Reply #61 on: Fri, 04 September 2026, 06:26:01 »
If your router uses the 10.0.0.0.1 IP address, you will be able to log on to its console simply by typing it in your browser.
Offline upscale image
« Reply #62 on: Tue, 15 September 2026, 20:11:40 »
Glad you found a good TKL! If you ever want to share clear photos of your build, try <a href="https://upscaleimage.pro">image upsacler</a> to make your images bigger and sharper.
Offline darknova88
« Reply #63 on: Thu, 17 September 2026, 10:45:40 »
Keychron C1 Pro 8K
I think you should just stick with the C1 Pro at this point. You found something you actually enjoy using, bought five of them, and they take your heavy Oil Kings without giving you stab headaches. A nicer custom might be better on paper, but I don't think it would necessarily be a better keyboard for you.
